Question about Compaq TFT5000 15" LCD Monitor
Hello My name is Claudiu. I have Monitor Compaq TFT5000 and i have no alimentator machine (power supply) Plaease tell'me what type do i need, and where do i find it . Thank You
I need diagram conections , power suplyy 12 and 5volt of monitor compaq tft 5000s
[email protected]
thank you
Posted on Jun 14, 2008
SOURCE:
Horizontal lines tft5000 compaq monitor
Check your VGA/HDMI cable(the cable which is connecting the monitor and the system) try bloing air through the connectors and reconnect the cable properly. Hopefully this will resolve the issue.
Sep 19, 2013 | Compaq TFT5000 15" LCD Monitor
Power cable description
The power supply is 12v. There are two different versions of that model monitor and the plug connector for the power is different. One version has 4 pins on the power connector on the other has just a center pin and barrel. You need to check the connection on the back of your monitor before you order that adapter to be sure and get the correct one that you need. You can get both type here:
http://www.ccl-la.com/catalog/index.php?cPath=25
Mar 13, 2013 | HP Compaq 1720 (Carbon, Silver) 17" LCD...
My hp compaq doesn't work when i branche the cable of alimentation it signe with red
How many times does the red light come on ? It should blink a number of times, then go off for a little while, and start blinking again. The number of blinks within each cycle will help you find out what is wrong:
Number of 1-second red LED blinks followed by 2-second pause, then repeats:
2-processor thermal protection activated
3-processor not installed
4-power supply failure
5-memory error
6-video error
7-PCA failure (ROM detected failure prior to video)
8-invalid ROM, bootblock recover mode
(http://h18000.www1.hp.com/products/quickspecs/productbulletin.html#spectype=worldwide&type=html&docid=11632)
Jul 07, 2012 | HP Compaq d530 CMT PC Desktop
I have compaq tft5000 15" lcd monitor when we
It is broken. Replace it.
If you look online for a "previously-owned" 15-inch LCD monitor, expect to pay $20 to $30.
If you go to any "big-box" electronics store, you can buy a 19-inch LCD monitor for under $100.
Either way, it's much less expensive to REPLACE it
than it would be for a professional TV/video technician to try to trouble-shoot and REPAIR it.
Jan 07, 2011 | Compaq TFT5000 15" LCD Monitor
Only one time show ok display on power on than convert black dispaly
This is an old monitor, I remember working on these many years ago.
Anyways, the backlight is bad. The CCFL bulb needs to be replaced.
It is cheaper to scour ebay or something to get another one if this is in a server tray than to get it fixed.
If not, just buy a new monitor. You'll see a world of difference in picture quality.
Oct 13, 2010 | Compaq TFT5000 15" LCD Monitor
Power connection pinout
Here is a pin connection specification for the ac power supply (dual voltage adaptor)
>socket/plug for a Compaq TFT450 LCD Monitor that she
>supplied (edited for further clarity).
>The pins of the male connector (a PS2 mouse type connector) should be connected like this:
> 1 2
> 3 I 4
> 5 ^ 6
> GND GND
> 5V I 12V
> 5V ^ 12V
>For clarification - the male will be the end of your cable, and not the socket on the monitor.
>The I is the central polarising bar of the connector, and the ^ is the notch.
Jun 16, 2008 | Compaq TFT450 14" LCD Monitor
COMPAQ LCD TFT5000 GOES BLANK!
Make sure your PC's video card is set at low resolution (800 x 600) and at a refresh rate of 60 Hz.
May 04, 2008 | HP Pavilion F1703 17" LCD Monitor
Compaq tft 5000 out of work
Your backlight probably went out and needs replaced.
Jun 18, 2007 | Compaq TFT5000 15" LCD Monitor
Power light blinks fast red
Hello All,
The problem with the fast blinking power light is caused by 4 capacitors in the power supply unit going bad. We have been repairing this model for 4 or 5 years and this is a very common problem. We have a kit with all of the parts and directions available for $15.00 plus $2.00 shipping. Let me know if anyone needs the kit. [email protected] We can also do the repair for youif you are not confortaqble with disassembly of the ac power unit.
Dec 27, 2006 | Compaq TFT5000 15" LCD Monitor
Compaq tft 5005
Did the same and burnt a frazzled chip. it is on the 3rd circuit board (I believe it provides the lamp power). It is the 8 pin surface mount chip next to C900. As far as I can make out, the numbers on the chip are 4559 **** **7B I was told it's the lamp drive. If it is indeed lamp drive, then when you turn the monitor on, round the edges of a flashlight pressed to the screen, you should see a picture. If there isn't one, you may have killed more than I did. Is there no power regulator at the input? Good luck
May 18, 2006 | Compaq TFT5000 15" LCD Monitor
Compaq TFT5000 15" LCD Monitor Logo
153 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
