Question about Nokia 6600
Nokia 6600 hello can you help my screen has gone blank and yet the phone is still working.i have,nt dropped it or anything just went blank all of a sudden.i have not tried anything as i cannot see anything.
  • Quit Nov 08, 2007
    yes i have a same problem. My screen has gone blank and yet the phone is still working.i have,nt dropped it or anything just went blank all of a sudden.i have not tried anything as i cannot see anything.
    Note: When i start the phone he lukes fine, but then a few minutes later..caput....
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 128 Answers
Maybe the lcd connector was off.takoff the front cover and screws and try to conect it again
Posted on Sep 12, 2007
SOURCE:
I dropped my nokia xpressMusic 5800 on the flor
Hi, first remove the battery and see what happens next. If the screen is still blank?, During the fall of the phone,the screen might have shifted and is not making the phone to display.
Loosen the phone and readjust it , it will come on again.
But if when readjusted still the same, that means due to the fall the screen will need to be replaced with another one.
Good luck.
Jun 08, 2010 | Nokia 5800 XpressMusic Smartphone
Tip
Format your nokia 6600 mobile phone....
A. Blank screen phone unable to boot-up. B. Phone is only able to boot-up to “Nokia” screen (may flash “Nokia” 4 times also).
C. Install a program but unable to uninstall it.
D. Unable to delete certain files on C drive.
WARNING: This will ERASE EVERYTHING on your phone
If you have any files that are important to you, make backups.
1. Make sure you phone is fully charged.
2. Backup your contacts list and personal files to MMC memory card (if possible).
3. Switch-off your 6600 phone.
4. Press and hold these three keys together
-Green dial key,
-Star key (*)
-Three key (3)
then press the power on/off to swtich on the 6600 phone.
DO NOT let go the three keys until you see the “formatting” screen displayed
5. After a few minutes, the format will be complete. Your 6600 will now be at its original factory settings.
Disclaimer: I will not be held responsible for anything that happens to your phone as a result of following my guide. Use this guide at your own discretion and risk.
on Apr 26, 2008 | Nokia N70 Cellular Phone
Nokia 6600 white screen problem
hello,the screen is faulty from the problem you posted above,this can equally be fixed.all you need to do is to get another screen to replace the faulty one.
I will suggest you take it to a mobile phone engineer to help you fix it,and this will make your screen come back to normal as it was.
Take care.
Apr 10, 2010 | Nokia 6600
How to Format your nokia 6600 mobile phone....
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}A. Blank screen phone unable to boot-up. B. Phone is only able to boot-up to “Nokia”screen (may flash “Nokia” 4 times also).
D. Unable to delete certain files on C drive. WARNING: Thiswill ERASE EVERYTHING on your phone
If you have any files that are important to you, makebackups.
2. Backup your contacts list and personal files to MMCmemory card (if possible).
-Green dial key,
-Star key (*)
-Three key (3)
DO NOT let go the three keys until you see the “formatting”screen displayed
5. After a few minutes, the format will be complete. Your6600 will now be at its original factory settings.Disclaimer: I will not beheld responsible for anything that happens to your phone as a result offollowing my guide. Use this guide at your own discretion and risk.
Feb 12, 2009 | Nokia 6600
Blank white screen
It seems to be ur lcd stops working..Take this to service center...
Nov 29, 2008 | Samsung J700 Cellular Phone
Fon screen faded and went off itself
dnt use local memory cards.its the 100% virus problem..first u hv to format ur memory card and then format ur mobile with jaf .dnt use bluetooth to receive data from other mobiles.reply post
Sep 27, 2008 | Nokia N70 Cellular Phone
I dont know what is happening, nothing happened to my phone to my knowledge, it just went to a white screen. on the white screen it says --download started-- blank then it says, emergency @ usb, then at...
buy a new phone and try real hard nt to drop it the a920 tends to pack up when dropped as it happened to my last a920 and even telecom went to repair it but it was going to cost more than the price of a replacement a920
Sep 17, 2008 | Samsung MM-A920 Cellular Phone
Nokia 6300 - blank screen
6300 hand set's blutooth not working pls send asolution
Sep 08, 2008 | Nokia 6300 Cellular Phone
LCD screen went blank
to fix this problem is usualy simple, 90% of the time if you have a blank screen it is because the screen has come unplugged, open the casing of the phone and just plug the screen back into the circuit borad this should solve ur problem, please note this does not work if you have full white screen. hope this helps people with this problem.
Jul 28, 2008 | Nokia 3230
Nokia 6600 Cellular Phone Problem
-Green dial key,
-Star key (*)
-Three key (3)
Low feed backs hurt my ratings and I tried my best to help you with your problem,Show your Appreciation by rating it:
email [email protected]
May 10, 2008 | Nokia 6600
Nokia 6600 Logo
107 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
