Question about Philips HTS3440/37 System
Philips HTS3440/37 sound shuts off. If I press mute button it goes to mute,press mute again sound will come back on. What can I do to solve this?
  • dwarner151 Sep 07, 2007
    The sound shuts off on its own. To getit to come back on I must shut off the power and turn it back on, or I can press the mute button once to set the unit in mute mode, then press the mute button again and the sound will come back on.
  • dwarner151 Sep 08, 2007
    The sound shuts off on its own,a lot. tring to watch a movie or show is a pain in the ---. To get it to come back on I must shut off the power and turn it back on, or press the mute button once to set the unit in mute mode, then press the mute button again and the sound will come back on for a unknown time.
  • 59 Answers
I agree with guide...it sounds like your getting electrical feedback current from the speakers causing the system to shutoff. try just one speaker or alternate speakers...there is something called impedance that you should check into as well. too low of impedence can cause amp failure/shutoff. e.g. connecting surround sound speaker up incorrectly can easily cause an impedence problem.
Posted on Sep 10, 2007
    Master:
    Sergeant:
  • 461 Answers
Please elobrate further your problem.. i'm a bit confuse " If I press mute button it goes to mute,press mute again sound will come back on" This is normal.i.e. that is the function of mute button.
Posted on Sep 07, 2007
  • SS s
    SS s Sep 08, 2007
    check speaker connection and setting, make sure audio cable are connected properly and correct source are selected.
    Please ensure you follow the procedure in the manual page 13 to 19.
HOW DO I TURN ON THE AUTO MUTE ON A COBRA ESD 8285
When changing the Settings on your detector, please keep in mind: Each time the unit is turned On the factory settings of Highway and Auto Mute-On will be set. They can be changed while the unit is in use as described in the following sections.
Assistance Muting An Alert
Your detector allows you to quickly turn Off an audio Alert by momentarily pressing the Mute button. If you press the Mute button a second time during the Alert, the audio Alert will be turned back On.
Auto Mute Mode Auto Mute will automatically reduce the audio volume of all alerts after four (4) seconds for as long as the signal is detected. The factory setting for Auto Mute is On.
Highway/City Mode Setting your detector to City mode delays all X band audio alerts at lower signal strength levels. (A single beep will sound when the signal is first Notice detected.) This will reduce false alerts while you are driving in, or near, urban areas where there are many sources for conflicting X band signals such as microwave towers and automatic door openers. To change settings, follow the procedure listed below, which indicates what you will see and hear as you complete each step. The factory setting is Highway mode.
Highway Mode City Mode
Mute Button Press and release
To Turn Auto Mute Off X Ka L S
City Button Press and release
Press and release the Mute button while no alert is occurring.
Jan 27, 2016 | ESD-8285 Radar Detector
Why can't I turn off the mute function?
Usually, mute is turned on and off at the remote. Press once to mute, press again to turn sound back on.
Sep 29, 2015 | Sony Audio Players & Recorders
I have a Clarion XMD3 am/fm marine cd player that came with my 2000 Searay boat. I was somehow able to turn the inside cabin speakers off last season and only have the outside speakers on. I must have...
Might be set on mute !
Mute instructions
Use this function to turn off the sound immediately.
1. Press the [ M ] button.
The sound turns off and "MUTE" appears in the display.
2. Press the [ M ] button again to cancel the mute mode
in this other user manual it is a mute button[m] page 4
http://www.clarion.com/us/en/MungoBlobs/552/388/XMD3.pdf
or
Adjusting the fader
1. Press the [ A-M ] button and select "FAD 0".
2. Press the [ w ] button emphasizes the sound from the front
speaker, press the [ z ] button emphasizes the sound from the
rear speaker.
? The factory default setting is "FAD 0". (Adjustment range: F12 to
R12)
3. When the adjustment is complete, press the [ A-M ] button
several times until the function mode is reached
May 04, 2017 | Clarion XMD3-RET AM/FM MARINE CD PLAYER
I have a magnavox projection tv...picture /no sound
I put new batteries in the remote and reset the cable box.
Mar 27, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Philips RC4318 Remote Issue
SOLVED!!!! Make hard reset of the remote control:
1. Five seconds Mute & Menu buttons 2. Press Select untill four lights comes up, exept TV 3. Press OK That's it! Get your remote control as a new :)
Sep 14, 2008 | Philips 50PF9630A 50 in. Plasma Television
Sound problem on TV monitor L 2010
What are you using to connect to the monitor? Have you tried replacing the cable, sometimes cheaper HDMI cables can cause this issue
I’m happy to help further over the phone at https://www.6ya.com/expert/joshua_ac64e182ed26f66d
Feb 07, 2018 | LG L2010B (Grey) (Gray) 20.1" LCD Monitor
Close caption turns on and off by itself problem
Check the cable box to make sure the captions aren't truned on in the cable box.
If not -if it really is the Magnavox caption service- then -
This is assuming you have the original remote:
1 Press MENU to show the on-screen
menu.
2 Press VOL+ or VOL- until SET is highlighted.
3 Press CH+ or CH- repeatedly to
highlight CLOSED CAPTION.
4 Press VOL+ or VOL-
to display the
CLOSED CAPTION menu.
5 Press CH+ or CH- to select the
closed caption you want (OFF, CC-1,
CC-2, or CC-MUTE).
CC-MUTE sets
the TV to show closed captions when
you press MUTE. The TV volume will be
disabled until you press MUTE again to
restore the sound.
6 Press VOL+ or VOL-
to confirm your
selection.
7 Press TV/AV/EXIT to remove the
menu.
Feb 25, 2008 | Philips Magnavox 27MS343S 27" TV
Volume and mute buttons suddenly stopped working
Try changing the batteries. Most times the "tivo" buttons will work but the "tv" buttons will stop working when the batteries are low.
If you have done that, go back into settings and program the remote again for your tv, then give it a shot.
Nov 05, 2007 | Tivo DirectTV Remote Remote Control
Tv has an advertisement that wont go off
Press the up and down volume buttons on the TV at the same time. This will turn off demo mode.
Aug 29, 2007 | Philips Magnavox 27MS343S 27" TV
Philips HTS3440/37 System Logo
229 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
