-   When I try to print copies of emails on my hP Lazerjet 2050N (2020 series) the prints comeout with text 5" down the page, with horizontal and vertical lines boxing this in, and blank for the rest of the page, cutting out the major part of the email. Can someone tell me why this is, and how to correct it to gat the full page of the copy email please?-   rene_schuste
Hi rene_schuste: This info may help you with your problem.
If you used an older or different HP LaserJet printer driver (printer software) to create the document,
or if the printer Properties settings in the software are different, the page format might change when
you try to print using your new printer driver or settings. To help eliminate this problem, try the
following remedies:
● Create documents and print them using the same printer driver (printer software) and printer
Properties settings regardless of which HP LaserJet printer you use to print them.
● Change the resolution, paper size, font settings, and other settings.
Graphics quality
The graphics settings might be unsuitable for your print job. Check the graphic settings, such as
resolution, in the printer Properties and adjust them as necessary.
Have color and contract problems with my Mitsubishi 9550, all prints come out with a heavy yellow...
(More)
Have color and contract problems with my Mitsubishi 9550, all prints come out with a heavy yellow cast and very contrasty. I have set software to printer determines color to Photoshop determines color and have adjusted fine adjustments and nothing seems to correct the problem. I also check on my color profile and it is the only one Mitsubishi has for this printer. Suggestion??
Please do not respond if you have NEVER used a UP-DR100... because this is not as simple as...
(More)
Please do not respond if you have NEVER used a UP-DR100... because this is not as simple as downloading a driver Just recently, I had to have my laptop wiped out due to a virus, when I did that I had to reinstall everything. Unfortunately, I do not remember all the steps involved with the UP-DR100. Does anyone know where I can go to find step-by-step instructions for this printer? This is not a simple plug and play kind of a deal, and with everything I thought I remembered, I'm still getting "Target not found". Any advise from a UP-DR100 veteran will be appreciated.
printing so that the page gets cut off on the left hand side and there is an inch blank on the right...
(More)
printing so that the page gets cut off on the left hand side and there is an inch blank on the right hand side(landscape)
