Heating & Cooling Logo
Anonymous Posted on Aug 19, 2013
Handler runs fine but the outside unit, it will kick the fan on for a sec and then shuts off. It does it over and over. sounds like something isn't turning on? what's going on?
Robert Slack
Level 2:
New Friend:
  • Expert 138 Answers
  • Posted on Aug 24, 2013
Robert Slack
Expert
Level 2:
New Friend:
Answers
138
Questions
0
Helped
23561
Points
351
Sounds like a bad relay on the fan , if the compressor is trying to start and stopping that kick the fan on and off. That could be due to a low charge if the unit is not cooling properly.
If the unit is cooling properly it is probably a bad relay or contactor on the fan motor.
Other possibility is the fan motor is over heating for one reason or another and if its thermally protected it will automatically shutdown. If thats the case then you need a new motor.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
5 Related Answers
fixr1st
  • 49 Answers
  • Posted on Jun 01, 2008
SOURCE: blower fan keeps shutting on/off,
Try putting your fan in the on not auto position and see if your outdoor condensing unit cycles on and off. If it does you might have a defective time delay relay to blower. If not your contactor might be stuck or your thermostat could be defective.
Anonymous
  • Posted on Jan 12, 2009
SOURCE: axu heat and outside blower fan run all the time
I can tell you exaclty whats wrong . and it sounds like multipart problems. you have an old RUUD heat pump and its reversing vavle is stuck. without that valve opening it will contantly try to run in refrigerant mode to make heat. and here its 26 degrees, het pumps are only made to be effiient in over 34 degrees and that why your electric heaters in the blower section in an in a closit of unit
continously running up you eectric bill big time. cuses for the reversing valve to stick are sitting along time when it was low on refrigernt. or ust plain shut depending on its age. that cicking is the relay trying to open or close the reversing valve swict to make pressure again. any local guy an fix that one. theyre are kits called hard start kits that they hook up to them that shoot an extra zap of jiuse in it to try to free it up if its not totally lockd up being though that you still hear the relays pulling in and out thats good you may have just caught it in time.
now here is a quick test and possible cure but only if you what your doing turn both units off take off the top cover of the old rudd and get a small hammer not a sledgehammer and rap and tap all around the reversing valve. it will be a cylindrical tube black usually have sets of copper or brass tubings going in the 2 sides of this so dont hit itthat hard it gets dents it and is ruined. look for oil spots which uually means the refrigerant leaked out , and its seized up for good. they try spinning around the big out door fan door fan some. you may have to rock it back and forth Till it braks lose but dont put super human efort int it,
than put it all bak together making sure you connected wires back up right. go in and have you wife eithe watch it or you do it and switch the breker on and off about 8 times to trying to get the cnnectors switches to stay in and if your brave take a well insulated screw driver and hold them in for 2-4 miuntes to force it to work. if that doesnt do it call your local repairman and tell him you need a hard startkit only much safer, the cost about 40$ but you labor will be high if he is sent alone so may you can help im out and lessen your bill if the valve cant be made to work again. you may want start looking for prices with that model and serial number and d shut that electric heater off some one to replace it . I hope I helped you out some no charge ( I dont have my Pay Pal acct. set up yet ) good luck tom.
pierre1811
Perry Putnam
  • 144 Answers
  • Posted on Jan 22, 2009
SOURCE: Heat pump is humming loud>
When the heat is not on. Go to the T-stat and turn the fan to the on position. With the blower now running is it making the noise? If so you probably either have something in there such as the filter that was mentioned, a piece of paper etc. or one or more of the blades on the blower wheel is vibrating. Don't let the condition persist w/o having it checked out or you may turn a simple fix into a costly one.
Anonymous
  • 478 Answers
  • Posted on Mar 12, 2009
SOURCE: Amana 1 ton Residential AC / Outside unit comes on for a sec
open the service panel to check for control voltage of 24volts when tstat calling, The contactor should be pulled in, if contactor is down,and contacts appear to be clean, and the unit is still not running, it is a bad compressor. to test this unplug the black wire from the compressoror at contactor,w/ power off! Turn on power if fan works normally it's a bad compressor. However if you see a swollen split cap(5 wires to a soup can looking w/ the terminal C,F,and Comp), switch it first and start at square one.
You also need to consider the high pressure switch if its cycling on off on off.
Anonymous
  • 46 Answers
  • Posted on May 25, 2009
SOURCE: OUTSIDE UNIT OPERATES BUT FAN DOESN'T TURN AND UNIT DOESN'T COOL.
the motor could just be locked in place from sitting...take a stick or something and try to see if it spins be sure of rotation! you can also give it a little nudge while it is on and it will take off! if this happens then you have a bad start compacitor but no there are no fuses that only protect the motor!
I have an older trane twe030c140b0air handler and it was workingq fine then today froze. Fan in unit will not run. Sparks from conteoller. Is that the correct name? Unit is 208 thanks
Turn power off to air handler. Jump red and green inside the machine. Turn power on. If fan runs then the problem is likely outside of the machine, that being tstat or tstat wire.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
My air handler fan does not come on, the outside unit turns on fine. Is their a way to reset the fan?
Check for fan operation by turning the fan control at the thermostat to "on". If the fan blows, it works. If not, check a circuit breaker or fuse.
If the fan blows when forcing it on with the thermostat but not in automatic, check the fan control circuit in the air handler. Danger: high voltage, beware! There should be a system wiring diagram inside the air handler somewhere.
Replaced capacitor on fan in air handler now condenser will not run and fan on air handler will not shut off
fan relay stuck in & control fuse might be blown. see if you have 24 volts at outside unit.
My Armstrong Concept 1200 stopped working yesterday (model EFC14MAA-1A, Serial # 6099F44101, 42000 BTUs). All breakers are OK. On the outside compressor unit, I can depress the relay and the fan and...
sounds like your problem is in the air handler. Sounds like the fan is not kicking on in the air handler this could be the board or the cap or fan motor you can run a micro farad test on the cap that goes to your evap motor be sure you take the leads off the cap and the mf are written on the cap itself. does the outside suction line which is the big line starting to freeze up? you can check your motor winding by running an ohms test across the motor winding. You do this by reading on the motor which wires goes to your start and run windings. You should get and ohms reading and if they are bad you will get infinity.
1helpful
Why does my fan runs continus. and the condenser won't run out side.
The fan runs continously because your condensor is not kicking on and removing the heat. The thermostat needs to come under the set temp. to kick off the fan. If your compressor doesn't run and the fan on the outside unit does run, your compressor has an issue. If nothing runs outside, then your transformer on the inside unit(air handler) has an issue. This could also be a control relay on the condenser or the air handler.
1helpful
2answers
I noticed some straining noise coming from my a/c unit today. The fan on top of the condenser runs fine but as soon as the compressor tries to kick on the fan stops for a split second and you get a kind of...
You amy ahave a bvad capacitor on the outside unit. It starts the fan and the compressor. You can change this yourself. Open the outside panel and you will see a silver canister with terminals out the top. Replace this and I think your problem will go away. On the cap. it will say something like 30uf 5uf 370 ot 440 Just get these numbers and get a new one. Russ
Burning smell and icing
Sounds like your blower motor in your furnace or air handler has burned up. shut the unit down and replace the motor. make sure the ice is melted and the unit is dry before you turn it back on.
Top Goodman Heating & Cooling Experts
Paul Carew
Mike Cairns
Mike Cairns
Jay Finke
Jay Finke
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
