Whirlpool RBS305PDS Electric Single Oven
Problem for Whirlpool RBS305PDS Electric Single Oven
Oven has power; wont heat
By iam1irish1 on Apr 08, 2009
Whirlpool RBS305PD Electric Single Oven---where is the flush mount SPDT  thermostat how do i repair it?
Best Solution
posted on Apr 25, 2009
Very Helpful)
applguy
Rank: Master
Rating: 88%, 17 votes
It's mounted on the rear of the oven. First, turn off the circuit breaker, then the oven must be removed and the back panel taken off to access the TOD (thermal overload device). Its mounted right flat against the oven rear panel, with one large red wire attached on each end. If the TOD is open, that means the rear of the oven got too hot or the TOD failed (its a safety device). You can connect the two wires together and insulate with electrical tape, restore power and test the heaters to make sure the TOD is actually the problem. They haven't ever solved this problem...the most current answer is to replace the TOD with a new one, but bend the mounting tabs so that when the new part is installed, there is a space between the TOD and the oven sheet metal about the thickness of a dime. Then reassemble and reinstall the oven.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Whirlpool RBS305PDS Electric
Questions and Unsolved Problems for Whirlpool RBS305PDS Electric
Do you recommend Whirlpool RBS305PDS Electric Single Oven?
Answer
Answer
E2- F3 Error code, what does that mean?? Oven is locked Is a Whirlpool accubake wall oven.
Answer
My whirlpool accubake SC465 has the code"E1 F5". What does that mean?
Answer
my dimensions to my wall oven are depth 23 height 32 width 29 3/4 need to replace electric single... (More)
Describe your Ovens problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Oven Experts
Top Range & Oven Repairmen
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
(800) 555-9987
All the services you need in order to get your...
Home Blue
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
