Question about HP iPAQ h6315 Smartphone
Memory card not detected
I used so many card in my device but not tedected please tell me the solution
0 characters
1 Points
I was using black berry then i switched to nokia e50 and i remove the mmc from black berry and when i inserted it to nokia e50 memory card is currupted how to solve this problem
You may need to format the memory card with your Nokia device.
However, all data in the memory card is permanently deleted if you format the memory card.
It is recommended to back up device memory regularly to the memory card. The information can be restored to your device
To back up information from device memory to a memory card, select Menu > Tools > Memory card > Options > Backup
phone mem.
To restore information from the memory card to the device memory, select Menu > Tools > Memory card >
Options > Restore from card.
Do not remove a memory card when the card is being accessed. Removing the card in the middle of an operation may damage
the memory card as well as the device, and data stored on the card may be corrupted.
If you cannot use a memory card in your device, you may have the wrong type of memory card, the card may not be formatted
for your device, or the card has a corrupted file system.
Tip: You can install and remove a memory card without removing the battery or powering off the device.
Dec 21, 2010 | Nokia E50
Windows 7 not detecting My G1
You may need to load the dirvers for the Android usb cable. Standard Windows usb drivers dont always work properly.
This unrelated article has some relevant content so jump to step four at this url. Pay close attention the the usb repair tool as well.
Aug 26, 2009 | HTC G1
Transfer files into memory card
Please follow the below steps:
Open Messaging -> Options -> Settings -> Others -> Memory In Use.
Then change memory in use to memory card and files that you received will be save in the memory card
May 29, 2009 | Nokia 3230
for that you need to open message and then go to options nad over there you will find message setting
you have to change all incoming message come to you memory card not to your phone memory
May 25, 2009 | Nokia 3230
LG Viewty KU990 pc sync
Do you mean you want to tranfer files or music files from your computer to your phone so you can enjoy music on your device? If so let me tell you that BLUETHOOTH or the SOFTWARE CD are not the best or fastest ways to sync or transfer files from your computer to your phone or vise versa, so Im going to tell you the safest, fastest, and Easiest way to do it, using your USB ,but it may require you to change settings manually on your device first. Make sure you have a Memory card,
Choose settings for USB connections
1.Find "USB connection mo..."
  • Press the menu icon.
  • Press the fourth tab.
  • Press Phone settings.
  • Press Connectivity.
  • Press USB connection mo.... 2.Select setting
  • Press Mass storage
  • Press OK. 3.Exit
    Once you've done this and have your memory in your device, Open the MY COMPUTER folder in your computer and connect your device to your computer using the USB cord, a new Icon will appear containing the folders from your device's memory card, that way you will easily be able to transfer files back and forth without the NEED of any sofware Cd's or use slow Bluethoot.
    And Welcome to the Viewty Family! Enjoy...!
  • Oct 17, 2008 | LG KU990 Viewty
    Rokr e6
    To New Guyxxx:
    For me too similar problem comes rarely, I wl restart the phone and the problem will b rectified automatically. Try this, if u still face the problem You just remove your memory card frm phone and plug it again. Also ensure the memory card is working properly.
    To Guest:
    You have to use Motorola phone toolkit to copy and backup the contacts and messages. For E6 to be detected as Mass storage, the drivers are preinstalled in XP, so no need of drivers.
    Aug 29, 2008 | Motorola Mobility ROKR E6 Smartphone
    My dell axim x30i wont detect my 4gb memory card
    If the card is a SDHC, its not compatible the axim, it will only take standard SD cards
    If its one of the early 4gb cards (which are a hack of the SD standard) its luck of the draw if it will work in any device, the x30i is reported to work with some, but you may need to try several (or find a forum with people who can tell you which ones definitely work) before you find one that works. You could try formatting it with large sectors on a pc, that works for some devices.
    There are often issues with these non-standard cards which could cause crashes and data loss even though they may appear to work in the first instance.
    They are also usually very slow
    The safest solution is to use a maximum of a 2GB card.
    If you really need 4gb or more the only way unfortunately is if there is a hacked firmware out there somewhere (but the only one I have seen is for the HTC Universal) or upgrade to a more modern device that supports SDHC which you can currently get cards up to 32GB
    Best of luck
    Jun 07, 2008 | RIM BlackBerry Pearl 8100
    You might want to "format", or "fix" your memory card, these can have corrupt items on them.
    To format the memory card:
    1. Press Menu (Center Select Key).
    2. Scroll to and select Settings.
    3. Scroll to and select Phone Status.
    4. Scroll to and select Storage Devices.
    5. Scroll to and select Memory Card.
    6. Press Menu.
      Note: If the memory card is not listed please remove and re-insert the memory card and restart Steps 1-5.
    7. Scroll to and select Format. The following message will display: "Formatting will erase all data. Continue?".
    8. Press Yes. The following message will display: "Format Complete. Enter New Label?".
    9. Press Yes and enter a desired label for the memory card.
      — or —
      Press No to use generic label.
    May 06, 2008 | Motorola Mobility ROKR E6 Smartphone
    Sony Clie n760 memory stick not detected when inserted
    Do you share this memory stick with other devices? If you pulled out the memorystick before the device(s) were finished closing the connection, the card may be corrupted. Another thing may be because your memory stick may be too large for your handheld to support. if you don't wanty to refund your $ just shrink the memory stick into a gig or less. You have to have a pc with a memory card reader that supports memory stick. just open up my computer> right click the memory stick> Fortmat and select a smaller size to format to.
    Jun 25, 2007 | Sony CLIE PEG-N760C Handheld
    HP iPAQ  h6315 Smartphone Logo
    20 people viewed this question
    Top HP PDAs Experts
    David Payne
    David Payne
    Bob S
    Level 1 Expert
    Are you a HP PDA Expert? Answer questions, earn points and help others
