Question about HP Compaq Presario V2000 Notebook
Black Screen / Computer Stays in Standby Mode
I recently closed my laptop lid without restarting, which caused it to go into standby mode. When I came back the screen stayed black and the power signal was blinking as if it were still in standby mode. I held the power button down to turn off the computer and when I turned it back on it went right back into standby mode with the power light flashing again. There are no lights other than the power light that turn on. I tried powering down and restarting with both AC and battery power with no luck. Someone please help!!!
  • Anonymous Mar 12, 2014
    its almost like its going on standby mode alot as soon as i move the screen its back to normal but happens again
  • 89 Answers
Completely remove the battery and unplug the power cord for a few minutes. Reinsert battery and power up. You can also hit F8 when starting and see if you can boot into safe mode.
Posted on Sep 06, 2007
2 Suggested Answers
SOURCE:
  • 31 Answers
SOURCE: goes into standby when I OPEN lid
ok - if you are using XP -go to your start menu - control panel
click on power options and click on the 'advanced' tab - this will give you the options of what happens when you shut your lid.
if using Vista - click on control panel, choose 'classic view' from the left sidebar and carry on as above
hope this helps 8)
Posted on Dec 07, 2008
Toshiba Satellite L300D. Laptop will come out of sleep or hibernate mode without prompting and display the login box.
If the login box is displayed when it wakes up, that is usual. It uses a sensor to detect when the lid id open and will come out of standby when it thinks the lid is open.
Re configure the power off settings to avoid standby or sleep mode when the lid is closed.
Feb 16, 2014 | Toshiba Satellite L300D-ST3501 Notebook
Power light blinking on nv53a gateway
Your Gateway laptop comes with a series of LED lights that alert you to the state of your computer. You'll notice there are blue, purple and red lights that either blink or display solidly. Each light, blinking or solid, has a different meaning. The blue blinking light on your laptop indicates that it is in Standby mode. Your laptop goes into Standby when you close its lid without shutting down the computer. To turn this light off, you'll need to take the computer out of Standby mode, and if you want to ensure that the blinking blue light does not return, shut down the computer after each use.
Open the lid of your Gateway laptop and press the power button. Once Windows loads, enter your password if required. The blue light will no longer be blinking because the computer is no longer in Standby mode. Shut the laptop off when you finish using it rather than simply closing the lid to stop the blue light from blinking again. Click "Start" from your Windows desktop and click "Shut down." Change your computer's power settings to keep if from going into Standby mode when you close the lid if you'd rather not shut down your computer every time you use it. Click "Start" and click "Control Panel." Click "System and Security" and then click "Power Options." Click "Choose what closing the lid does" from the list of options on the left side of the window. Select "Hibernate" from the drop-down lists under "On Battery" and "Plugged In." Click "Save Changes." Your laptop will now bypass Standby mode when you close the lid and it will enter Hibernate mode instead. Hope it helps.
Jan 23, 2013 | Gateway MT6730 Notebook PC
My laptop shows black screen after turn on the system there is no start up display in screen.
Possible faulty backlight. Wait for boot-up and then close the lid or press the power button to put the laptop into sleep/standby mode. Open it up again and see if the screen comes on.
Aug 30, 2011 | Computers & Internet
Screen goes black , but when you close the lid and reopen it comes on just a bit then goes black , Is the screen bad ??
it could be the switch that change to Standby mode when you close the lid <br /> I can fix this <br /> <a href="mailto:[email protected]">[email protected]</a><br />
Aug 26, 2010 | Toshiba Satellite A135-S4527 Notebook
Hi.i have a dell e521 with a e197 fp monitor. when i turn the system on the monitor stays in stand-by mode. so i have a black screen,is it broken?
not really.. theres a possibility that the monitor is just on standby mode. try to disconnect the power cable of the monitor, then hold the power button of the monitor to drain its flea power. put the power cable back then try it again.
if its going to do the same thing, check the connection of the monitor at the back of the computer. see if its seated properly.
try restarting the computer..
try draining the flea power on the computer as well, possible that the computer is in standby or hibernate mode..
Jun 23, 2010 | Dell E197FP LCD Monitor
Screen stays blank after start up. Grafic card?
take battery out then get rid of dust then restart it if still doesn't start make sure adaptor works correctly, if problem is still there its a computer error/bug
May 30, 2010 | Fujitsu Siemens AMILO D-7830 Notebook
D800 laptop will not display on external monitor
Most laptops go into standby mode when the lid is closed. To stop this, (Windows XP) click Start, Control Panel, Performance and Maintenance, Power Options, then click on the Advanced tab, select "Do nothing" in the drop-down for "When I close the lid of my portable computer"
Feb 12, 2009 | Dell Latitude D800 Notebook
Computer does not stay in hibernation or standby mode
That happen because on the stand by or hibernate setting the time was setting in 5 minutes.
Go to Control Panel >> Display >> Screen Saver >> Power
And set the time right there as your preferences.
Oct 01, 2008 | Toshiba Satellite A135-S2276 Notebook
HP Compaq Presario V2000 Notebook Logo
506 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
