Question about Sony Televison & Video
Color is terrible - lot of green
Sony 55 inch tv, 19 months old. Color problem has occured within the last two weeks. Friend stated the cause is the lamp engine which has a cost of $ 1400.00 What is a lamp engine and does it control the color automatic correction?
  • 700 Answers
If this is a CRT type most probably loosely connection of the other color gun. Commonly attached to the backend of the CRT.Dust problem or transistor is busted for color red and blue. Or some minor component connected to driving color.
Posted on Apr 08, 2009
SOURCE:
I just bought a new lamp 3 months ago, and the screen is now very dark. With the brightness all the way up the picture is dark.
Your most likely fault is bulb failure. The only way to confirm a weak bulb situation is to replace with a known "good" bulb. Maybe your replacement bulb is not the correct one, or has a problem, like damage from shipping or poor quality to start with. We hear from many users that buy el cheapo bulbs from Internet shopping carts and have failure within 30-90 days. Many shopping carts churn out inferior copies, surplus or rejected products ranging from TV parts to doll clothes and costume jewelry.
Premature lamp failure can also occur with rough use such as:
  • Turning off TV and starting again while still hot.
  • TV turned on while Lightning strikes or other power line "bumps" occur.
  • Collisions with vacuum cleaners or balls bounced against TVs while operating.
  • Over-heating caused by poor ventilation or direct sunlight.
You may also have optical engine failure if images on the Sony Optical Engine Fault Gallery appear with the dim picture.
easyab@hotmail.com
Feb 11, 2011 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony wega 55 inch tv turns on fine but after one minute tv shuts itself off and comes back on 40 seconds later by itself and this cycle continues - none of the error code lights blink
This kind of problem occurs when lamp becomes weak that means near to end of working life hours but still not dead nor broken.
Replacement of lamp in tv will solve your problem, lamp replacement procedure is easy and would be written in user manual.
Thanks.
Oct 30, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sometimes the TV's lamp will not go on with the first Power-On
When the set shuts off again count the number of times the led on the front flashes and the color of it. ait will flsh a number of times pause and then repeat. this is an error code and will help diagnose the problem.
Apr 01, 2010 | Sony Grand WEGA KF60XBR800 60" Rear...
Mitsubishi wd-73736 bulbs buzzing noise
The Ballast that ignites the Lamp could cause the Lamp to fail and/or cause a buzzing noise. That being said, the Color Wheel in the Optical Block assembly could also cause a similar symptom. If Mitsubishi would be willing to help with the Lamp cost, I would call a local Mitsubishi repair facility to install it and see if the noise is still there and find out exactly what is causing it. Mitsubishi Customer Service Phone number is 1800-332-2119.
I hope this helps,
Skyassoc
Oct 24, 2009 | Mitsubishi WD-73736 Television
Sony xbr 60 tv has lost red color
SONY IS INVOLVED IN A CLASS ACTION SUITE-problem is a bad light engine-check into this on the web-check your model number to see what they are willing to do.
IT IS A COSTLY REPAIR IF YOU HAVE TO PAY A TECHNICIAN
Sep 03, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Loewe Articos 55 inch DLP does not turn on
Your problem besides color wheel is the Ballast Board this Board is what turns on Lamp and be sure to CK cooling Fans if fan that cools Lamp is defective Lamp will not light,nor will set turn on!Call Encompass Parts or visit their website they should have listing for parts to your TV 1-800-638-3328 and heres another company you can Call UED 1-800-648-6657 If you need to know anything else let me know.
God Bless and have a Wonderfull Day.
Jan 23, 2009 | Loewe Articos 55 55" Rear Projection...
Color fades out on tv
I have the same tv and the same problem (color banding, incorrect colors, colors blinking) occured after I replaced the lamp. I had a tv repairman take a look at my unit and he said the color index was incorrect, the tv doesn't know the correct colors to display. The best way to fix that problem is to replace the "light engine". The repairman replaced the "light engine" to my tv and everything is working great. My tv was still until warrenty so I don't know how much a new "light engine" would have cost.
Jul 27, 2008 | Mitsubishi WD-73732 73" Television
Color bands at the top of the screen - Sony KDF-50E2000
I have the same TV with the same problems. Sony has issued a recall for these tvs. Contact sony and will fix it for free or give you a discount on another tv.
Apr 02, 2008 | Sony KDF-50E2000 50" HDTV
Televison & Video Logo
78 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
