Question about Pentax K100D Super Digital SLR Camera
Blurry pictures with Pentax K1000
I am using the longer zoom lens and the picture looks focused when I take it but when develped the pictures are blurry.
    Problem Solver:
  • 18 Answers
It may be the equipment or it may be the way you are holding / taking the picture.
Here are suggestions on how to take better zoom lens pictures (this also applies to any camera) before you start diving into the equipment.
1) Use the fastest shutter speed possible. This reduces the amount of time of exposure, this limiting the amount of motion blur that can happen.
2) Don't hold the camera by hand. Either use a tri-pod or rest the camera on something stable, like a wall, rock, bench, etc. This makes it less likely that the camera will move when you are taking the picture, thus reducing motion blurr in the image.
3) If you have to hold the camera by hand, hold the zoom lens with your left hand (because it is more towards the center of gravity than the camera is) & try to slow your breathing & take the picture between heart beats.
4) Also, another thing that helps is to use a remote shutter release (such as that rubber bulb or plunger attached to the shutter release). I would also say using the self-timer would help, but the K1000 doesn't have that. This is so the camera doesn't shake from you pushing the shutter release button.
5) Make sure the lens is clean! Even get one of those lens pens from your local camera shop.
If you have tried all (or most of these) then its time to start looking at your equipment, such as . . . is your shutter getting stuck when exposing, thus lengthening the exposure and making for a blurring shot or do you need glasses? <grin -- which is why I find it really difficult to use manual focus equipement now, because my eye sight is really bad!>
Take care & Happy Imaging!
Glen
Posted on Jul 26, 2008
    Scholar:
  • 133 Answers
It may be that because you are using a zoom lens that any instability in the camera's positioning may cause motion blur on the moment of taking the picture. Either that or the developing process of the photos is failing in some manner.
Posted on Sep 06, 2007
SOURCE:
Out of focus pictures when shot with view finder
I had a problem similar to this. Try taking off your glasses or removing your contacts and try again. Best of luck.
Nov 23, 2013 | Canon EOS 60D Digital Camera with 18135mm...
Viewfinder blurry Pentax K100
The image is directed by the lens to a mirror then to a prism then to the viewfinder. The mirror flips up when you take a picture so the image can reach the film behind it. If the lens is ok it is possible that the mirror is very dirty or not returning completely to the proper position after a picture is taken. If the mirror is dirty you should have it professionally cleaned because it is a very light weight metal mirror and VERY EASILY SCRATCHED. If you have another lens then mount it and see if it is also blurry and cannot be focused.
A few cameras like certain Olympus models have a mirror lock up option which you use after focusing the image while the camera is on a tripod. This gets rid of the slight vibration caused by the mirror swinging up out of the way while taking. a picture.
If all else fails you might consider taking it to a good camera shop if you can find one.
Digital cameras are getting better and better but there are still things film cameras can do that most digitals cannot. Long exposures in "Bulb" mode and multiple exposures are among these. Also each brand of film has it's own Artistic color expression such as Afgachrome vs. Kodachrome.
Jul 16, 2013 | Pentax K1000 35mm SLR Camera
I dropped my pentax k1000 and the lens is stuck. wont focus, wont move at all. do i need to buy a new one and if so, how much/what kind am i looking for?
While turning the camera on, or zooming gently push and pull the lens to get it unstuck. If you have to buy a new one it will cost you $75 here.
Mar 22, 2011 | Cameras
Pentax K1000 35mm SLR Camera Lens will not turn or focus= stuck
Impact damage??? remove the lens and check the barrel for straightness. also the rear lens element must be perfectly straight. some of the latest lenses have a plastic helical gear that can be tapped out with a light hammer and a piece of wood ( 1in X 4in. ) used on the high end of the rear lens, if impacted.
Oct 16, 2009 | Pentax K1000 35mm SLR Camera
Lens problem, no zooming capabilities and blurry images
This would need to be serviced something is wrong with the auto focus and this is inside the lens housing. I would take it into a camera shop and have the examin the autofocus.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jul 13, 2009 | Olympus FE-230 Digital Camera
All zoom pictures blurry
I am sure your lens is clean but from what you describing you have a definte problem with the lens assy which includes the autofocus sensors. Sometimes is can be a faulty focus motor , dirt between sensor and outer lens. Camera needs to be stripped and checked up.
Mar 27, 2008 | HP Photosmart R817 Digital Camera
Lens damaged camera dropped camera body damaged pentax k1000
"To get the lens to retract, we tried to do a slight twist over to the left (looking at the camera like your the subject - camera lens is facing you). Sure enough it went back in! But now it has trouble focusing. That's another question now. Darn thing...we'll see what else we can jimmy :-)"
quoted from another solution.
Mar 15, 2008 | Pentax K1000 35mm SLR Camera
Pentax K1000 camera
VGDHDTH HNTFHDT VGJFT GJ ME MAY
Dec 19, 2007 | Cameras
SLR not working
The lens you are talking about has either:
1)a faulty diaphragm mechanism ( lens stays closed at f 22 or f 16 when you attach it to the camera instead of opening fully as it should ) . or
2) the lens is fine but the diaphragm coupling mechanism inside mirror box ( on the left hand side if viewed from the front ) is not engaging the lens properly so that your lens stays fully closed ( F 22 /16 ) : because diaphragm stays fully closed image in viewfinder appears v. dark.
Solution ? have a camera technician take a look but my guess is that the diaphragm needs cleaning and it should not cost you more than $ 80 bucks.
Nov 26, 2007 | Pentax *ist D Digital Camera
Pentax K100D Super Digital SLR Camera Logo
406 people viewed this question
Top Pentax Cameras Experts
Ekse
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
