Question about HP Officejet 5610 All-In-One InkJet Printer
Set up HP 5610 to fax lost manual
Need set-up to receive fax on HP Oficejet 5610 or free copy of manual
  • 2 more comments
  • Ron Rodgers Sep 24, 2008
    When I try to fax the wininstall ask for disk 1
  • rjsvo Dec 23, 2008
    I lost my manual and I am having problems receiving calls and faxes on the same line
  • tfkeffer66 Jan 21, 2009
    I have a HP Printer 5610 series, & I need a owners manual !!! Help !!!!!!!
  • razorback883 May 11, 2010
    cartridge error, what do I do to fix it
I just bought an HP 5610 series all in one fax, copier and scanner. How do I set up the fax machine?
Posted on Dec 21, 2008
    Scholar:
  • 74 Answers
This link will get you to the HP web site page for manuals on your printer. http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&cc=us&dlc=en&product=441125&
Posted on Sep 07, 2007
Machine reads Cartridge Error. I replaced them several times. No luck?
Posted on Aug 10, 2009
  • 31 Answers
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
313
Posted on Mar 18, 2009
Good afternoon,
having trouble srtting up my fax machine!
Posted on Dec 04, 2008
SOURCE:
I can send a fax, make copies, scan but cannot receive a fax...why?
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set.
Have a nice day and do not forget to rate please...!
Feb 13, 2010 | HP Officejet 5610 All-In-One InkJet...
My HP J6480 All-in-One will fax out but I can't get it to receive incoming faxes. I have cleared the fax log, but it still won't receive incoming faxes
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
ab11
Jul 14, 2009 | HP Officejet 5610 All-In-One InkJet...
Hp all in one 5610 wont receive fax and phone line does not go on double ring . incoming fax shows phone off hook when trying to receive fax.no ready appears
hi,
ab2
Jul 07, 2009 | HP Officejet 5610 All-In-One InkJet...
Fax will not receive faxes
You have to go through your menu to fax functions & change it from manual to automatic.
Jul 02, 2009 | HP Officejet 5610 All-In-One InkJet...
FAX
If you have fax on hp officejet 5610.
You can recive fax .
start>steeting>printers and Fax> Setup Fax.You need windows XP CD for this Fax installation.IF manufacturer given software u r not need to install again.Just review the fax configuration by rigt click on fax icon then go to properties.
IF it helps
pls RATE ME
Jun 25, 2009 | HP Officejet 5610 All-In-One InkJet...
How to fax with the hp 5610 officejet printer
hi,
ab86
Jun 22, 2009 | HP Officejet 5610 All-In-One InkJet...
We have an HP OfficeJet 5610 All-In-One and several times a day we need to fax two copies of the same document to a business. Is there a way to do this without running two copies through the fax?
hi,
ab90
Jun 20, 2009 | HP Officejet 5610 All-In-One InkJet...
Can not recieve fax. currently just hooked to phone line
Receive a fax
Depending on the Auto Answer setting, your HP All-in-One can receive faxes
automatically or manually. If you have set the Auto Answer option to Off, you will
need to receive faxes manually. If the Auto Answer option is set to On (the default
setting), your HP All-in-One will automatically answer incoming calls and receive faxes
after the number of rings specified by the Rings to Answer setting. (The default
Rings to Answer setting is five rings.)
Receive a fax manually
If you set up your HP All-in-One to receive faxes manually (the Auto Answer option is
set to Off) or you answer the phone and hear fax tones,
1. Make sure the HP All-in-One is turned on and you have paper loaded in the input
tray.
2. Remove any originals from the document feeder tray.
3. If you are currently on the phone with the sender, instruct the sender to press
Start on their fax machine.
4. When you hear fax tones from a sending fax machine, do the following:
a. Press Fax on the control panel of your HP All-in-One.
b. When prompted, press 2 to select Receive fax.
c. After the HP All-in-One begins to receive the fax, you can hang up the phone.
Jan 14, 2009 | HP Officejet 5610 All-In-One InkJet...
Hp oficejet 5610 all in one not recieving
bad modem board. plug a phone into the ext jack see if you get a dial tone. The modem board can be bad even if it can send but not recieve.
Jun 11, 2008 | HP Office Equipment & Supplies
Receiving a fax
The answer mode determines whether your HP All-in-One answers incoming calls or not.
If you set the HP All-in-One to answer faxes automatically, the HP All-in-One will answer all incoming calls and receive faxes. Set the Auto Answer setting to On.If you set the HP All-in-One to answer faxes manually, you must be available to respond in person to the incoming fax call or your HP All-in-One will not receive faxes. Set the Auto Answer setting to Off. For more information on receiving faxes manually, see Receive a fax manually. If you do not know which answer mode to use, see Choose the recommended answer mode for your setup.
To set the answer mode 1 Press Setup. 2 Press 4, and then press 2. This selects Basic Fax Setup and then selects Auto Answer.
3 Press right arrow to select On or Off. 4 Press OK to accept the setting.
Mar 14, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
2,701 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
