CC
Original not detected
E1
00
Lost communication with the Sorter
10
11
ASIC error
12
Image Processing Unit error
13
ROM error
14
NVRAM error
15
Page memory fault
16
SIMM not present or installed incorectly
17
Page rotation error in RAM
80
Electronic sort board error
81
82
84
88
E7
03
Lens position error
04
White level calibration error
05
Black level calibration error
12
CCD calibration error
F1
06
Shift sort motor overloaded
F5
02
Exposure lamp blown
F6
00
Fax board problems
10
80
81
82
84
88
F9
00
Printer board problems
10
80
81
82
84
88
H2
00
Fusing unit temperature error
H3
00
Overheated fusing unit
H4
00
The fusing unit doesn't heat up
L1
00
Scanner position error
L3
00
L4
01
Main motor drive overloaded
10
Separation motor overloaded
L6
10
Polygon mirror motor not up to speed
L8
01
Zero cross signal error
U2
04
EPROM error
11
Main counter error
12
EPROM error
U3
29
Mirror position error
U9
00
Op panel problem
81
82
84
88
U95
Firmware error
I have a copier that needs servicing. It is an old Xerox XC1040 model and it needs a new drum or...
(More)
I have a copier that needs servicing. It is an old Xerox XC1040 model and it needs a new drum or someone who can clean it properly. Do you have in-home service?
i cannot fax from c3200-c1. every time i try i get paperoutput that looks like pcl language - out of...
(More)
i cannot fax from c3200-c1. every time i try i get paperoutput that looks like pcl language - out of the printer. manual fax from device works
