Question about HP PSC 1315 All-In-One InkJet Printer
Will not turn on
My printer will not turn on and everything is plugged into working outlets, what can i do?
If printer in warranty. you contact to hp service station .
Posted on Sep 07, 2007
I am getting a cartridge error....have done everything I know to do and still getting the error. Just installed a new color cartridge on Jan 28th....worked fine until today
Hello shearcountry, "Lets see if this fix it." Turn-off your (Computer). Next [Turn-off] the (Printer), "Unplug" the 'Printer' from the Power Outlet; "do not make any changes" to the Computer! Disconnect (all) the Printer Cables from the Computer; "Reconnect the 'Cables' to the Computer, and 'Plug' into Power Outlet. Turn-on the Computer (first), Turn-on the Printer (second). Go to the Control Panel from the [Start Menu], open the Control Pane, and choose the (Hardware and Sound) 'applet', click Printer; if the Printer is present; click to open the Properties, click on the (Drivers) button, and select to "Update Drivers." Once you are finished, click {Apply and OK}. To finalize the changes "Restart the Computer." I hope this information is helpful? Thanks for using FixYa, paul7of9"
Feb 06, 2011 | HP Office Equipment & Supplies
What do I do about Error # 1200 for my Lexmark X4270?
1. Press Power to turn off lexmark X4270.2. Unplug your lexmark X4270 from the wall outlet.3 Check for paper jams.
4 Plug in your all-in-one lexmark X4270Cartridge
if everything is ok still the problem persists->The cartridge carrier is jammed.1. Turn off you all-in-one lexmark X42702. Unplug the all-in-one lexmark from wall outlet 2.Open control panel the cartridge access door 4.Make sure the cartridges are snapped in properly 5.check for objects obstructing the cartridge carrier 6.plug in your all-in-one printer power to turn on teh printer.
This should fix teh problem.
Sep 16, 2010 | Lexmark X4270 All-In-One InkJet Printer
My Lexmark x9350 only turns on and off if I plug and unplug...
This, probably, is a power issue on the printer. Unplug the printer from the computer. Unplug the power supply from the printer (it's the black box behind the printer where the power cord is attached). Try not to use any power strips or extensions for the power cord. If possible, plug the power cord straight to the wall outlet. With the power cord plugged in straight to the power outlet, plug the power supply back in the printer. That should refresh the printer. When everything's powered on, plug printer to computer. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
May 13, 2010 | Lexmark X9350 All-In-One InkJet Printer
HP OFFICEJET 7210 all in one printer is diplaying carriage jam and check right cartridge. I have the manual and done everything suggested but still not working. the display still shows the same . anyone...
Please perform the steps provided in the following web link:
If the issue persists, please perform:
1. Unplug the power supply from the wall outlet.
2. Unplug the power supply from the back of the printer.
3. Wait at least 20 seconds, then plug in the supply back into the wall outlet.
4. Plug in the power supply back into the printer.
5. Press the power button to turn the printer on.
If the issue persists, please replace your printer, as this is a hardware issue.
:) Dr Tony
Apr 20, 2010 | HP 7210 OfficeJet All-In-One Printer
My printer wont work. Its on and everything is plugged in correctly why wont it print it was just fine yesturday.
Turn the printer off. Disconnect the power-cord from the wall-outlet.
Turn the computer off.
Reconnect the power-cord & turn the printer on.
Turn your computer on, and try again.
Nov 30, 2009 | HP Photosmart C6180 All-In-One InkJet...
It wont turn on i plug everything the printer just dont work please help
Check your power source, make sure that the outlet has got power, if it has, then it might be that your power supply is faulty
May 25, 2009 | Lexmark X5495 All-in-One &USB...
Cleared a paper jam & now the printer will not turn on. We have checked to make sure there is no more paper jammed. We turned printer upside down as recommended earlier. Nothing fell out. We...
Hi, please check the power cord if there's any sign of damage. Try to connect the printer directly to the wall outlet or if possible plug the printer to reliable power outlet. If issue still persist contact printer manufacturer and call for service.
--->> Tirzo
Jun 12, 2008 | Office Equipment & Supplies
Beeping noise
I've had the Dell 1720dn at my desk for years. Worked flawlessly. Moved it to a different workstation and it began beeping immediately while printing. Another site said to plug it directly into the wall, instead of a battery backup. I unplugged it from the battery backup outlet, and plugged into a surge protector only outlet on the same battery backup unit.... NO MORE BEEPING. Hope this helps someone else.
Apr 01, 2008 | Dell 1720dn Laser Printer
Paper jam
dear yelly
try this methode
There are 2 different types of flashing patterns with those two lights on the printer.
Resume light and power light BLINKING ALTERNATELY
Problem: Paper is jammed in the printer.
Resume blinking SIMULTANEOUSLY with power light
The print cartridge carriage is stuck.
1. Open the top of the printer.
2. Remove anything that is blocking the carriage path.
3. Turn the printer off.
4. Turn the printer on.
There is something wrong with the printer. (I didn't write it, I am pulling this from actual HP tech documents, so don't blame me on this one) :)
If the printer will not turn off, unplug the power cable from the electrical outlet or wall outlet.
Unplug the power cord from the back of the printer.
Wait about 30 seconds.
Plug the power cord back into the wall outlet.
Plug the power cord to the back of the printer.
Jan 17, 2008 | HP Photosmart 7450 InkJet Printer
Hp 1315 all in one
The all-in-one product does not turn on If the all-in-one product does not turn on at all, try the following actions in order to determine the cause:
  3. Remove the product cable from any power strips or surge suppressors, and plug it directly into a grounded (three-prong) wall outlet.
  4. Wait at least 20 seconds, then, plug in the supply back into the wall outlet.
  5. Plug in the power supply back into the printer.
  6. Press the power button to turn the printer on.
  7. For models that have an external power supply module, verify that the power supply module is plugged in correctly. Some power supply modules have a green LED built into the connector end or on the power supply module. This LED will be lit if power is present. If the LED is not lit, replace the power supply module.
  8. Plug the power cord into a different electrical outlet. If the all-in-one product has an ADF with an external cable plugged into the back of the product, use the following procedure:
    1. Turn off the unit.
    2. Unplug the power cable from the wall outlet.
    3. Unplug the ADF cable from the back of the product.
    4. Plug the ADF cable to the back of the product.
    5. Plug in the power cable to the wall outlet, and turn on the power.
      1. If no change, the problem is not the ADF.
      2. If the problem clears, turn off the all-in-one, unplug the power cable, and reconnect the ADF.
      3. If the error returns, the ADF is defective. Contact HP Customer Care to get the ADF replaced.
  9. Disconnect the computer parallel cable from the back of the all-in-one product and try to turn on the product again. The computer might be grounding out through the parallel port. If this corrects the issue, check the grounding of the computer and outlet.
Jan 08, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
20 people viewed this question
Ben Johnson
