Question about iRiver H10 MP3 Player
Iriver h10 WHEN I TURN IT ON IT SAYS SYSTEM FILES MISSING, TO RESTORE CONNECT H10 TO RECOVERY TOOL, PROBLEM IS IT DOESNT CONNECT ANY MORE TO ANY COMPUTER, EVEN WITH EMERGENCY CONNECTION!
  • 8,596 Answers
Get recovery tool from iRiver website
Posted on Jun 26, 2008
4 Suggested Answers
SOURCE: iriver (h10)
either find rockbox or iriver plus and do a firmware upgrade
Posted on Nov 19, 2007
SOURCE: my iriver is saying 'system
Hi
My iriver is working again, no joke, i got it to work by hitting it off the wall! it broke when it fell on the floor so i just hit it off the wall after trying everything else.
thanks
O
Posted on Nov 09, 2008
ipodslinger
  • 688 Answers
SOURCE: My device says System files missing to restore
Here is the iRiver website download page for your device. You should be able to get what you need to restore your device.
http://www.iriver.com/index.asp?code=0302
Good Luck
Posted on Jun 05, 2009
It says files missing need h10 recovery tool
When the H10 comes up with the information "files missing", system files are missing on the player for proper functionality.
The recovery tool must be run to restore the player's functions.
When not having the tool available on disk it can be downloaded from
the iRiver site, starting here:
http://www.iriver.com/flash/index.asp?code=0302
In the second column next to GO, enter the word recovery in the bar.
Click on the upgrader, to see how to perform the recovery for the MTP version of this type of player.
MTP version indicates that the firmware on the player is suited for transferring media using Windows Media Player 10 or 11.
The version depends also on the region, the player has been sold. More info for checking the MTP or MSC version, see:
http://www.iriver.com/flash/popup/flash_pop.asp?board=faq&code=365
Need more help ? Just post a comment.
Dec 16, 2009 | iRiver H10 MP3 Player
IRIVER WONT WORK AAAAHHH HELP!!!!!? my iriver wont work when i try to turn it on it comes up and says system files missing to restore the system files, connect to iriver plus wat dose that mean i have...
When system files are missing on the player, you will need to reinstall the FIRMWARE.
When looking online for the connection type for the H10 / H10JR, I can see 2 CONNECTION TYPES for the H10 / H10JR:
1. MTP, when using Windows Media Player 11 ( WMP11 ), for the H10.
2. iRiver Plus, when using iRiver PLUS, for the H10JR.
The connection type determines what software on the computer will be used for transferring media.
Each software on the computer needs corresponding firmware on the player to be installed.
When the player itself comes up with the information to connect to iRiver PLUS, this is the correct software for this device probably. Then the device is a H10JR.
When not having the program iRiver PLUS, go to the iRiver support site, for the download:
In the left column click Plus3 and go for the download.
Run iriver plus 3 and then select [Tools > Portable Device > Firmware Upgrade] from the menu.
In case you have the other model player, the H10, let me know if you need assistance for its recovery.
Dec 15, 2009 | iRiver H10 MP3 Player
Restore the system files, connect H10 to recovery tool
The procedure depends on what version you have.
Below there is the procedure for 20 GB , on other models procedure is the same, but you must find the right download for your model.
For 20 GB :
TO RESTORE "SYSTEM FILES MISSING" LOCKED PLAYER
--- This applies ONLY to the 20 gig version of the H10! ---
--- This procedure formats your H10 so all data will be erased on the player! ---
1. Power off H10 - 20gig unit.
2. Insert staple or other small object into reset hole to press reset button.
3. Connect player to USB cable.
3. Hold down Select key (labeled "O" - right button on front of player) while also holding down power key until player boots.
4. Unit must display "Emergency Connection."
5. Unit will now appear as a drive under My Computer. Right click on drive, select Format. No need to change anything, just proceed.
6. Download H10_20GB_System.exe. It is a self-extracting archive. Double click on it and unzip to c:\iriver.
http://www.iriveramerica.com/downloa...0GB_System.exe
7. Locate iriver directory, double click. You will see H10. Double click once again; you will see System.
8. Right click on system, select "Send to" and choose the directory of the player.
from System Files Missing
If you have the 5 or 6 GB see iriver - H10 5/6 GB Series Support
Feb 24, 2009 | iRiver H10 MP3 Player
Iriver h 10 mp3
OK, one day i turned on mu iriver and it's say's "system file missing to restore the system files connect to H10 to iriver and i dont know how to connect it.The other proplem when playing the music it's like a scratch CD i dont know how to fix it.
Sep 25, 2008 | iRiver H10 MP3 Player
Iriver, H10 , system files missing
iRiver H10 - Missing System Files
You must be connected to the internet for this to work: 1.Download the MTP Firm Updater Utility from iriver website - iriverinc.com/support (Audio Jukebox --> H10) 2. Unzip file, run .exe file, go thorugh wizard (if you are not in mass storage mode, it will give you instructions on the wizard on how to change this) 3. Select Recovery 4. Finish going through wizard 5. disconnect iRiver from computer, and wait for it to update - your player should be good.
If the problem happens again, then uninstall Windows Media Player 11 from your computer and rollback to Windows Media Player 10 (you will NOT lose any songs by doing so).
-Tha Mp3 Doctor
Sep 16, 2008 | iRiver H10 MP3 Player
I need to restore the system files for my H10 Iriver MP3 player
go to www.iriver.com people - what the f--- do you think it means?
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 04, 2008 | iRiver H10 MP3 Player
Iriver (h10)
Nov 12, 2007 | iRiver H10 MP3 Player
What do i do?
Does the device appear in "My Computer"? Download the H10 firmware from iRiver's website and install it.
Jun 13, 2007 | iRiver H10 MP3 Player
iRiver H10 MP3 Player Logo
336 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Mohammad Abumuailek
Mohammad Abumuailek
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
