Question about HP PSC 1350 All-In-One Thermal Printer
Hp 1350 all-in-one
Every light is flashing. How do I fix this?
I cannot find the place to plug in the power cord.
Posted on Jan 10, 2008
  • 24 Answers
When power is applied to the all-in-one for the first time, the power light is solid and the check paper, check print cartridge, black copy, and color copy lights flash, the display will be blank, and the all-in-one will not respond. One or more of the following symptoms will also be observed: The all-in-one keeps turning off Cannot print, scan, or copy The print carriage will not move Windows plug and play (device detection) does not occur The all-in-one does not respond when buttons are pressed, including the power button. SOLUTION: This problem occurs for two reasons: the front panel cover was not installed or the ink cartridge access door was not closed before plugging in the all-in-one. The front panel overlay must be correctly installed before the power cord is plugged in. Follow the steps below to correct the problem: Disconnect the power cord. Lift the scanner lid and carefully line up and install the front panel overlay. Plug the power cord in. The print cartridge access door must be closed before the all-in-one is plugged in for the first time. The all-in-one cannot complete its first initialization until the door is closed. Follow the steps below to correct the problem: Disconnect the power cord. Locate and close the print cartridge access door. CAUSE: The all-in-one initializes when it is plugged in for the first time. While initializing, the all-in-one scans a bar code on the under side of the front panel cover requiring that the front panel cover be in place and that the scanner be operable. The scanner cannot operate when the cartridge access door is open On light (green) - On Check Paper light (amber) - Blink Simultaneously Check Print Cartridge light (amber) - Blink Simultaneously Black copy area backlight (green)- Blink Simultaneously Color copy area backlight (green) - Blink Simultaneously Issue Front panel overlay is not attached at all or not attached properly Solution Turn Off the all-in-one. Attach front panel overlay as instructed on Setup Poster. Turn On the all-in-one.
Posted on Sep 25, 2007
All lights flashing on HP psc 1350 printer
Resetting a Hp printer means switching off the machine, removing the cartridges, disconnecting the usb cable and the power chord, leave it off for few minutes then restarting it again without usb cable connected to it and without cartridges installed. You need to press the power button while it boots up. Leave it one for few minutes and again turn it off. Reinstall the cartridges and plug in the usb cable, again Power On the printer. That's all.
But there's another thing when you say all lights are blinking/flashing, there is chance that there's an internal faulty. Clean the cartridges contact point and the contact points on the printer. If possible, clean the printer thoroughly, including the waste ink tank. This will let you help find out the culprit.
Good luck.
Thanks for using FixYa.
Jun 20, 2010 | HP PSC 1350 All-In-One Thermal Printer
I have a HP 1350 that is flashing lights because of a power outage. Computer no longer recognized printer. How do I fix this?
Just logout + shutdown all including power off. Check connections power and cables well. Then first power on printer, then the computer. If the flashing continues then check that your cartridges are not empty.
Feb 11, 2010 | HP PSC 1350v All-In-One InkJet Printer
I have refilled ink in the hp 1350 but the orange light is still flashing beside Check print cartridge and i cant print
Those cartridges have electronics inside to tell the printer when they are empty, there's no guage inside the cartridge. Online you might find ways to reset your cartridge, but the best is to buy a new cartridge.
Jan 10, 2010 | HP PSC 1350 All-In-One Thermal Printer
All lights are flashing. This happened after a
check out the following link:
also make sure that your clear the jam first
and then restart the printer and that should make it work
Jul 14, 2009 | HP PSC 1350 All-In-One Thermal Printer
All the lights on my HP 1350 printer are blinking and it will not print. Normally where you could put the number of copies i " E" is in thaat spot.
In addition to providing information about current tasks, the lights on the front panel can also indicate error conditions, as described in the table below:
If the On light, Check Print Cartridge light, Check Paper light, and Start Copy, Black and Start Copy, Color lights are all flashing, do the following:
1 Verify that the front-panel overlay is attached to the HPPSC.
2 Turn your HPPSC off and on by disconnecting the power cord and reconnecting.
All ights blinking: An error caused the HPPSC to stop functioning.
1 Turn the HPPSC off and then on.
2 Restart your computer.
3 If the problem is not corrected, unplug the HPPSC and plug it in
If the problem persists, contact HP.
Apr 26, 2009 | Office Equipment & Supplies
The check print cartridge light keeps flashing
I replace a new cartridge and the print light still flashing
Aug 14, 2008 | HP PSC 1350 All-In-One Thermal Printer
My HP 1350 wont scan
Please perform the steps given in the below webpage.
If the issue still persists then power cycle the all-in-one.
Perform a power cycle:
  1. Verify that the unit is powered on.
  2. Remove the power cable from the rear of the unit and wait 20 seconds.
  3. Press and hold the POWER button and insert the power cable.
If the issue still persists then reset the all-in-one.
Jun 05, 2008 | HP PSC 1350 All-In-One Thermal Printer
HP PSC 1350 All-In-One Thermal Printer Logo
196 people viewed this question
Ben Johnson
