1930wm POP UP WINDOW FOR RESOLUTION ADJUSTMENT
Cannot get the pop up window, asking for a change of resolution, which HAS been done, to stop appearing every time I log on, or chandeISP. It is SO annoying and I lose speed and train of thought.
  • nancy24 Sep 06, 2007
    I JUST bought this monitor, I am NOT going to PAY to have this issuw=e mAYBE repaired!
  • nancy24 Sep 07, 2007
    Why should I pay YOU to fix this? I have only had this thing for 6 months!!!!!!!!!!!!!!!!!
  • 54 Answers
You can try to reinstall your video card driver, it could be the reason why you're experincing this type of problem :P
Posted on Sep 21, 2007
SOURCE:
How do I increase font size in Windows 7?
Step-1
Right click on desktop and click on personalise
Step--2
A new windows will appear Click on Windows Color
Step ---3
A new windows will appear Click on Advance appearance setting
Step---4
A new windows will appear Click on text on the window and change the font.
Regards,
M.W Sabri
Dec 18, 2014 | Computers & Internet
Graphics drivers windows 7
Right click on the desktop and a pop up menu will appear. Three items off the bottom select 'Screen Resolution' and click it. A new window will appear, in the centre are 4 options, choose the drop down menu (small black triangle) against Resolution. It will most likely be showing 640x480 in the window. Click the drop down menu and select your required resolution, the best one for your video card will have (recommended) against it. Click OK and wait for your screen to refresh. You should see a confirmation message asking to OK the change. If you do not see that DO NOT TOUCH any keys or buttons for a minute or so. If the screen went black and stayed that way you have chosen the wrong one. By leaving the keys alone for a minute, the display will automatically revert to the last setting thereby giving you the option to try a different setting. If you touch anything whilst the screen is black you may not see anything again, be warned!
Dec 21, 2013 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
How do I change my screen resolution to 1024 x768
Right click on any open area on the desktop. Select Screen Resolution if you're using windows 7 or select Options if Windows XP. If windows XP, a window will pop up and you can change the resolution on the last tab.
Mar 21, 2011 | Samsung Netbook / Intel Atom Processor /...
How can i change my display settings on my inspirion mini i cant change my screen resolution
Just right click on a BLANK area of screen and select the graphic properities from there
depending on the operating syetem vista and windows 7 will actually offer you the "change resolution" option near the bottom of the pop up when you do that.
Feb 04, 2011 | Dell Inspirion Mini 884116022442 Notebook
My laptop screen is zoomed in which is making all my icons huge. It makes my Internet pages huge also. How can I zoom out so my screen is back to normal size?
use this if using windows vista/windows 7
Set the zoom level in Magnifier. This can display objects on the screen up to sixteen times larger than actual size. Follow these steps to choose the magnification level that you want.
  1. ?id=microsoft.windows.resources.shellexecutetopiciconClick to open Magnifier.
  2. In the Scale Factor list, select a level. The zoom level in the Magnifier window will change right away. Adjust the level until it's right for you.
use this if in windows xp
  • 1 Click the "Start" button in Windows.
  • 2 Select "Control Panel."
  • 3 Select "Appearance and Themes."
  • 4 Select "Change the Screen Resolution."
  • 5 Look at the left side of the "Display Properties" dialog window. About half way down the screen you will see a box labeled "Screen resolution." There is an adjustable slider in this box.
  • 6 Move the slider left or right, by holding down the left mouse button, and moving the mouse in the appropriate direction. Release the button when the slider is pointing to the resolution you desire.
  • 7 Click the "Apply" button at the bottom right of the window. The screen will go black for an instant, and then will switch to the new resoulution. You will also see a message pop up asking you to confirm the setting. If you are unsatisfied with the appearance, then click "no," and try another resolution. Otherwise, click "yes."
  • or try the accessibility mode
    1) press start goto control panel be sure use are in classic view
    2) select accessibilty options and select display tab and uncheck the enlarged icons option and apply and click on ok. this will reset all programs to a smaller view.
    ROB
    Nov 25, 2010 | Computers & Internet
    Ratio on wide screen not correct photos appear "squashed"
    Your screen resolution is not correct for the monitor. On Win XP just right click anywhere on screen background, and choose properties from the pop up men. In the tabbed window that opens choose the "settings" tab where you'll see a slider bar for "resolution". Try different levels till you find one you like, where round object appear round and not oval. In Vista or Win 7 when you right click the background, choose "personalize" and locate the resolution settings there.
    Nov 10, 2010 | Dell Computers & Internet
    Hi, i have installed windows xp but display is not proper and text size all so i am enable to change Please suggest me if you can
    To change the text size.
    1) Right click on the desktop.
    2) Select "Properties" from the pop-up menu.
    3) Then select the "Appearance" tab.
    4) In the "Font size" field select "Normal".
    5) Click Apply.
    To change the resolution.
    3) Then select the "Settings" tab.
    4) Go to the "Screen Resolution" slider bar.
    5.1) Sliding to the left would decrease resolution meaning less quality and larger desktop icons.
    5.2) Sliding to the right would increase resolution meaning greater quality and smaller desktop icons.
    6) You will have to play around with this slider bar until you find a resolution that you like.
    NB: If your screen goes black after you have set a resolution then it means that your graphics card cannot handle that resolution, immediatly HOLD down the "Enter" key to cancel setting.
    Please take the time to rate this solution, it's the thumbs up on the top right hand side of this solution.
    Thanks.
    Nov 01, 2010 | Intel D845GVSR Motherboard
    Dell inspiron 1100 bought used reinstalled xp and monitor had only 6 inch image adjusted resolution, it grew almost perfect one more adjustment now quickly shuts. down image Windows logo with start up...
    You may have set the resolution/refresh higher than is possible for the laptop to produce, Try booting into safe mode (F8 on power up)
    if you can, you can now reduce the resolution to the monitors default resolution.
    If you have not already, pop over to the dell support site and download the right driver for your display
    Jul 19, 2010 | Dell Computers & Internet
    Changing font size for larger monitor.
    You can adjust your settings to something more to your liking by right clicking on your desktop in an empty area - then choose "properties" from the menu that pops up.
    In the new window go to the tab that says "settings" and adjust the screen resolution to something a little larger. If you change your desktop settings in this manner then a window will pop up immediately after the adjustment asking you if you want to keep the new settings or revert back to the old one. If you don't select something within like 15-30 seconds it will change back. It does that just in case you change the settings so bad you can't see anything.
    Another place to adjust the size of your fonts is to go to the "appearance" tab of the same menu and look for "font size" and there you can make your fonts bigger and ridiculously big, in case you still need to after changing the resolution.
    I hope you find this information helpful, have a blessed day!
    Dec 12, 2008 | Dell E173FP 17" LCD Monitor
    MSI K9VGM-V
    IN Windows XP: Riglt Click on desktop. Select Properties from pop-upmenu appeared. Click on Setting tab. Select and drag the Screen Resolution bar. It will set your screen resolution as much you want. Then press ok.
    IN Windows Vista: Right Click on Destop. Select Personalize then Click on Display Settings and select your resolution.
    Thanks
    Iqbal
    Mar 29, 2008 | MSI K9VGM-V Motherboard
    Computers & Internet Logo
    120 people viewed this question
    Ekse
    Alun Cox
