Question about Dell E152FP 15" Flat Panel LCD Monitor
Dell Monitor 152FPC POWER BUT DIMMED SCREEN
This is my story: Ihave a Dell Monitor 152FPC and the monitor has Power ( The Power Button stay Green when pressed) But the image is very dimm. any solutions for this problem ? Thank You
  • 2 more comments
  • Anonymous Sep 07, 2007
    I check everything and looks ok.I check for dry joints but looks ok.Im thinking of check the capacitor but I do not have esr meter
    Logitech z-640 speakers sytem. set of 6 speakers 5 of them are working right, and the subwoofer it was working, but not anymore. I check all the wires and they are connected to my sound card correctly. I check my software settings and they are 5.1 speakers enable. may be something wrong with the subwoofer itself?. Please give me some advice what to do. Thank You
  • darnell57 May 16, 2008
    My monitor come up clear than goes down to dim to see. How can I solve this problem.
  • subcom_eve Sep 30, 2008
    the back light turns on for 1 second and then
    it turns back on. you can still see the images.. but no light
Xlmedium was right on the money, thanks I fixed my monitor
Posted on Feb 21, 2009
I was successful in getting the backlight repaired with this procedure. It would flash ON for about ½ second and show correct video then the screen would appear blank. I could also faintly see the test pattern when the monitor was plugged into AC power but the video cable was disconnected. Now, after having replaced the caps as described, it works fine!
0) Disconnect the AC power and VGA cables from the monitor.
1) Remove the stand from the monitor by removing the 4 screws on the back of the stand.
2) Using a small, flat-blade screwdriver and starting in the middle of one side, CAREFULLY push it in to the gap between the front and back bezel and pry the back away from the front while pushing in. The front bezel has fingers which are captured by the back, so push in on the front, and pry out on the back. I started in the middle of the right side and worked my way around the bezel.
3) Carefully pry the top edge of the back of the case away from the LCD assembly and the entire back plastic should be able to be lifted off easily.
4) Remove the screw that holds the small sheet metal door onto the back of the LCD assembly.
5) Gently pry the sheet metal door up and away, so that it can slide out.
6) Remove the 3 screws that hold the front-panel button board to the front bezel. The LCD assembly should now be free from the front bezel.
7) Carefully disconnect the cable from the LCD assembly. These are very small wires, so try to pry the connector parts apart. I started on one side and was able to get under the edge and walk it out by alternating ends. I had to remove two small stick-on foam blocks in order to remove the connector.
8) Gently peel back the silver tape that covers 2 of the 4 screws that hold the LCD assembly to the metal back. You will want to reattach the silver tape during reassembly, so only peel it back far enough to get it free from the metal bezel of the LCD.
9) Remove the 4 screws and the back and LCD should be able to be opened like a book. The backlight cables will still be attached, but you can get to the circuit boards now.
I’m trying to fix the back light, so I’ll be working with the Power Supply board. To remove the power supply board:
A) Remove the 3 screws that hold on either one of the white plastic covers over the cables that feed the backlights. This exposes the backlight cables and allows them to be gently pried out. I used a screw driver to gently lever them out. Now do the same with the other white cover and cables.
B) Carefully disconnect the white cable from the smaller video board. I plugs into the side of the video board and snakes under that board and over to the power supply board.
C) Remove the 4 screws that hold on the power supply board.
D) In the center of the power supply board is a plastic “Keeper.” Carefully squeeze the two wings into the center so that the power supply board can be lifted off of it.
E) Unplug the connector to the AC socket. The board should now be free.
F) Upon inspection, I see that the flat end of C922 is bulging and has leaked black stuff. I will be replacing it. It is a 16V 1000uF capacitor. It is OK to replace it with a higher voltage capacitor, but NOT a lower voltage one. Radio Shack has 1000uF 35V caps (RS Part # 272-1032) which are slightly larger in size, but easily fit in my board. They were about $1.59 each. Be sure to match the polarity (White negative stripe on the Cap to the wide white band on the silk screen.) Since there are two back lights, I chose to replace C923 at the same time, since I expect that it serves the same function for the other backlight.
10) Reverse the process for reassembly!
