Question about AKG C451B Professional Microphone
Loose Mic Head
Hi Everybody, Got given this AKG C451B mic for free - it works fine but the top housing that is on the mic seems to have come loose and as you move the mic around the top housing moves against the screws and this noise can be picked up on the headphones and the recording. Anybody else encounter this? Is there a quick fix? Just had another look at the mic head and it seems the screw holes have become bigger due to wear!! Any suggestions on what i can do? Thanks in advance.
  • 1,512 Answers
Hi intel
Aahhh the joys of second hand gear. wow, the holes have been enlarged... may be that the original screws are not fitted to it also. OR less likely, mic may have become this way from years of being pulled in and out of a bag, with loose screws the whole time. It will rattle if the screws are a loose fit, can only suggest to you at this point try and get some new screws for it. or short on that (more drastic measure) to resecure the head of the mic with a small dap of clear nail varnish about each screw head. the varnish will hold well enough, but may present an issue getting the mic apart again, this depending entirley on how much of the stuff you have applied. Less is better :). other than that, there is not really a fix. Hope this advice helps you.
regards
robotek
Posted on Oct 31, 2008
I have the AKG wms 40 dual mini mic set with two wireless mics. When mic on ch 2 is in the off position, I get lots of static. Works perfectly fine when on. What do you think is the issue?
Channel 2 mic's receiver needs the Squelch adjusted. The squelch control mutes the receiver so that when the transmitter stops transmitting, erroneous noises are not picked up and amplified.
Jan 23, 2013 | AKG WMS 40 Professional Microphone
C451eb dead?
hard to say without more info. you probably know this , but as a condenser mic it requires 48v phantom power to operate. Does the pre-amp/mixer you are plugging it into provide that (there will be a button on it marked 48v)? If not, that is the problem.
Apr 30, 2011 | AKG C451B Professional Microphone
Hum which is made worse on touching top half of mic. clearly an earthing matter. engineer has checked bottom half but does not know how to get into top half.
I have the same mic, same problem. I disassemled the mic, put it back together, and the problem fixed itself. I can't explain exactly why.
To disassemble the top part of mic, turn the 2 plastic posts inside the mic clockwise.
http://www.akg.com/mediendatenbank2/psfile/datei/96/C4000b4055d1f13eb44.pdf
Mar 18, 2011 | AKG C4000B Professional Microphone
What is the switch for on the Phantom power unit at the end of my AKG C747?
Hi,the switch for the phantom power on the microphone is to activation of the mic.Without the phantom being activated, the mic will not work.
It can only be activated with a mixer console that has a phantom activation on it. After connecting the mic to the mixer,activate the phantompoweronthe mixer and switch on the phantom power on the mic,and problem solved.
Note: Mic will not work if no phantom activated on the mixer.
Oct 20, 2010 | AKG C747 Professional Microphone
How can you open an AKG 220 perception mic to repair it? the mic got knocked over and still works, but the inside seems loose, moving around from side to side.
at the bottom of the mic where the xlr connector is you'll find a ring screw with two notches. unscrew this and you con remove the lower housing. The upper housing is hold by 5 screws.
May 13, 2010 | AKG Perception 220 Professional Microphone
My akg perception 200 is not responding
Have you tried using a another XLR cable..,or are the other mics phantom powered condensers..ie try to locate if its a mic problem or the cable..2 other points are 1 - XLR leads for phantom mics need to be XLR to XLR male to Female plugs[ends] 2- is that often an XLR to XLR cable will be not soldered or wired right,so that the power [phantom power is not getting to the mic] so ensure you have a proper cable for that job...Sorry i can't be more specific but from reading your problem all these issues come to mind..If you have ruled all these things out,then it could be the capsule or loose joint or component in the mic which means contact AKG,pro audio services or find a DIY mic person to help..G luck!!
Jan 11, 2010 | AKG Perception 200 Microphone
No sound from a Shure MX412D/C
Sounds to me like you may be missing a phantom power supply. The 570S is a Dynamic mic. The MX412d/c is a Cardioid and requires a 11-52v supply over pins 2 & 3 in the mic cable. Phantom power is a feature of most professional mixing consoles(usually 48v). If you do not have a phantom power supply on your system- then you can purchase single battery powered units to insert in the link between sound console and Mic. For example: AKG B-18
Hope this helps.
Rus.
Feb 23, 2009 | Shure MX412D / C Professional Microphone
Akg D8000S
need to buy the proper sound card ,or a mixing board built for your comp.thier is a usb cord out there,i have one with 1/4 inch on end and usb other end,im sure someone makes one with xlr.
Jan 30, 2009 | AKG C451B Professional Microphone
AKG 414 crackle
Had the same problem. Check the ground (earth) is attached properly to the mic. This will cause the signal to be interrupted and can also cause a phasing problem. A lot of techs don't check that when you send them for repair
Nov 12, 2008 | Audio Players & Recorders
My mike just stopped working, dead?
The first thing to check is the phantom power. Make sure it is there. The mic will appear dead without the power present.
Dan
Apr 07, 2008 | AKG C414BULS Professional Microphone
AKG C451B Professional Microphone Logo
160 people viewed this question
Top AKG Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Ben Armstrong
Are you an AKG Audio Player and Recorder Expert? Answer questions, earn points and help others
