Question about Kodak EasyShare C703 Digital Camera
Lens error No. 221,0,0,0
Help, my camera was dropped and when i turn it on the lens pops out and back in and displays lens erro 221,0,0,0 then turns off.
  • 1 more comment
  • Meggan99 Dec 26, 2007
    Same problem here! I tried pushing in the lens all the way, banging the bottom. nothing helps. I even took it apart in hopes i would see something.. but i didnt want to completely break it :S
  • Anonymous May 09, 2008
    When i start my camera , i get error message Lens Error : 221,0,0,0
    lens got stuck and it is not coming out for zooming
  • Anonymous Aug 15, 2008
    same problem....except my camera was never dropped, it just stopped working one day....is there anyway to fix this error?
I have Pentex Optio E 30 camera
Posted on May 09, 2008
SOURCE:
Sony camera wil not stay on reads lens erroe 112 and turns off how can i fix it
Lens errors (system errors on Sony) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Feb 22, 2012 | Sony Cyber-shot DSC-W100 Digital Camera
WHAT IS ERROE CODE E18
Hi. thanks for your question.
The problem usually happens because dirt or sand get into the lens mechanism. But it seems that more and more people are showing, who took great care of their camera, and still started receiving E18 errors.
Here is how to fix it.
Before trying any of the suggestions, make sure your Canon has fresh batteries and it is in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but very often in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
I hope this helped you. Thank You for using FixYa
Dec 14, 2010 | Canon PowerShot A470 Digital Camera
Camera was dropped. Now it will turn on, but after a few seconds, lens begins to move in and out for about 3-5 seconds, then a messag is displayed: Pleaase turn camera off then on again". Doing this r
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 17, 2009 | Panasonic Lumix DMC-LZ3 Digital Camera
Lens error, restart camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Apr 28, 2009 | Canon PowerShot SD850 IS Digital Camera
Lens erro, camerra wont turn on, completely dead
Casio will fix it but there would be a fee. A lens error means that there has been some kind of damage done to the lens gears. Unfortunately there is nothing that can be done by the consumer, it is something that has to be sent in. Call repairs at 800-706-2534 option 2 and tell them you have a lens error and have talked to tech support already. Otherwise they will make you call tech support. :) They will tell you where to send it.
Nov 01, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
KODAK LENS ERROR
ok, mine did this and the lens semmed to be bent side ways
if yours is like this you can do like me (and this worked for me) and just apply brute force to the lens untill it is back in place ....
:D
Mar 12, 2008 | Kodak Easyshare M753 Digital Camera
Lens error
i didnt drop mine i turned it on and it had this problem what do i do??
Jan 26, 2008 | Nikon Coolpix L11 Digital Camera
Lens Stuck
Same problem guys!!! LENS HAD GOT STUCK - ABOUT ONE THIRD OUT after a knock. After lots of playing, and tapping and batteries in and out tried the whole twisting and pulling thing whilst turning off and on.
After a few minutes it came free and whole lens popped out. I then had to twist the outer part of the lens to straighten that up and allow it to fully retract. Works a treat now!
PS Tried the Sony online chat support - useless!!!!
Sep 08, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Kodak EasyShare C703 Digital Camera Logo
265 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
