Fist click the start menu
and click the printer and fax
and select the hp printer and rith cilck the proparties and seat the print colar coular that time
select only black...............ok
Unfortunately, the printer does not actually measure the ink in the carts, but measures how many droplets called for. The carts may actually be full, but the printer now thinks they're empty. Most likely the black ink needs to be "charged" because you've cleaned out the pipe. I don't know what to do to charge it, and you'll likely need new carts.
The draw back of inkjet technology printers are, if it is not using quite long period of time,cartridge nozzles will dry up, result printer will act just like a printing some thing but nothing will come on paper(blank page) even ink levels are showing full. Try to recover the both cartridges through 'clean print cartridge' process from the system,if not better consult cartridge re-filler to clean the nozzles..Replace new cartridges if above said methods are not worked out.
Check
the display for an error message. If the display reads "Clearing paper
from printer," the engine has detected a jam and is attempting to eject
the jammed pages automatically. These pages will often be blank.
Check
the display for "Performing PRINT/STOP TEST" or "Performing SERVICE
TEST." Either of these messages indicates that the printer is going
through a test procedure that may eject blank pages.
Reduce
the amount of paper in the input tray if the printer is feeding
multiple blank sheets at a time. The printer will pull extra pages
through if the input tray is overfilled.
Replace
the paper in the input tray with the correct size if needed. If the
4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
Replace
the ink cartridges if certain colors are blank on the page. Replace the
black cartridge if printing a black text document that is coming out
blank. The printer may attempt to print even if the ink level is low or
empty, but will unable to print anything on the page, causing it to
come out blank.
Remove
the sealing tape from newly installed cartridges. The tape covers the
print heads and should be removed before installing the cartridges. If
the tape is left on, it will prevent ink from getting on the pages as
they print.
Press
the "Check mark" button on the control panel to enter the printer menu.
Run a diagnostic so the printer can attempt to determine the cause of
the blank pages printing. Press the up or down arrow to select
"Diagnostics." Press the "Check mark" button. Press the "Down" arrow to
highlight "PQ Troubleshooting." Press the "Check mark" button. The
printer runs a diagnostic and returns to a ready state when done.
Calibrate your new blank ink cartridge, have some nozzle check, cleaning check, and printer alignment. This are procedure that new ink cartridge will have to calibrate before you use. Epson printer are very sensitive when capable of changing ink cartridge. Unlink HP directly work without any print test because the cartridge head and ink join together, Epson with ink cartridge and the head separate. Have some test on it at Printer Maintenance. I'm sure 100% works on it. Good luck!
Using HP Director, you should be able to check estimated ink levels by selecting Settings -> Print Settings -> Printer Toolbox and then clicking on the Estimated Ink Levels tab.
If the ink levels appear to be sufficient, on the printer control panel press Setup, 1, 4. This will generate a self-test report. If there is streaking of any of the 4 bars at the bottom of the page, the affected cartridge may need to be cleaned. If any of the bars are missing, the cartridge needs to be replaced.
To clean the cartridges, press Setup, 5, 1. This will print a page of patterns.
Try checking the ink cartridges and make sure they have ink in them or it will keep printing blank pages. Then try printing a test page by going to control panel, clicking on printers and faxes and right clicking on your printer and going to properties. Then go all the way down to the bottom of the page and click print test page. It will clean the printer cartridges and align them to print correctly. It should work after that.
thank you but selecting black didn't work either. Any other ideas?
new cartridges--aligned--printing blank pages--opened printer icon--showed cartridges both full--still printing blank pages.
