Question about Epson Stylus Photo R200 InkJet Printer
Red lines keep printing through all text of my print-outs. I've tried everything suggested in the manual such as cleaning and alignment an I still get red lines wherever there is text.
There is a spong that catches the ink when doing a head clean. I took some Q tips t soak up some of the ink from within the spong. Try to clean as much as you can from the spong. Even use a soft rag iif possible. You also may have to change the brand of ink that is being used.
Posted on Sep 06, 2007
Lines on colored prints
Hi Jam Jam, Try changing the Print Quality from Text to higher print quality.
May 12, 2014 | Brother MFC Office Equipment & Supplies
Doesn't sound like your printer hardware. Try printing something other than your text document. If the page comes out clean/perfect then it means your printer is having a problem understanding your text document via print program translation. Otherwise try converting your text to pdf and print a sample page, if it works then again problem with software/printer translation.
Nov 24, 2013 | Epson Stylus CX3810 All-In-One InkJet...
Red prints as Orange
If this is magenta being weak (light) on all the things you print (try doing a test pritn, and a configuration page from the printers own menu system). this will be the dirty laser lens/mirrors problem that is very common with this printer.
Solution is either
Dismantle (it IS quite a lot of work, but fairly straightforward methodical screwdriver work) the printer to remove the laser unit. Take cover off the laser unit and CAREFULLY clean the lenses and mirrors. NOTE take care not to disturb the alignment of any part of the laser optics, and be especially careful with the mirrors as they are surface silvered and V easily scratched.
You can find NEW laser units on a certain internet auction site, and also (genuinely) refurbished exchange printers. Both of these two opttions will obviously save time and effort, but be more expensive.
Jan 20, 2010 | HP LaserJet 2605DTN Color Printer
Printer Epson DX6000 ... all new cartridges .... will not print any text. I can print the head clean test page as well as the head alignment page ... but no text
You said all new cartridges.. But are they Epson Genuine Cartridges???? I had the same problem when I replaced with new, but generic cartridges.
After finally, going thru 2 sets of each, removed them and put in Genuine., and finally, everthing started printing fine. Weird , but true.
I suggested my answer problem below.
Good Luck :0)
Problem for Epson Stylus C84 InkJet Printer
Re: C84 I'm using generic ink, but the red
By mclamemo on Nov 12, 2009 re: C84 I'm using generic ink, but the red doesn't work at all. I've done all the printer cleaning programs and swabbed inside the printer with alcohol, and re-inserted the cartridge multiple times. it still doesn't print at all.
Also now even the black every few lines prints the top half of the line or the bottom half of the line, or its smeared, etc...
Best Solution
posted on Nov 12, 2009
cns assoc
Rank: Wiz Expert
Rating: 84%, 22 votes
I have learned from experience, that Epson does not like generic ink. You must use Epson Genuine Cartridges. Hopefully, you haven't screwed up the printer, like I did. I did try cleaning the heads and doing everything possible. Use 2 cartridges of ech set, for cleaning, cleaning, cleaning. ......But Nothing.
Had to go out and purchase a new printer.;
Good Luck :0(
Asker's Testimonial
" Thank you. Called Epson also and they didn't say it as directly, but advised real Epson ink too. Hope I didn't kill the printer! Generic ink for sale " - mclamemo
Nov 12, 2009
- Funny. hahahahah,
Me too! I would say, about 2 dozen cartridges to be exact.
lol :0) :0) :0
Nov 15, 2009 | Epson Stylus C86 InkJet Printer
I have tried everything from head cleaning, nozzle checks, print head alignments to changing the printing setups to everything and anything I can think to help but no matter what I do, my pages keep...
I had the same problem. What you need to do is manually clean it. Take the ink cartridges out and clean the bottom of the ink loading bay with a Q-tip. Than, inside the printer, there is a black sponge that lines the area below the printing heads, take it out (gently). Clean it with water over a sink by squeezing it, but be gentle. A lot of ink should come out of the sponge. Once it is thoroughly cleaned, let it dry (I used a hairdryer than let it air dry for a little bit). Reinsert the sponge (make sure it is dry!) and ink cartridges. Do one head cleaning on the computer and now it should print like new.
Jul 16, 2009 | Epson Stylus CX3810 All-In-One InkJet...
Poor printing quality on text
so, what sort of text is it you are attempting to print? what program is in use?
Aug 15, 2008 | Dell A940 All-In-One InkJet Printer
Stripes on Images only - Text OK
Perhaps the CMY color heads need alignment. If you have not already done so, run a head alignment from the driver maintenance section. It will print out a page containing several lines and text, and request you select the closest-aligned images. After this is done, do another image print to check for improvements.
Normally, the printer uses the black cartridge for text and the CMY inks for images (even for black on photo and specialty paper). So when you are printing normal text pages on plain paper, only the black ink is used. A good check for this would be to print a normal text page, but select photo paper in the driver to trick the printer into using the CMY inks to make a substitute black text page. If this looks ok, then you are having issues other than cartridge alignment.
May 24, 2008 | Canon BubbleJet i560 InkJet Printer
Multiple Problems Printing
Replace the print head, and all should be just fine.
Jan 06, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Epson Stylus Photo R200 InkJet Printer Logo
120 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
