Question about Dell Latitude D620 Notebook
Changeable parts for the screen
Hi! I have a broken dell latitude d620. The backlight has gone in the screen and I want to change it. I need to find a screen inverter and it have been very hard to find one for this model. Inverters cannot be bought, only together with the screens. I wonder which models are compatible with my screen inverter. I mean computer models. Or is there screens for other computer models which can be used for my dell.
  • Murre Sep 07, 2007
    Thanks for the suggestions, but I have problem to access
    the Screen Tecs website. What is the adress to the website?
  • 89 Answers
Go online to Screen Tec and visit their web site. You can find a referral for inverters. Inverters are sold without screens on a regular basis. If you are still having a problem check out www.oceansidecomputers.com/laptops.htm
Posted on Sep 06, 2007
SOURCE:
I have a dell latitude D620 that the screen look blurred, i change the resolution to the highest but still blurred.
It is unfortunate that the LCD screen has blurred. There is a possibility that the LCD screen has failed. You may want to use the below link and performing an LCD BIST:
http://dell.to/1irqbYp
Also try connecting a known good external monitor and check if that helps.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
Jul 01, 2014 | Dell Latitude D620 Laptop (Latitude-C620)...
Hi have got a dell latitude d630 laptop and a emos battery buy cant seem to be able to pinpoint what type i need many thanks
Under back of the laptop, you will find the service tags.
Go to dell official site to check your laptop details:http://support.dell.com/support/topics/global.aspx/support/my_systems_info/details
Also, if you need a replacement battery,those sites may helpful:9-cell dell LATITUDE D620 Battery http://www.battery-center.net/dell-latitude-d620-battery.html
6-cell dell d620 battery http://www.brand-new-battery.com/dell-latitude-d620.htm
Oct 30, 2011 | Dell Latitude D630 Notebook
The backlight won't turn on but occasionally will flicker.
Suggest you replace the Inverter. A Backlight goes out all at once.
90% of the time the Inverter is the hardware part at fault.
[ An LCD screen cannot produce enough light by itself.
A Backlight is used to supply the needed extra lighting.
A Backlight is a CCFL.
Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a much smaller scale
An Inverter is used to required power for the LCD screen, and the Backlight.
Boosts power up for the LCD screen, brings it down for the Backlight.
Dell Support > Latitude D600 Notebook PC > Service Manual
http://support.dell.com/support/edocs/systems/latd600/en/sm/index.htm
Replacing an Inverter is a simple job. Replacing a Backlight is not.
The Backlight is located within the LCD screen assembly.
The metal frame of the LCD screen assembly is removed along the edge where the Backlight is located, to access replacing the Backlight.
In the above list for Service Manual, click on > Display Assembly and Display Latch.
This information shows you where the Inverter is located on a Dell Latitude D620 Notebook PC.
The Latitude D620 is part of the Latitude D600 series of Notebook PC's.
http://www.insidemylaptop.com/remove-replace-lcd-screen-dell-latitude-d620-laptop/
Just one place from a quick search, that sells Inverters for a Latitude D600 series Notebook PC,
http://www.parts-people.com/index.php?action=item&id=2895
MATCH the part number listed that they have, to the part number on your Inverter.
You have to have THE correct Inverter.
Regards,
joecoolvette
Nov 05, 2010 | Dell Latitude D600 Notebook
When i turn my computer dell latitude d620 on it comes to the dell screen then the windows xp screen and then it goes black with nothing more than the mouse. what could be the problem?
This sounds like a video issue. Try starting the system into safe mode (after the dell screen, tap F8 to get the startup menu and then select safe mode) When in safe mode, go to the control panel and remove the display adapter driver from the device manager under System > hardware tab. Try booting into normal mode windows- you should be able to get into windows at that point. Download and reinstall the graphics driver from support.dell.com. If the issue reoccurs after you've reinstalled the graphics driver, it means that the video card on your system has gone out. At that point, contact Dell technical support if you are in warranty to get service- if not, try pricing the replacement video card from Ebay or Dell parts service.
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
Oct 05, 2010 | Dell Latitude D620 Laptop (Latitude-C620)...
Edited by tech1: Battery problem on old laptop dell, the most common failure on any PC laptop/notebooks'and tablets.
the batteries eventually wear out and quit taking a charge. You can run the system without a battery with no ill effects. replacements are about $100 for a new battery
Sep 27, 2010 | Dell Latitude D600 Notebook
Am seeing a web cam on the monitor base of the dell d620 i got but the web-cam seems like it isn't working at all. so am wondering if it just came that way?
The Dell Latitude D620 (I personally have one) does not have a webcam. What you are seeing is the ALS (Ambient Light Sensor), it is used to automatically adjust the backlight of the screen based on the environment's lighting. I have never seen anyone get one working.
May 19, 2010 | Dell Latitude D600 Notebook
I dropped my laptop, it works but the backlight doesn't. Ive got a dell Latitude D620 how can i repair it at home
Below is a link that gives you an illustrated view of the disassembly of your laptop. It be that the wire from the video cable has popped out of the inverter. When you remove the bezel from the lcd panel, check the plug connections on the inverter before changing the inverter out.
http://ahwee.com/how-to-disassemble-laptop-dell-latitude-d620
May 11, 2010 | Dell Latitude D620 Laptop (Latitude-C620)...
Dell Latitude D620, Black Screen/Power On
It is the backlight! That laptop uses a fluorescent lamp. It is bad.
If you look carefully at the screen, you will see the Windows desktop (or whatebver you are running). It just needs to be lit up.... from the back. Tel them to replace the LCd screen or replace the lamp.
Hope this helps!
Sep 07, 2009 | Dell Latitude D620 Notebook
Dell Latitude D620 no display on main screen!!
If you have already replaced the LCD inverter cable and still the problem is there . You also told that the display is working fine when connected to the external monitor. This mean the Video controller on the motherboard is fine. This lead us to the conclusion that you would have replace the whole LCD assembly and not the inverter cable alone.
Thanks for using fixya
Proton
Aug 31, 2009 | Dell Latitude D620 Notebook
Blank Laptop Screen
Either the LCD inverter or the LCD or, at the very least, the backlight in the LCD, is faulty. You will need to replace either your LCD inverter or the screen itself.
Jun 22, 2008 | Dell Latitude D620 Notebook
Dell Latitude D620 Notebook Logo
166 people viewed this question
Ekse
Clive
Clive
Alun Cox
