Question about Intel Motherboard
MSI K9N4 display garbled
I am building a new PC with a MSI K9N4 SLI-F and AMD 4400+ AM2 Processor. The video card is a GEforce 8300 AGP card. When the machine boots, the graphics are garbled and all squirrelly. For example, the bios screen has bars and streaks and "faded-looking". It's readable, but not acceptable at all. I re-seated all of the components, and I have tried replacing the video with a junky video card I had hanging around, but it did not seem to change the behavior. Also, sometimes it would not boot up at all. I figured this to be a motherboard problem, maybe a short of some sort from the standoffs, so I re-built it. In the process, I noticed that the CPU had a pin broken off. I do not have the parts to interchange to further troubleshoot whether the CPU was the only problem, or if the board is bad as well. Has anyone experienced these kind of symptoms?
  • NO_Joe Sep 07, 2007
    Nothing obviously damaged with any of the capacitors. I will have to try switching it out with a new CPU and see if it works. Thanks for the tip.
  • blackm Oct 02, 2009
    Maybe I have the same problem.
    If I use graphic card GForce 7300 with passive cooling and non external power supply, everithing works right.
    Now I would like to install graphic card GForce 8800 with external power supply and if PC boots, the graphics are garbled, letters are fuzzy and screen finishes black.
    I measured voltage on connectors with result 11,97 Volts. I mean it is right.
    I am agonized of it.
    Can anybody help ?
    Novelist:
  • 231 Answers
Hi, have a real close examination of the capacitors on the board. [round things that stand up in groups] if any of these are buldged out on top or bottom discard the board. If they are ok just fit another CPU and you should be ok, MSI make a reliable and very stable board. I have used them for several years without any problems. Regards mistyman
Posted on Sep 07, 2007
SOURCE:
Does the MSI K8n NEO4 Platinum SLI motherboard support the Geforce GTX 550 Video Card?
The MSI K8N NEO 4 Platinum Edition mobo, has an AGP graphics expansion slot. (Accelerated Graphics Port)
It uses AGP graphics cards that are either 4X, or 8X. (Supports 1.5 Volt AGP graphics cards, hence 8X)
http://www.msi.com/product/mb/K8N-Neo-Platinum.html#/?div=Detail
Click on the Specification tab. Look under the bold - Slots - subheading.
(Overview, { Which is the tab it automatically opens to}, Specification, Download, Support, News and Awards, Where to Buy )
This is Evga's version of the Nvidia GeForce GTX 550,
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130625
Click on the Details tab. (Overview, Details, Feedback)
Under the bold - Interface - heading, and to the right of the subheading - Interface, we see the interface is - PCI-Express 2.0 x16.
Tells you a lot right off the bat, if you know what you are looking at.
1) The graphics expansion slot you need on your motherboard, is a PCI-Express x16 slot.
You have an AGP graphics expansion slot. (That uses either 4X, or 8X AGP graphics cards)
2) The PCI-Express technology used is PCI-Express 2.0
Therefore the answer is No, Stephen.
[ More info on AGP graphics technology, and PCI-Express technology,
1) AGP:
http://en.wikipedia.org/wiki/AGP
2) PCI-Express:
http://en.wikipedia.org/wiki/PCI_Express
Now if someone asks you, why the GeForce GTX 550 graphics card will not work on your motherboard, you can explain why in detail, instead of just saying some dude/dudette on FixYa, said it will not work.
Are you sure some 'Mom and Pop' computer store will not trade out, a decent AGP graphics card, for the Nvidia GeForce GTX 550 you have?
Always worth a shot. Just MHO.
Regards,
joecoolvette
[ For additional questions please post in a Comment ]
May 25, 2012 | MSI : K8N NEO4 Platinum SLI/S939/nForce4...
I'm running a NVIDIA GeFOrce FX5500 on ecs motherboard p4vmm2 with 1G of RAM. Screen hangs and when I try to run DOTA it displays a garbled screen.
i have a same problem with you vhanex. my system is (Asus motherboard KBu-X, AMD sempron 1.6GHZ, 1GB of RAM, Nvidia FX5500 256MB). when i play flight simulator, it`s work perfectly. but, when i play Dota or other games like NFSU, it display a grabled screen. Anyone can help us.. thanks regard.
Mar 01, 2010 | MSI FX5500-TD256 GeForce FX 5500, (256 MB)...
I would like advice on upgrading my Graphics card
Unfortunatly your still running low end CPU power and low end agp graphics. Your going to pay 150-200 just for a fair PCIe/AGP HD/3D VC. If $200 doesnt hurt (and this is the lowest price best option), then might I suggest Mobo/CPU/RAM for around $200 that would do the trick and allow for future upgrades. You might also need a power supply. I just built one less than 3 weeks ago for a friend and it fairs against my own gaming comp.
MY PC...
AMD ATHLON 64 X2 DCP 6000+ 3.01GHz
NFORCE6M-A V:2.0
8GB PATRIOT
XFX 8800GT AD 512MB
500W PS
NEW PC....
Gigabyte GA-MA785GMT-UD2 MB $90+/-
AMD Athlon™ II X2 250 BOX 3.0GHz (CAME W/FAN)$70+/-
AND 4GB OF DDR3 1066 RAM COMPATIBLE WITH MOBO $40+/-
THE ONBOARD VIDEO IS CAPABLE OF USING 700MB
OF RAM...RGB/DVI OUT.
HOPE THIS HELPS.
Sep 12, 2009 | Asrock K7VT2 Motherboard
Hardware upgrade required for autocad 2009
Your existing CPU will not work with that motherboard. The AM2+/AM2 processor slot is for AMD processors only. For this motherboard, you will need one of the following processors: Phenom FX / Phenom / Athlon 64 FX / Athlon 64 X2
Jul 06, 2009 | Dell Dimension 8250 PC Desktop
Upgrade compatibility continued
hiya
as this pc is skt 775 and has dual core support then it is quite likely that the e5200 will work but may need a bios update to support this cpu...
just goto dells site and choose the pc u have and select drivers then download the lastest bios, transfer it to the dell pc run it as its a self extractor system will reboot perform the update then bobs ya uncle.......pop in new cpu and hey presto cheapo ugrado
#and as for the graphics card you will need to accertain which pcie version u have as most dell pc's only have pcie v1 so wont be able to handle the newer gpu's on the market.......
hope this helps
Rik
Feb 24, 2009 | Dell Dimension 9100 PC Desktop
More compatibility problems ?
what you will need to do is accertain which cpu format you have in your machine and find out if you have pcie 1 or 2
regards rich
Geforce 5500 fx for agp ultra screen flickers
use the build in video card to install the AGP card drivers first and install the card and go into the bios and make sure its set to boot from the agp slot first not build in . Thanks
Nov 26, 2008 | Palit Microsystems GeForce FX5500, (256...
Cannot POST - 1 LONG BEEP !!
reset the CMOS, and then change again the video card.
Feb 24, 2008 | MSI K9VGM-V Motherboard
Graphics cards
that might be pci express new style wont work with what u have ok
Feb 03, 2008 | Gigabyte GV-NX66T128D GeForce 6600GT 128MB...
MSI K9N4 SLI-F / Vid Card question
Hi, for the best graphics always go for dual graphic cards. This is the best way to obtain realistic 3D effects. The onboard audio chips is every bit as good as stated, MSI systems are equal to the best but at a lower price. The only change I can see that you need to make is to install a better power supply. A minimum 500w is needed with your system and if your budget allows then anthing up to 600w. Have fun with your games. Regards mistyman
Sep 21, 2007 | Intel Motherboard
Intel Motherboard Logo
50 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
