Question about Samsung HCL4715W 47" Rear Projection Television
Red CRT is dim....
Please read. Everyone keeps writing the same thing, without reading the description. Put in new PCB SUB to fix convergence (fixed) But Red CRT is now dim (all connections checked) Screen controls are located directly on each CRT board, NOT the Focus block. (Focus controls work) Screen control wire from PCB SUB directly goes to Red CRT first, then Green and Blue complete the series. Tried to adjust the Red CRT screen control dial so red is not dim. (No response). Green and Blue CRT are fine in brightness, but their screen controls do not work also, probably becuase they are in series with Red. MY QUESTION: How do I diagnose, why the screen controls do not work. I need increase the Red, so it is not so dim. Or do I have other problems. Someone mentioned to me the 220V line....
  • 3,130 Answers
Yes I did. You will need to get a service manual for this TV set to trace the voltage coming from the sweep power supply. If this is a problem that is new after you replaced the convergenbce4 board, you for sure have a broken wire or connection somewhere in the set. Have seen this happen may many times after a novice repairs a TV set. Good Luck
Posted on Sep 07, 2007
How to read and write to registry
.NET code.
It is very simple all you need is.
Imports Microsoft.Win32
Public Class Form1
Dim reg As RegistryKey = Registry.LocalMachine.CreateSubKey("Software\MyApp\", RegistryKeyPermissionCheck.ReadWriteSubTree)
Dim regKey As RegistryKey = Registry.LocalMachine.OpenSubKey("Software\MyApp\", True)
Private Sub SetBtn_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles SetBtn.Click
regKey.SetValue("KeyName", "Path")
End Sub
Private Sub GetBtn_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles GetBtn.Click
Dim Path As String
Path = regKey.GetValue("KeyName")
End Sub
End Class
Jun 23, 2009 | Microsoft Visual Basic Enterprise Edition...
Convergence Issue?
1 read the manual,2 look under convergance,3 follow the instructions.if you can not do 1,2 or
find a hetrosexualman that can read and make him dinner.If you do not have a manual look up the manufacture and you will be able to down load one for free.
Jan 18, 2009 | Mitsubishi WS-55807 TV
Use and access
Imports System
Imports System.IO
Imports System.Data
Public Class SaveImage
Shared Sub main()
Dim o As System.IO.FileStream
Dim r As StreamReader
Dim gifFile As String
Console.Write("Enter a Valid .Gif file path")
gifFile = Console.ReadLine
If Dir(gifFile) = "" Then
Console.Write("Invalid File Path")
Exit Sub
End If
o = New FileStream(gifFile, FileMode.Open, FileAccess.Read, FileShare.Read)
r = New StreamReader(o)
Dim FileByteArray(o.Length - 1) As Byte
o.Read(FileByteArray, 0, o.Length)
Dim Con As New _ System.Data.OleDb.OleDbConnection("Provider=Microsoft.Jet.OLEDB.3.51;Persist Security Info=False;Data
Dim Sql As String = "INSERT INTO images (Pic,FileSize) VALUES (?,?)"
Dim Cmd As New System.Data.OleDb.OleDbCommand(Sql, Con)
Cmd.Parameters.Add("@Pic", System.Data.OleDb.OleDbType.Binary, o.Length).Value = FileByteArray
Cmd.Parameters.Add("@FileSize", System.Data.OleDb.OleDbType.VarChar, 100).Value = o.Length
Catch ex As Exception
End Try
End Sub
End Class
Jul 08, 2008 | Microsoft Computers & Internet
Panasonic Rear Projection TV - PT-47WXC43G Convergence Problem
The tube should be ok its the IC's regulating the convergence is your problem . A tv repairman should be able to repair it fro around $250.00 - $300.00 or less depending on who you call. Good luck
Mar 01, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Red convergence real distorted for mitsubishi ws-65807
A man with your experience won't need photos. 1)locate center PCB--has large heat sink-- 2)using a hook tool,gently lift board edge connectors.Go slow,be gentle. 3)remove all connectors to center board (unplug) Don't worry about getting them mixed up--we have a saying--they are idiot proof. 4)remove all center board hold-down screws,includes two in sister board shield and three difficult to access in large heat sink shield. 5)gently lift PCB up and to the right while releasing hold-down plastic tabs on the front e of PCB.Replace STK IC's.Throw it in reverse-done
Sep 10, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Internal Screen Adjustments No Response
thr focus block assy.has the screen and focus controls on it it about 3"x3" in size has red wires attached to it and one feeding form the flyback transformer to it.
Aug 29, 2007 | Samsung HCL4715W 47" Rear Projection...
HCL4715W Rear projection CRT problem
your screen and focus controls need adjustment to acheive a good grey scale picture the adjustment are not on the crt neck boards.(focus block)
HCL4715W Rear projection "Red" color is dim
screen adjustment,remove front bottom cove and find the focus block the screens are also on the same block,if your not sure don't try.
Aug 28, 2007 | Samsung HCL4715W 47" Rear Projection...
New PCB SUB - But blurry and color off.
have you tried to also adjust the lenses to fine tune the focus .
Toshiba model 61HX70 convergence issue
It is a good possibility you damaged something on that PCB that had the IC's, I like to use an upgraded chip the STK394-160e that is designed for HD signal stresses. I dont know why they ordered the convergence board but I suspect it would have been ok, there are also 2 jumpers that need soldering JW10 and JW50 that supply power to the chips and they REQUIRE resoldering or it will fail again. Might try reseating the RED CRT board, check for cables that you may have unhooked to see if they are not seated in their sockets properly, double check every wire you unhooked, Make sure you used a Silicone Heatsink Compound on to the back of the IC's. I dont know what all you unhooked, but check the wires going between the CRT Boards. Check for cracks in the boards to make sure they werent flexed to much. Good Luck.
Sep 09, 2006 | Toshiba 61HX70 61" Rear Projection...
Samsung HCL4715W 47" Rear Projection Television Logo
119 people viewed this question
Jerry Greenberg
Jerry Greenberg
