Question about Samsung RS2630WW Side by Side Refrigerator
Samsung RS21w USA style frige freezer panel problem
Samsung RS21w USA style fridge freezer panel problem. The freezer is too cold and the fridge is showing 19 degrees. The light is working ok in the fridge but it is not getting cold. The panel is showing 'locked' and will not let me lower the temperature to make it cooler. HOW DO I UNLOCK THE PANEL SO THAT I CAN ADJUST THE TEMPERATURE? The only options on the panel are: "VACATION", FRIDGERATOR TEMPERATURE", QUICK FREEZE" & "FREEZER TEMPERATURE".
  • gobsy Jan 08, 2008
    Hello
    We have a problem with our side by side fridge freezer - Samsung SR - S 2026CVW.
    The panel on the outside door of the fridge shows
    freezer at -19
    fridge at -1. T
    The fridge light comes on but inside of the fridge is at 10 degrees and food is not keeping cold(used a thermometer) while bottom panel at the back of the
    Fridge is frozen with water leaking in to the bottom of the fridge
    How do I adjust the panel on the outside door which shows :
    vacation
    refrigerator temperature
    quick freeze
    freezer temperature.
    Hope you can help
    Joan
  • Anonymous Mar 27, 2014
    THE FRIDGE TEMPERATURE READS 25/30 DEGREES AND NOT COOLING. I CHECKED THE BACK PANEL, NO FREEZING COMPONENTS FOUND. BUT THE COOLING ELEMENTS REMAINS COLD INDICATING THAT IT IS WORKING. I CHANGE THE FAN, BUT STILL THE TEMP. REMAINS THE SAME READING.
About two weeks ago, I had what sounds like the very same problem with my RS2545 purchased this past summer at Costco. The refrigerator began freezing everything, even after setting the temp to its maximum (46F if I remember correctly). The solution was to defrost the coils on the backside of the refrigerator comartment (behind the panel as described above) which had become encased in ice! Since there are some sensors within the coil structure that were also insulated with the ice, they could no longer detect temperatures below 32F and, I believe, caused the overall temperature mechanism (for detecting overall refrigerator temperature) to malfunction. The refrigerator has been working fine since then, though now (two weeks later)the freezer seems to be running warmer than it should (maybe in an attempt to defrost itself).
A siezed fan in the refrigerator may have caused the buildup of ice on the coils in the first place, which is also a suspicion. The process of defrosting the coils may have also allowed the fan to defrost as well. What I don't want (or expect) is to have to perform this procedure eveery few months to keep the unit working properly. I now keep a closed container of water in the refrigerator in the hopes of preventing refrigerated items from freezing in the future - as did happen this time!
Posted on Jan 05, 2008
Thank you for your suggestions. Pressing the 2 lower function buttons for 5 secs did unlock the fridge. The fan did make a loud noise but this was intermittent. I've had to call out a repair specialist - it turns out that it was not the fan but the thermometer that had seized up this time round. Now that it has been replaced - everything is back to normal. In the past we have had to replace the fan - seems to be an issue with this type of fridge.
Posted on Sep 24, 2007
If the fridge has been making more noise than usual, like the sound of a plastic fan grating against something then the fan has probably seized up with ice. This will cause the fridge temperature to rise. It is located at the back of the fridge behind a plastic panel at the bottom where the water cooler pipe and bottle are. You need to partially remove this panel just enough to be able to aim a hairdryer down the back of it to defrost the fan.
Posted on Sep 20, 2007
Hold down the 2 lower buttons for 5 seconds to unlock the display panel
Samsung fridge not working freezer is?
sounds like you removed the defrost tstat.you need to replace it.if your evap coil ices up it will block the cold air flow to the frige section.replace your bad part so your defrost system willwork
Nov 27, 2012 | Samsung Refrigerators
Samsung Fridge Freezer (Freezer on top) Model SR-52NXA Freezer is cold but fridge is not cooling ?
remove evrything from bottom of freezer. take out the shelves . You will see a panel on the back of the unit with screws holding it on take these off . under it is the freezer exchange coils they got froze up,
and frosted full so now no air is circulated between the cabintes, refridge and freezer do not use any sharp object to clear it use a towel and blow dryer to thaw it even a spray bottle with warm water, but don't pick at it!!!! you can puncture the coils . take your time and you will save your unit. also while your at it pull it away from the wall remove that small panel from the back, and the grill from the front and with your long reach nozzle vacuum the heat ex changer coils under the unit. put back together carefully and it will run for a while longer i have one that is a 72 model still runs great Oh any change you find is mine!
Sep 06, 2012 | Samsung Refrigerators
The freezer works fine, but the frige side is not cold at all. the unit is still under warranty, and the service guy replaced the "control board". but that worked for about a week. Everything is...
Hello Patrickbono,
I understand that your are having a problem with your fridge it is not getting cold. However, the freezer is cooling just fine this is a common occurrence when the evaporator fan goes out in the unit. Here is a tip you can follow to help you diagnosis the problem
Fridge not getting cold?
I would suggest you call the service tech as the unit is still under warranty and have them to replace the fan and check the rest of the unit.
Thank you for choosing FixYa.com
justinbur167
May 11, 2011 | Samsung RS265LBBP Side by Side...
Frige freezer works fine but frige does not. 6 yr old kenmore 596.75509400 model
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 25, 2011 | Refrigerators
Freezer and frige not that cold
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 30, 2009 | Neff K3965XO Side by Side Refrigerator
Freezer is working good but the frige is 52
OR
Aug 17, 2009 | Refrigerators
Blowing cold air but not cold enough to keep frige cold
if one of the panels in the fridge has frost on it, the evaporator coils may be iced up. this restricts the cold air flow. to defrost: empty the fridge and freezer, turn it off, remove the panel in the freezer that has the frost, use a hairdryer and defrost the ice buildup, sop up excess water, dry it up, replace the panel, turn it on (while it's empty), set the temp halfway, and close the doors. when the compressor turns off, fill the fridge. if the panels are frostless and the coils are warm, you may be out of refrigerant from a freon leak somewhere. it might be cheaper to replace the fridge.
Jul 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer and frige dont get cold and making a noise
Hi Thanks For The Question. Is The fridge Cold.If Yes Check In Fridge For The Noise. If Not In Fridge Pull Fridge Away From Wall, Remove Back Panel Clean All Coils Thanks The Appliance Doc
Sep 12, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
SAMSUNG RS20CCMS AMERICAN STYLE FRIDGE FREEZER
in the freezer section there is a 6 screws. unscrew them and remove the back panel. there will be 2 wires attached to the panels, remember where they go. you will see a metal evaporator which will be filled with ice. this is the problem. use a hairdryer to melt the ice. this is essential as you mustn't puncture the wall of the fridge with any sharp item. before replacing the panel ensure that everything is dry or ice will reform, and also ensure that the fan blades are turning properly or cold air will not be blown into the fridge.
May 22, 2008 | Samsung 24.8 Cu. Ft. Side-by-Side...
Samsung RS2630WW Side by Side Refrigerator Logo
433 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
