Question about HP LaserJet 2840 Printer
HP 2840 only prints half a page in any color or black and white
  • 9 more comments
  • Anonymous Nov 29, 2007
    I have the same problem too. How do you fix it?
  • Anonymous Dec 05, 2007
    I have an HP 2840, It only prints half a page black or color
  • dansayman Dec 15, 2007
    I also have the same problem. How do you fix it?
  • Anonymous Sep 08, 2008
    so how do you recalibrate; I, too , have a 2804 only printing on one half the page; I have replaced all cartridges , taken them out and reinstalled to no avail
  • Anonymous Oct 29, 2008
    same problem
  • Anonymous Nov 20, 2008
    Same this here, dam hp
  • blznscorpion Nov 24, 2008
    i have the same problem..and thats great lasersmith..gears are out of sync..that helps..not really..can u please explain how u fixed the problem?
  • Liberty08 Dec 09, 2008
    Same problem and I dont have three days time to fix this. Yes I used a recycled cartridge.
  • barbertime Jan 24, 2009
    my hp 2840 only prints on half the page
  • barry93 Feb 06, 2009
    I have the same issue!
  • Anonymous Feb 13, 2009
    My HP color Laser Jet only prints half the page
The carousel gears are out of sync - "off a tooth" and have to be realigned.  i spent 3 days last week fixing this problem - it's quite a job, to say the least.  my question - if you ever check for this answer - is: what were the circumstances when the problem first occurred?  just after replacing a toner cartridge?  if so, was it recycled cartridge?
Posted on Oct 25, 2007
smunteanu
  • 43 Answers
SOURCE: HP Laser Jet 2840
try to recalibrate the cartridge carousel. the central axel is twisted. there are more than 2 problems like this arownd...
Posted on Mar 18, 2008
leroyal
  • 2120 Answers
SOURCE: HP 2840 Prints Blank Pages
Black is used on all prints. Did you pull the tape on the new cartridge?
Posted on Jan 13, 2009
SOURCE: Replaced black toner..now printer won't print any
In this case, actually it is not the Black toner that got depleted. Here the message being displayed indicate that one of the color Toner supply need to be replaced as it got depleted and currently the printer is printing in Black and white using the Black toner cartridge.
in this case, to troubleshoot these issues please try performing the following and check for the results.
* 1. Check for the level of the toner cartridges:
a) Check from the HP Toolbox application. Here are the steps to be performed from your PC:
* Access the Toolbox software.
* Select the Status tab.
* Select the Device status option.
Here you can check for the supplies status in terms of the % remaining for each toner cartridges.
b) By checking the supplies status from the printer control panel display.
On the printer display when printer is in Ready mode the supplies status can be checked from the supplies level indicator. Each toner cartridge and the Imaging drum level will be indicated by a bar which varies according to the level of the supplies present.
c) Print the supplies status page from the printer.
* On the printer control panel menu, press Menu .
* Use the (Right Arrow) button to select Reports, and then press Enter .
* Use the (Right Arrow) button to select Supplies Status, and then press Enter .
If any of the color toner cartridges and the Imaging drum have a low supply level replace them with genuine HP print cartridges.
The part numbers of the consumables are as follows:
* Black print cartridge - Q3960A
* Cyan print cartridge - Q3971A
* Magenta print cartridge - Q3973A
* Yellow print cartridge - Q3972A
* Imaging Drum - Q3964A
Posted on Oct 23, 2009
  • 1218 Answers
SOURCE: Hp color laserjet 2840 - prints one page in color,
Follow each of these steps until the problem is resolved:
Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
Remove and then reinsert the print cartridge(s) into the printer.
Print the document.
If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
Try printing again. If the problem continues, replace the print cartridges.
http://www.fixya.com/support/t5717191-hp_deskjet_6540_printer_yellow_light
Posted on Oct 05, 2010
  • 1218 Answers
SOURCE: my hp 2840 doesnt print in color? it prints in
It seems simple enough, but this is one of the most effective ways of fixing printer cartridge error. Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached. To reattach the cartridge, turn on the lid of the printer and then remove the cartridge from the printer head. Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report. Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Posted on Oct 11, 2010
2840 laser printer only prints on right side and nothing on left side
My Color LaserJet 2840 will only print on the right side of ...
h30434.www3.hp.com > ... > Scanning / Faxing
Apr 26, 2011 - 2 posts
I have a HP Color LaserJet 2840. If I am ... My Color LaserJet 2840 will only print on the right side of the page, how can I fix this? ... If I am copying or printing from the computer, the printer will only print the right side of the page. ... something obstructing the laser scanner blocking that side of the media path.
HP 2840 printing problem ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/46992
Feb 1, 2010 - ... Apr 19, 2007 at 10:57am. 0. HP Color LaserJet 2840 ... I have the same issue as above-Not printing on the left side of pages.I went threw the ...
HP Laserjet 2840, various problems ' FixYourOwnPrinter
Dec 25, 2015 | HP LaserJet 2840 All-In-One Printer
Black stripe when printing from hp laserjet 2840
Cartridge faulty...
Two ways you can find out the faulty cartridge.
1. Remove each cartridge, just flip the drum shutter & chk for any toner bands appears on drum surface.. if found replace that cartridge..
2. Go to the paint. create four colored page as shown, print & verify which colored print mixed with bads.. replace that cartrdige.. ">
Mar 01, 2014 | HP LaserJet 2840 All-In-One Printer
Hp color laserjet 2840 - prints one page in color, next in black & white. Yellow ink cartridge light blinking. Says "replace supply, using black only". Yellow wasn't showing as low previously.
Print the document.
Jun 18, 2010 | HP LaserJet 2840 Printer
Sep 23, 2009 | HP LaserJet 2840 Printer
Jan 13, 2009 | HP LaserJet 2840 All-In-One Printer
HP 2840 All in one won't print color
printer is ok, check the connecting cable and drivers.
Oct 28, 2008 | HP LaserJet 2840 All-In-One Printer
HP Laser Jet 2840
Feb 27, 2008 | HP LaserJet 2840 Printer
HP LaserJet 2840 Printer Logo
1,159 people viewed this question
Clive
Clive
