Part # 180008 the pressure is 20 so I know it needs to be back wash and what I need it to know is if the drain is on the very botton there is a black knob also I would like to see if I can get a manuel I never got one when I got my house. Thank you
part # 180008 pentair pool products
The drain is the black cap that is on the side on the tank near the bottom. To backwash this type of filter you do not need to drain it. Turn off pump, move multiport valve handle to backwash, run pump for 30 seconds to 2 minutes, turn off pump, move valve to rinse, run pump for 10 seconds, turn off pump, move handle back to filter. You may need to repeat depending on how dirty the filter is...
Hello & Welcome to FixYa
Ld means long drain and is displayed when it takes longer than 5
minutes to pump out the water to a point where the pressure switch resets. To
solve this problem make sure that the drain filter pump assembly located inside
the bottom front panel is clean and after cleaning if the error returns then
the pressure switch needs to be tested and if bad then it needs replacement.
Please get back to me if you have any other questions.
Kevin