Posted on Sep 25, 2008
I just wanted to thank "Guest" if he/she happens to look at this again. That was EXACTLY what the problem was in my case, and I wouldn't have known where to start without your help. Thanks!
Posted on Nov 30, 2007
At my place of work, we've had several blown capacitors on this monitor. You can see the capacitor bulging once you tear apart the monitor. Radio Shack 1000uF is the replacement, and only costs about $1.50.
Posted on Nov 19, 2007
    Problem Solver:
  • 7 Answers
Connection could be loose ,loose pin on pinout plug, dirty connection,broken wire in cord,make sure connection is tight,bad ground in plug or wire
Posted on Sep 07, 2007
SOURCE:
Dell 1707FPt monitor doesn't display
Make sure you have the plug in tight or maybe your need a new monitor
Jan 13, 2010 | Dell UltraSharp 1800FP 18.1" LCD Flat...
I have a Dell 1707fp monitor. When I power the monitor on it powers on normally. After a few miniutes, even though the power button is still green the display goes blank. I have tested this on other known...
I just fixed my for less then 1 minute. Here was the problem, when turn on the PC with the monitor connected. The screen appear like normal for about 2 seconds then shut off black but the GREEN power LED stay on, if i press the power off and turn it back on the screen act the same thing.
Here how to fix it, turn off the PC, unplug the monitor power cable then plug it back. The power LED will stay amber. Hold down both brights minus - and plus + same time, turn on the PC, keep hold the - and + buttons press the power button turn on the monitor.
You will see the screen back on, just hold for about 10 more seconds till you see the screen seem to stay on fine then realse them. That's it how i fixed my.....GOOD LUCK
Oct 27, 2009 | Dell E173FP 17" LCD Monitor
Dell E172FPb monitor black screen green flashing power button
We have a dis-assebly and repair guide posted on our web site at:
www.ccl-la.com/monitor_repair.htm
The problem is usually the driver transistors, our guide shows where they are and what to replace to get your monitor back running again.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 30, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Blank screen, flashing green light
Internal power supply is hurting. It is a non linear supply and they switcher transisters are not working
Jul 27, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Dell E173FPc monitor. Screen is black, power button color cycles
First, verify the monitor is functional.
Monitor STFC (Self Test Feature Check)
Turn off the monitor
Plug the monitor power cord directly into the wall socket to remove any
surge protectors or APCs from the troubleshooting equation
Unplug the monitor video cable from the back of the computer
Turn on the monitor
The floating dialog box should appear on screen against a black background.
If the issue appears during the STFC, the monitor is defective.
What are the results please?
Feb 24, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
I have to press the power button 4 times on my monitor before it works
well i think there is problem with ur screen on/off switch and its technical problem just take it to the service centre. and u might wanna check the power cables before that it could be loose and ur signal cable to.make sure its hooked with ur system tightly .pleasure helping u .
Oct 24, 2008 | Dell E153FP 15" LCD Monitor
Dell Monitor won't stay on
When it goes black, does the power buton stay green or is it orange? If it's orange, the power supply/inverter is your main culprit. If the power button stays green, it sounds like the backlight for the display is bad. Either way, unless you have parts for the same monitor laying around to swap out, you're due for a new monitor. The good news- with the economy in the tank, you can search online and find some reputable vendors selling nicely sized screens for less than $100! Heck, I've even seen a 22" for $129 (once but it was there).
Sep 23, 2008 | Dell E177FP LCD Monitor
Screen going black, green LED staying on
Check to see if the image is Dimmed. Chances are the power supply on the FPD is either dead or not supplying power to the back lights.
Your problem is the power supply or the inverter on your board, you can replace it and it will be fixed.
Easy Fix REALLY EASY FIX
(inverter is what supplies power to your backlights. A lot of the times the reason a monitor goes black and the green power button is on, is because the backlights shut off. in most designs of the 1730 the inverter is embedded on the power supply. That is most often the case on this problem. Power supply/Inverter=Replace it and you will have a spanking new looking nice monitor working again. :)
Jun 19, 2008 | Gateway FPD 1730 17" Flat Panel LCD...
Dell E152FP 15" Flat Panel LCD Monitor Logo
575 people viewed this question
Ekse
Clive
Clive
