WHILE DISHWASHER IS RUNNING EERY ONCE IN A WHILE THERE IS A LOUD THUMPING NOISE THAT SOUNDS LIKE MAYBE THE RACKS ARE HITTING THE INSIDE OF THE DISHWASHER DOOR BUT I'M NOT SURE.
Usually this is caused by a long spoon or something similar being hit with water and slapping the inside of the dishwasher. Also, it could be the rinse arm spinning around and hitting a tall dish or utensil in the basket below. Check to see if the arm spins all the way around before you start your load. Also, make sure all dishes can't easily move and hit the inside of the washer.
The washer will turn off during the cycle. If I open and close it, it will come on and resume. But...
(More)
The washer will turn off during the cycle. If I open and close it, it will come on and resume. But it seems to be at the 42 minutes left mark during "water heat." I have recently had to cancel, drain and put through the quick wash.
I have SMEG DWI710 given with the house. The power light is on but it does not work. The start...
(More)
I have SMEG DWI710 given with the house. The power light is on but it does not work. The start button is always in the up position is that right or is it suppose to click down. The power on off button is the only one that does anything altho the others with the exception of start do click down. I have a copy of the almost useless manual it says nothing. Help !!
