Question about Sony KDL-32S3000 32 in. LCD Television
No power When I push the power button the green light turne on it clicks on and the picture flash twice wit no video jus low bright, then it make little sound and shuts down. The red lght blinking 6 time stop and blink again and still stop and blink 6 time. If someone know about I need help. Thanks
  • 1 more comment
  • Anonymous Sep 10, 2007
    My boss don't have manual, hi won't I despend time to try fix it ????. I think if of the problem is backlight, some video will show when it flash. The audio plays little time. May be you right but I need the board to make shur were ara the problem. Thank you. I will still tring your idia.
  • Anonymous Mar 16, 2014
    Green light comes on blinks a few times and then shuts off
  • Anonymous Mar 30, 2014
    blinking red light bottom corner blinks twice
    Scholar:
    New Friend:
  • 28 Answers
Recent LCD Tvs are designed to acquire signals from receiver devices. For example, connect pheripheral like VCRs, DVD players, or Dish Cable receiver Satellite transmiters to the LCD TV. The display should move pass the blank screen upon powering on. A new TV is not expected to malfucntion. Consult the TV user guide for diagnostics
Posted on Jan 08, 2011
    Scholar:
  • 133 Answers
It sounds like the backlight or an inverter board on the television may have failed. Check your warranty status on the television to see if you can get it repaired by the manufacturer for free.
Posted on Sep 06, 2007
SOURCE:
No picture no sound opc light and power light
This is very common in sharp tvs.U turn it on.U get power on light stable right?U hear a click,one or twice,sometime tv is good right?Sometime POWER light and OPC light flashes?Push the power button on/off couples times will work, picture will come on.If keep trying off/on couples time after POWER and OPC flashes,don't ever stop and never get backlight and picture.Ur Video backlight board is dead must replaced.
Dec 28, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
RED LIGHT FLASHING
da red light means rudolph is near by so hide ur cookies cause santa wit him
Jun 28, 2009 | Sony PlayStation 3 40GB System
Stays in standbye and will only flash green (power on) twice before staying in standbye
The 6 inverter transformers on the bottom of the picture is the problem and what need to be tested.
Unplug the 6 wires that goes to the LCD screen. Use a multimeter to test for resistance from each output plug on the board. The one without the resistance is the bad one.
If this doesn't locate the bad one this way, Each plug should give out DC voltage if working properly. Test each plug for voltage.
The TV will automatically turn off in a couple of seconds like before. You'll have to keep pushing the power button to test each output plug for voltage.
Soon as you find the bad Inverter Transformer, just solder in a new one and the TV should work fine after that.
The part # for the Inverter Transformer is LTZ2PC0MS008.
Here's two places to get them:
http://www.partstore.com/Part/Funai%20Corporation%20Inc/Funai/LTZ2PC0MS008.aspx
http://www.encompassparts.com/products/?LTZ2PC0MS008
Apr 23, 2009 | Televison & Video
Power button malfunction
Sounds like a faulty power supply. Consult warranty guide if its still under warranty, if not, you really need to consider calling a repair technician
Feb 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
WS 55315 Tv won't turn on-
Thanks for your help can you send photos so I can see what to look for
Dec 01, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Microlight doesn't operate as described
I KNOW HOW TO SOLVE IT. HOLD IT DOWN FOR LIKE 17~20 seconds
and after that u turn it off so everytime u press it, it will change as it suppose to work. i just solved the problem i had too :D
Oct 04, 2008 | Inova MICROLIGHT
Error number 1700 canon s9000 printer
knowing printer manufacturers I doubt they even have a sensor to detect that its full at all, they probably based on something crumby like print count. here are some instructions to reset the waste ink tank, the instructions vary so try them until one does the job :
Waste Ink Tank Reset
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice, then release all buttons
5: When the indicator lights steady, press RESUME three or four times. The indicator should be orange.
6: Press Power to set data
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
1. power off Printer
2. Push and hold resume button and push power button
3. Hold Power button and release Resume button
4. Push Resume button twice ( 2x ), and now release resume button and power button
5. Green light will blinking and stop.
6. When green light on, push resume button 4 x
7. Push Power button and printer will off, if that isn't off, push power butto again until print off position.
Aug 20, 2008 | Office Equipment & Supplies
Filter light still on "Red"
try holding ice type and child lock together for 3 seconds that worked on mine
Mar 30, 2007 | Maytag MSD2454G Side by Side Refrigerator
Sony KDL-32S3000 32 in. LCD Television Logo
710 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
