Question about SanDisk Sansa e200 MP3 Player
Help me... I got a problem. When I Try to resolve my problem with the load main image faides, i'm just not able to do the Step 5. There is no dialogue box that I can chosse America, Japan or any others countrys... Does somebody can help me please?
  • 626 Answers
Not sure what Step 5 you are referring to. Here are the correct steps. Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Select format when prompted. Best of Luck.
Posted on Sep 09, 2007
SOURCE:
E010
IR330, step 1- this Error is the main motor fails to rotate normally, does the main motor rotate until E010 turn on? if yes go step 5, if no step 2- harness wiring connectors around the main motor normal? if no correct the wiring, if yes step 3- does the voltage of J102-B12 on the controller pcb change to 0 VDC while the main motor is rotating?, if no replace main motor ( main motor driver pcb), if yes step 4-is there 24 VDC generated between J204-3 and J204-4 on the composite power supply PCB, if no replace the composite power supply PCB, if yes step 5 is the voltage of J102-B11 on the DC controller PCB about 5 VDC during WMUP? if no replace DC controller PCB. if yes step 6- Is there continuity of the harness between the image processor PCB and DC controller PCB normal J714-A14 to J113-A7 also 714-A16 to J113-A5 if yes to if no replace the harness if yes replace the DC controller PCB and the Image processor PCB.
Nov 30, 2013 | Printer Essentials Canon Gpr-2...
Tip
Xbox help for "Can read CD but NOT DVD."
Step 1: Inspect and clean your disc Take a close look at the bottom side of your game, movie, or music disc (the side without a label or image). Are there scratches? Excessive scratches or smudges can prevent your console from reading the disc. Clean your disc 1. Hold the disc by the edges without touching the top or bottom surfaces. 2. Using a soft, clean, slightly damp cloth, lightly wipe from the center of the disc outward. Note Do not use solvents to clean the disc. 3. Once the disc is clean, load the disc into your console and see if the disc plays. If the disc still does not play, try step 2. Step 2: Try other discs Try other discs to determine whether the problem happens with any disc or only with this particular disc. If multiple game discs, DVDs, or CDs will not play: 1. Make sure the media type and the disc region code are compatible with the console. 2. If the problem happens with several discs of different types (games, DVDs, and CDs), skip to “Step 7: Request a repair” below. If a specific game disc will not play: 1. Search the Microsoft Knowledge Base to determine if the game title has any known problems. 2. Make sure the media type and the disc region code are compatible with the console. If the disc you are using has a region code that is compatible with your console but you still cannot play the disc, try step 3. Step 3: Clear your system cache If your Xbox 360 console can’t play multiple game discs, try clearing your system cache. Here’s how: 1. On the console, go to My Xbox, and then select System Settings. 2. Select Memory. 3. Highlight any storage device, and then press Y on your controller. 4. Select Clear System Cache.
Note If Clear System Cache is not available, use the button sequence described in the following article: 971755 How to clear the Xbox 360 console cache 5. Try to play a game disc. If you still can’t play a game disc, try step 4. Step 4: Remove the hard drive If the problem only happens with game discs, let’s try temporarily removing your hard drive. If your Xbox 360 console does not have a hard drive, skip to step 5. 1. Turn off your console. 2. Locate the hard drive on your console. 3. Press the release button on the hard drive and lift the hard drive from the console. 4. Turn on your console. 5. Try to play a game disc.If this step resolves the problem, reattach the hard drive and contact Xbox support to order a replacement hard drive. If this step resolves the problem, reattach the hard drive and contact Xbox support to order a replacement hard drive. If you still can’t play game discs, try step 5. Step 5: Disconnect memory units 1. Turn off your console. 2. Unplug any memory units attached to your console. 3. Turn on your console. 4. Try playing a game. If this step resolves the problem, reattach the memory units and contact Xbox support to order a replacement memory unit.
on Feb 15, 2010 | Video Game Consoles & Games
I have a Frigidaire Gallery 3.5 Cu. Ft. King Size Front Loading Washer, GLTF2940E and t dont work anymore. at start it fills some water and than stops with continius humming sound and when i do the...
it indicates a communication problem between the central main control and the motor speed control.
The two control boards are not talking to each other.
The first step to resolving this problem is to check the wire connections at each of the controls. The main control under the top panel and the speed control behind the rear panel. See the images below for help with this. Pull and push on all of the connectors.
Remember to unplug the washer first.
If all connections are tight then most likely the main control will have to be replaced.
If you do not feel confident repairing this problem yourself, then you can have it repaired at your home by a Sears technician.
Jan 10, 2011 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Some sites the scroll down speed is really slow. It seems like text pages are ok and ones with images really slows the scroll responce down. Any ideas??? Thanks!!
Sounds like you are having problems with your Internet connection speed.You could try some of these tips..
  • Step 1 Click Start > Control Panel > Network and Internet Connections.
    Select "Internet Options."
    Under Check for newer versions of stored pages, click "Automatically." Under browsing history, click "Settings."
    If you're using dial-up, set the number under Disk Space to Use to between 250 and 1024 megabytes (MB). If you're using a DSL or cable connection, set it between 50 and 75 MB. Click "OK."
  • Step 2 Select "Delete" under Browsing history.
    Click "Delete files..." under Temporary Internet Files to clear your browser cache.
    Click "Delete cookies..." to remove all cookies from your hard drive.
