Question about Kenmore 95822 / 95824 / 95829 Electric Kitchen Range
Error code E1 -F5- Broil element comes on and wont shut off
Tried to preheat oven, after 5 min. an error beep and code E1 -F5- then broiler came on and would'nt go off, had to turn off power at breaker. Stove top works fine. Hoping for an easy fix, Thanks
  • FinFan Sep 28, 2007
    Thanks for response applianceboy and I do believe its something involving the door latch. I just did a self-cleaning (hi) and that fixed it, The (lo) cleaning wouldnt work so I guess it was thinking it was in cleaning mode somehow and needed to go thru the whole process. Yes I'm sure it all stems from the door latch somehow. Thanks
I just did the self clean option and when it was done I received the error code E1 -F5- and it does have to do with the door latch. After turning off the power to the stove I was able to open the door and wiggled the latch and that solved the problem.......
Posted on Oct 24, 2007
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 77 Answers
If it is a whirlpool, kitchen aid or kenmore by whirlpool you need to check the self clean latch asembly found on the rear of the unit. check the micro switches with an ohm meter. always remember to unplug the oven before you test any thing or replace parts. not sure why the broil wouldnt shut off. but the f5 error is definatly related to the door latch.
Posted on Sep 28, 2007
SOURCE:
I have an old Modern Maid double oven. DK 0757. Broiler comes on everytime I try to heat for baking. Any suggestions
It was common for the broil element to come on during the preheat time on older oven controls. When the oven reaches temperature the broil should shut off. If this just started then the points in the broil switch section are welded together and the oven thermostat will need replacing
Mar 20, 2015 | Ovens
My oven preheated fine and when I put the stuff in the oven the broiler element was still on and wouldn't go off. Do you know what would cause this?
It sounds like the broil relay contacts welded themselves shut (closed). You will need to replace the Electronic Oven Control (EOC).
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Nov 07, 2014 | Kitchen Ranges
Large oven in dacor dual oven range broiler comes on when i select bake
on bake both bake and broil will come on the broil shuts down around 260 deg
this is normal its done to shorten preheat time
Jun 03, 2017 | Dacor Epicure ERD30 Dual Fuel (Electric...
I'm getting an E1 f5 error code and my oven won't light
The F5-E1 error code means that their is a problem with the switch on the self clean door latch...it (the switch) is telling the control board that the door is locked even though it may be open so it will not let the oven come on
GENE
Nov 14, 2011 | Whirlpool SF325 Gas Kitchen Range
Ran self clean now oven will not heat up
Turn the breaker off for 5 minutes then turn it back on see if this helps if not let me know.
Sep 27, 2011 | Whirlpool RBS305PRS Stainless Steel Oven
Whirlpool oven question...FSEO on display after about 5 mins of oven operation..beeps continuously,oven shuts off...dinner ruined!
If you receive error codes F5-E0, F5-E1 or F5-E2, the door and latch switch need checking and possible replacement.
The door switch is #12 in the diagram (click image for zoom)...
Hope this helps.
Jun 22, 2011 | Whirlpool RF364 Electric Kitchen Range
Heating elements will not heat and getting an error code E1 F-5
Hello,the lock latch is located directly in the center upper portion of the door. It is a hook shaped latch that lock by turning downward. This lock gets stuck in this position which causes the e1 f5 error code. Locate the latch through the vent holes in the upper front of the oven door. Insert flat headed screw driver into vent hole and gently push latch up to a horizontal position & simply open door. Once unlocked, push cancel on the control panel.This will clear the error code and resolve the issue.
Thanks
May 30, 2010 | Whirlpool Ovens
SLOW HEATING OVEN
you may want to check your broil element
turn the unit on and wait a few minutes
see if you can feel the heat from the upper broiler elemnet
some model use both elements to preheat
i dont have your productiuon number so i cannot be sure with your model
anyway
14-20 mins is the industry standard for a 350 preheat...
Oct 25, 2009 | GE 30" Built-In Single Electric Wall Oven...
Whirlpool Gold Electric Oven F5 E1 code on bar code
For some reason I get the same error code every time we have a power outage. If you push and hold the "lower off" button for about ten or 15 seconds it will unlock and reset. Hope this helps.
Jan 26, 2009 | Whirlpool GBD307PDS Electric Double Oven
Kenmore 95822 / 95824 / 95829 Electric Kitchen Range Logo
937 people viewed this question
Top Kenmore Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
