Question about Soltek SL-85DRC Motherboard
No power up.
I recently bought a PC that was working fine, on moving it to a new location it did not power up. On inspection the power leads from the switch are off the motherboard. The loose wires are labelled. Power, Power LED, Reset SW and HDD LED. Need to know the correct pattern for refitting theses cables if you could many thanks. Frontman
  • Anonymous Mar 01, 2009
    I have a Soltek SL-85SID but he start not up what can I do?
  • 2,961 Answers
Although a different model it probably will be the same setup, see page 16
Posted on Sep 06, 2007
Mtx surround sound sub is on but no sound or thump.
most electronics now days only last for about five to seven years
so I would get checked out by a technician.
Jan 27, 2014 | MTX Audio Players & Recorders
Black screen death
non working ram leads to no boot at all or crashes. if ur laptop able to boot but unable to detect the built in monitor while at the same time detects external monitor just fine then the problem probably lies on the built in monitor itself or probably some lose cable between the mainboard and the monitor. i can assure u the GPU is working fine. if u can locate the RAM, it doesn't hurt to check them out tho. try reverting to stock ram by removing the newly installed ones and see.
Aug 10, 2013 | Lenovo ThinkPad Computers & Internet
Dell dimesion wont turn on at all
So it doesn't power up at all? I'm only asking because you said it's not the connection.
If it doesn't power up, open the box and reseat everything, something may have come loose during the move.
Sep 21, 2012 | Dell Dimension 2400 PC Desktop
Hello, I have an acer aspire 5741 which i bought 5 months back. The problem started a week back and has got worse. It is when i plug the cord for charging on laptop, the blue light on power button and...
it needs a new a\c power block inside they are cheap and semi difficult to repair i wouldnt think it would be over 100$ max but it isnt in my lap to inspect so this is my opinion ok
Dec 21, 2010 | Acer Aspire One PC Notebook
When I power up computer, I get 2 very rapid beeps, pause, 6 beep
it depends on the beeping
but i guess it's ur graphic card
make sure that the card is firmly in place and also check the memory modules.
Sep 14, 2009 | Sony VAIO RB30C (VGCRB30) PC Desktop
Samsung hd tv will not turn on red led light blinks
Just wanted to confirm the solution (or atleast solution to MY problem).
Thank You to those who posted the solution to this problem.
I have a Samsung 52" HD LCD TV. I bought it 1 1/2 yrs ago and recently had been experiencing this problem of continual clicking and no video upon power up.
It would take approximately 3 - 5 minutes before eventually turning on. I noticed that prior to turning on, the clicking would get faster and the blue light at the base of stand would begin to get brighter.
So, based on the suggestions here, I opened up the back of the TV and located the Power Supply. I visually inspected the capacitors and in fact, found 2 of them that had a subtle but obvious bubble or protrusion on the top -vs- flat tops, like the majority of the caps.
These caps were 2200microfared, 10V rating. I went to my local Radio Shack and bought a higher rated version of the 2200 microfared caps (35V). I Replaced the old caps with these new ones and it solved my problem. :)
There were a couple of caveats though:
1) the higher rated caps were physically larger & had axial leads vs radial leads.
2) The leads of the larger caps were just thick enough to prevent them from being inserted in the board.
3) Rather then make the holes of the board bigger and risk destroying the solder pad, I used appropriate sized leads from some resistors that I had as extensions and soldered the new capactiors to the extensions. Of course you need to be aware of polarity and assure that the leads will not come in contact with each other or anything else on the board.
4) Capacitor Radio Shack p/n: 272-1020. Total cost of both was less then $10.
Hope this is helpful. I did take some pics of the capacitor location and board location. If anyone would be interested in the pics, you can email me @""
Sep 03, 2009 | Televison & Video
Dell Inspiron 6400 charger not always working
u r very correect its the time for new 1 to be bought. u can get the new 1 from radio shack websites. and also dont try to use that faulty charger again as it can possibly blow the laptop electrical parts internally due to any over power short circuit.
Jan 04, 2009 | Dell Inspiron 6400 Notebook
Garmin quest won't swith on.
The Quest charges on about 5 volts you have to plug the cigarette adapter into a 12 volt souce, the adapter then converts it to 5 volts. If you splice 12 volts directly into the mount the quest will not work because you burn up the circuits or the battery.
Sep 11, 2008 | Garmin Quest GPS Receiver
Does the power supply have its own power switch?
It is located next to where the power wire plugs into the back of the PC.
Jan 10, 2008 | E-Machines eMachines Desktop PC
Dell Latitude CPi has no power and lights will not come on when connected.
If you bought a new battery and connect the powercable and still nothing happens it's usually a problem with a fuse. If not a fuse it's usually the cpu. If the problem is with the vga the lights usually turn on. Difficult problem. This depends on how fare you want to go and able to spent.
good luck
Nov 28, 2007 | Dell Latitude C610 Notebook
Soltek SL-85DRC Motherboard Logo
166 people viewed this question
Top Soltek Computers & Internet Experts
John Anderson
John Anderson
Steven Wander
Steven Wander
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Soltek Computer and Internet Expert? Answer questions, earn points and help others
