Question about Samsung ML 4600 Laser Printer
Does not take the paper
Green light on. Once I send a job to the printer, it starts to take the paper, but fails, and "paper" light and "error" are on. I tried couple of times; restart PC, cleared jobs in the queue, but nothing works. Thanks
  • 133 Answers
It's a problem with the feeder, or you haven't fed the paper properly. Make sure the clips holding the paper have a grip on the paper, but not too much to stop it from feeding. If this fails, it is likely that the feeding roller is not gripping the paper correctly and may have some nasty substance on it. If this is not the case then it will be a warranty repair on such a thing like this.
Posted on Sep 06, 2007
My lexmark Z2320 printer will not print. It places jobs in queue but still will not print. The green power light constantly flashes quickly once turned on. I have tried unplugging the printer from the main...
The flashing light on the printer indicates there is a problem. Make sure there is no paper jam or cartridges are properly installed. Disconnect the printer from your computer. Remove the sheets of paper from the printer. Open the printer cover and remove the cartridges. Close the cover. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, re-insert the cartridges (make sure the cartridges still have ink in them). Close the printer cover and check the power light. If not blinking, proceed with loading of paper. Reconnect the printer to your computer.
Make sure the print queue has no pending print jobs before sending another print job.
Jun 18, 2011 | Lexmark Z2320 InkJet Printer
Cannot empty the print que print jobs on IMac status is Deleted, except for last line which says "printing", but it is not printing
This is most likely because an error with the printer is making it impossible to delete the final print job. The most common error is no paper or a paper jam. Look for blinking lights on the printer and any error messages. Feed more paper if necessary. Once you fix the problem, reset the printer or press the blinking button.
Feb 21, 2010 | Dymo LabelWriter Thermal Printer
Solid orange light and blinking green lights
To check the light Pattern of your printer
Click on Light and Error HP Laser jet 1012 Printer
Check the error details from the above link
Condition of the printer Action/Description Ready
The printer is ready to print. No action is necessary. Processing
The printer is receiving or processing data. Wait for the job to print. Processing...(job name) Ready LED is blinking.
This message is displayed while the printer is processing a current job, but has not begun to pick pages. Processing...(job name) From Tray XX Ready LED is blinking.
This message comes up for any job, once the printer starts to pick paper. Manual Feed or Continuable Error
The printer is attempting to Manual feed, media is not loaded in the paper tray, media loaded is the wrong size or type. Verify that the correct media is loaded.
Press and release the GO button to continue printing. Out of memory
The printer is out of memory. The page you are printing might be too complex for the printers memory capacity. Try lowering the resolution. See Understanding print quality settings for more information. Door open, media out, no print cartridge, or media jam
The printer is in an error state that requires operator intervention or help. Check the following:
  • The print cartridge door is completely closed.
  • Media is loaded.
  • The print cartridge is correctly installed in the printer.
  • There is no media jam.
Printer initialization
A printer initialization is taking place. No action is necessary. Fatal error
All lights are on.
  • Unplug the printer for 30 minutes, and then plug it back in.
  • If the printer still has an error, contact HP Support.
All lights are off.
  • Verify that the printer is turned on.
  • Make sure that there is power.
  • Unplug both ends of the power cord, and plug them back in.
Job Cancel
All the LEDs cycle. Canceling...(job name)
The Job Cancel button was pressed and the job is aborted. Power ON
All the LEDs cycle. Checking Paper Path and Checking Printer
This only occurs at power up. Cleaning mode/Engine test
A cleaning page or engine test page is printing.
All the LEDs cycle. Cleaning Page prints
Wait until the cleaning page is finished printing and the printer is in Ready mode. This could take up to two minutes.
Wait until the engine test page is finished printing and the printer is in Ready mode. Clearing Event Log
All the LEDs cycle.
This will happen automatically during an NVRAM Init and a cold reset. No message will be displayed. No Action is Necessary. Power On
This occurs when the product is powered on and coming out of EDOS. No Action is Necessary.
Jan 03, 2010 | HP LaserJet 1012 Printer
'Printer out of paper' message
on note pad or word you should select the paper size first because it might set to a different size. when you click file click print click properties or printing preference and choose what size of paper you have in your tray and then click ok. print ok.
check the printer paper tray setting to make sure the paper tray side guide is right agains the paper. I hope this will solve your problem.
Aug 12, 2009 | HP LaserJet 5p Printer
HP Laserjet 4L - Grinding or Growling noise when job sent to printer
purchase a maintenance kit.
replace the piper pickup roller.
since the the printer is old and lots things need to be replaced. it is easier to replace all of the necessary parts when you have the printer apart.
the job is not difficult, just time consuming.
Nov 02, 2008 | HP LaserJet 4L Printer
this could probably caused by interrupted spooled jobs that was sent earlier, as i assumed, try pressing the cancel button on the printer itself, or from your pc cancel all documents.
if you cant recover still reset the printer once again and put some paper to finish the pending job that was qued earlier
Jul 25, 2008 | Samsung ML 1610 Laser Printer
No Paper Light wont go out
is this still a current issue?
Jul 22, 2008 | Brother MFC-8860DN Printer
I have (4) documents to print, but it won't print. It says: 4 document(s) pending owner
To cancel a print job in Windows you can use one of the following two methods:
When you send a print job to the printer, the Status Monitor will appear in the bottom right corner of your screen. Another printer icon for the PROGRESS METER will also appear in the taskbar while printing is taking place. This PROGRESS METER is there so you can manage print priorities or cancel print jobs.
1. Highlight the print job in the PROGRESS METER box.
2. Click on DOCUMENT and CANCEL, or, right click on the job name and left click CANCEL or DELETE.
3. Confirm cancelling the print job.
If no PROGRESS METER appears, you can access the document queue in this fashion:
2. Right click on your Epson printer name, left click PURGE PRINT JOBS (98,ME), or CANCEL ALL DOCUMENTS (2000,XP). (Or, double-click on the printer name to see and modify the status of documents in queue.)
3. Confirm cancelling all documents.
Keep in mind that once information has been sent to the printer it resides in the spooling folders within Windows. It may a while for printing to stop as this data clears the system.
If the printer continues to print (ie multiple copies of a cancelled job, or garbled print) remove the rest of the paper from the printer and allow it to run out. Once an "out of paper" type error appears on your screen, cancel the documents. Once all print job information has deleted, reload the paper and press the paper feed button once to clear the red light and return the printer to a ready state.
Jul 16, 2008 | Epson Printer
Print head jam
Iv'e seen these problems a 100000000 times with this printer and I found a little article you may wanna read before going farther with this machine!!!! Go to
Apr 19, 2006 | Epson Stylus C80 InkJet Printer
Samsung ML 4600 Laser Printer Logo
99 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
