Question about GPX HM3817DT Shelf System
Sound setting Every time we turn on our stereo we have to turn it down to a lower volume. We turn it down to about an 8. When it is shut off and then turned back on the volume is back up to around 18. How do we get the volume to stay at a lower level?
  • beekerbeck Nov 04, 2007
    I just purchase this stero, and I have found that when ever I turn it on it automaticly has set itsself for a level of 20. This is to loud. How do I set it to come on at a lower level
  • Kprof69 Dec 24, 2007
    Sound is set to 17 every time the unit is turned on.
I have no sound.
Posted on Oct 08, 2011
    Scholar:
  • 31 Answers
There are several complaints in FIXYA and they are all about this same fault conndition....the volume is too high when turned on...
Because of the high number of complaints about this same fault I would suggest that its a manufacturer fault.
So the manufacturer should be contacted about it to ask for your money back..
Cheers From YUBEUT..
Posted on Dec 04, 2007
My stereo amplifier shuts off when volume is raised, then it turns back on again and stays on when volume is lowered!
Obviously you are driving the amplifier too hard and it is going into protective shutdown to prevent damage to the output.
Feb 06, 2017 | Car Audio & Video
One channel muted until the volume is turned up
This problem is usually dur to some corrosion in the speaker relay. If the relay can be opened, burnish the contacts and you should be OK. The higher volume creates a higher voltage that can "jump the gap" so to speak. Once the connection is made it will remain. That is why lowering the volume will work.
Dan
Apr 14, 2010 | Yamaha AX-396 Amplifier
Repeated off and on
speaks are hooked up wrong or speakers are blowin.
Apr 01, 2010 | JVC KD-SX980 CD Player
Volume on jvc home stereo receiver cuts off at a certain level
I had the same problem and found that when I moved the speakers apart further...It works as well as it always did before my 8 speakers were introduced..I think the sound was interfering with itself.. Try it !!
Jan 18, 2009 | Audio Players & Recorders
The volume will not turn down
Do the volume controls on the stereo itself (not the remote) work? Try using a universal remote to lower the volume.
Dec 28, 2008 | Teac Audio Players & Recorders
Volume Issue with CD Player by Durabrand.
it just seems a setting problem.
go to AUDIO SETTINGS or MENU.it will have "ON VOLUME".
press volume control -ve to get desired volume.
press AUDIO or MENU to store volume level.Next time u turn it ON ,the volume will be what u SET. OK i hope this solves your problem.
Mar 24, 2008 | Audio Players & Recorders
Volume lowers
replace digital board. A hardware update is available that might solve it.
Feb 12, 2008 | Zenith E44W46LCD 44" Rear Projection...
Overload...
Pioneer posted this on it's Canadian Web Site:
Poor wiring connections, bad wires or a bad speaker may cause this. As you increase the volume, you will increase the amount of current you are drawing from the receiver. To troubleshoot this issue, try the following:
  1. Disconnect each speaker wire connection. Inspect for any frayed or damaged wiring and replace it.
  2. Check the impedance of the speakers; make sure they are properly rated for your stereo. In most cases, they need to be 8 ohms. Only a few Pioneer receivers will support lower impedance.
  3. If the problem still continues, try these steps:
    1. Turn the receiver off.
    2. Remove one speaker.
    3. Turn the receiver on.
    4. Increase the volume.
If the receiver overloads, repeat steps 1-4 (selecting a different speaker each time). If you disconnect a certain speaker and the receiver no longer overloads, have this speaker checked at a service center. It could have a bad speaker component, like a tweeter, sub-woofer, or even a bad crossover.
Dec 08, 2007 | Pioneer VSX-D514 Receiver
Volume knob
Normal Aiwa compact shelf units use what is called a jog switch for the volume. Usually you can tell the difference if when you you turn the volume up or down. It goes a short distance and seems to spring back. In this case there are two momentary contact switches. One for up one for down. With a plastic lever on the back of the knob that bumps the approriate switch whether turning down or up. If the lever is broken it will bump up against one but not the other. If it is broken plastic you know how good gluing plastic goes it never seems to hold.
Aug 02, 2006 | Aiwa NSX-A777 Shelf System
GPX HM3817DT Shelf System Logo
120 people viewed this question
Top GPX Audio Players & Recorders Experts
Joe Negus
Joe Negus
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