  • Step 3 Disable any browser add-ons you don't need. In Internet Options, click "Programs." Click "Add-ons currently loaded in Internet Explorer." Select the name of the add-on you don't want to load, and select "Disable" under Settings at the bottom of the dialogue box. Avoid deleting ActiveX controls as this will most likely cause the browser to prompt you each time you encounter content on the web, such as Flash animations, that use that control.
  • Step 4 Switch to a faster browser. While Internet Explorer is the most popular browser, it often causes pages to load slowly. Download a free browser such as Firefox, Opera or Chrome to get a quick speed boost to your browsing.
  • Step 5 Disable images in your browser. To disable images in Internet Explorer, open Internet Options and click the "Advanced" tab. Scroll down to "Multimedia" and uncheck "Show Pictures."
    To disable them in Firefox, click Tools > Options in your browser window and select "Content." Uncheck the box beside "Load images automatically."
    To disable images in Opera, open the arrow beside the camera icon at the bottom of your browser, and select "No images."
    To browse with Google Chrome without images, right click on the Chrome shortcut and place the switch "-disable-images" without quotes after the last quotation mark in the path of the file.
  • Step 6 Disable active content if you're still experiencing a problem with your browsing speed. Return to the "Advanced" tab in Internet Options. Uncheck the boxes beside "Play animations in webpages" and "Play sounds in webpages."
  • Aug 11, 2010 | Dell SP2309W 23-Inch LCD Widescreen...
    My 360 only plays cds or dvd s wont play games please advise
    Feb 15, 2010 | Microsoft Xbox 360 Console
    Sansa 260 R load main image failed message
    The Sansa e260 Rhapsody could be recovered by resetting the player.
    How to reset the player :
    1. Player switched on.
    2. Press and hold the power button for approximately 30 seconds.
    3. Put the player back on.
    When the fault is not resolved a firmware update / reinstallation needs to be made. There are 2 steps needed for getting new firmware on the player.
    Step 1: switching the player into recovery mode / MSC mode
    1. Turn off the player.
    2. Slide the Hold/Lock switch on top of the player so an orange color is showing.
    3. Press and hold the REC button and connect the device to the computer.
    4. A message will appear on the device display screen confirming the connection and a memory partition will be viewable in My Computer.
    5. Release the REC button.
    Step 2: Update the firmware ( updating firmware always in MSC mode, see Step 1 )
    Use next link for updating the firmware:
    http://kb.sandisk.com/app/answers/detail/a_id/306
    The Sansa updater installation on the computer should be the easiest way to update firmware.
    Need more help ? Just post a comment.
    Dec 17, 2009 | SanDisk Sansa e260 MP3 Player
    Camera wont turn on
    1. Step one: Reset the camera
      1. If you have an optional memory card installed, remove it. (Although removing an optional memory card is not necessary for performing the reset, it eliminates the memory card as a possible cause of the problem.)
      2. Remove all power sources (batteries and AC power) from the camera for at least 5 seconds.
      3. Reinsert the batteries and close the Battery/Memory card door and/or reconnect the HP AC power adapter to the camera.
      4. After verifying that the camera works without an optional memory card, reinsert the card, if you have one.
      Try to turn the camera on. If it now works properly, the camera experienced a temporary electrical problem and should now work properly.
      • If the issue is resolved , you do not need to continue with the rest of the instructions in this document.
      • If the is not resolved , continue with the next step.
      Step two: Check for damage or corrosion on the batteries
      1. Open the Battery/Memory card door on the camera.
      2. Remove the batteries.
      3. If the batteries are damaged or show corrosion, replace the batteries.
      Step three: Recharge the batteries
      1. Recharge the batteries or replace the batteries if they are damaged or will not charge.
      2. Try turning the camera on after the batteries are fully charged or have been replaced.
      Step four: Ensure the batteries are installed correctly
      1. Re-insert the batteries correctly into the camera by referring to the image on the Battery/Memory card door for proper battery placement.
      2. Try turning the camera on.
      Step five: Turn on the camera without the memory card
      2. Remove the batteries and optional memory card from the camera.
      3. Wait 15 seconds.
      4. Re-insert the batteries into the camera, but not the memory card.
      5. Try turning the camera on.
        • If the issue is resolved , format the memory card in the camera and then you do not need to continue with the rest of the instructions in this document.
        WARNING: Formatting the memory card in the camera will erase any images stored on the memory card. To avoid losing the images on the memory card, first save the images to a computer or another disk.
      Step six: Connect the camera to the optional AC power supply
      1. Connect the camera to the optional AC power supply. Ensure that the AC power supply is connected to a working power outlet.
      Step seven: Service the camera If the camera still will not turn on, service the camera. Cause The following conditions can cause the camera to not turn on:
      • Improperly formatted memory card - memory cards should be formatted in the camera they are going to be used in
      • Corrupt images on the memory card
      • More than 300 pictures on a memory card
      • Damaged batteries
      • Dead batteries
      • Incorrectly installed batteries
      • Damaged camera
    Jul 19, 2009 | Leica C-Lux 1 Digital Camera
    Sidekick id backlight only works
    physco2fresh
    The lcd flrex cable may be loose. Is the screen white?
    If so try this procedure to fix it.
    Repair a Sidekick with a White LCD Screen
    Jun 21, 2008 | T-Mobile Sidekick ID Cellular Phone
    SanDisk Sansa e200 MP3 Player Logo
    37 people viewed this question
    Top SanDisk Audio Players & Recorders Experts
    Joe Negus
    Joe Negus
    Ekse
     Ben
    Ben
    Level 1 Expert
    Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
