Question about Sony Cyber-Shot DSC-P100 Digital Camera
LCD Blank when in camera or movie mode
I can view pictures in my folder but cannot take pictures nor movies the lcd stays blank. Sometimes after I have tried changing setting the lcd is active again and I can take photos again until I switch it off, then when I put it back on again the lcd is blank again and I have to go everywhere to try to set it on again. it seems to come on at random.
    Champion:
  • 217 Answers
Defective ccd imager!! There's an internal loose inside ccd imager. Sony will replace this ccd imager free of charge. Year 2002 up to 2005 released units has a factory defect ccd imager. the company recalled those units and replaces with a stronger version of ccd imager.( they are still doing it). check it out.
Posted on Sep 07, 2007
SOURCE:
How can I obtain a picture that covers the full screen width?
There are settings accessed through the TV remote that should allow you to adjust the screen size. Sometimes movie rentals are shown at widescreen (black at top and bottom of screen) due to how the actual movie was made to be viewed by the viewing audience.
Sep 19, 2014 | Televison & Video
No preview image
Hi there:
You can view pictures in the folder when connected the camera at pc monitor? but cannot take pictures or movies... the LCD stays blank?
If this answer is yes, could be a problem with the CCD image sensor, if no, your LCD display go to bad and will need replacement.
Check this interesting article about bad CCDs.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Feb 07, 2012 | Nikon Cameras
How do i default pictures to thumbnails view?
Set current folder view to Thumnails. Then go to Tools>> Folder Options >> click Apply to all Folders
Mar 30, 2010 | Microsoft Windows XP Professional
Screen going blank but sound is fine
check around the flyback transformer for component failure. change the flyback transformer if you don't see anything wrong .
Don't forget to vote me
Sep 15, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I have a 32" Toshiba Regza, within the last week, the screen goes blank but still have audio. If I turn the TV off and back on the picture comes back, sometimes the picture stays but other times the...
i know your problem. its an inverter loose connection from CCFL to inverter output. back of your LCD inside the TV. try to remove and re-connect again. be sure no power and AC is unplugged. [email protected]
May 28, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
We are watching a movie and the picture does not fill the screen. How do I change the settings to fill the screen?
on the remote control it shows alll these different ways of viewing the the movie so try to find that on the remote
Jan 11, 2009 | Sharp AQUOS LC-45D40U 45 in. LCD...
White preview screen after pic taken
Have u tried switching the view from and eyeview(viewfinder) to LCD while viewing pictures. Sometimes we forget it and panic. Hope it helps. Good Luck.
Nov 20, 2008 | Fuji FinePix S7000 Digital Camera
SCREEN AND VIEW FINDER BLANK
Is the battery dead? Try taking it out and charging it, then put it back into the camera.
Also, you can try using another battery of the same type.
May 30, 2008 | Panasonic Lumix DMC-FZ50K Digital Camera
Video playback problem on lumix dmc tz3
I don't have a solution to the first part of your dilemma (why it won't playback) but I do have a solution for deleting the file.  On your camera are "hidden" file folders.  When you connect your camera to your computer, you probably only see two folders (that's all I see for my DMC-LZ8).  But there are more, and your undeletable picture/video is in one of these folders.  Find the folder and you'll find the file.  Delete it from your camera using the computer to do the command.  Problem solved.  Okay, so how do you find the hidden folders?  I have a Mac, so my process was this:  1) Connect camera to computer; 2) Select/open camera icon (looks like "volume disk"); 3) From top Finder bar, select File then Find;  4) Select the camera volume to limit your search to the camera (not HD or other external hard drives you may have connected to your computer); 5) Select "Kind" and in the next dropdown button "Folders".  Voila.  Happy searching.  My hidden "undeletable" video files were in a folder called "100_PANA".  I selected them then moved them to the Trash.  Be sure to eject your camera properly (don't just turn it off or disconnect it).
Good luck.  I hope this helps.
PS - My theory is that this occurred after an upload to my computer got unexpectedly disconnected before everything finished loading or else the camera got disconnected from the computer incorrectly even if the upload had already finished (see above comment to eject camera properly).  In either case, the blank/black screen, unviewable but "there" on the camera taking up memory photos/videos problem happened to me, too.  The above actions resolved it for me.
Apr 07, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Stuck on standby
The sliding button above the LCD display has three settings. You need to slide the button to the right, A camera icon for taking pictures, a movie camera in the middle and the green arrow on the left to view pictures and movies taken
Dec 28, 2007 | Fuji FinePix A350 Digital Camera
Sony Cyber-Shot DSC-P100 Digital Camera Logo
80 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
