Question about Compaq Armada 7770DMT Notebook
Help I was given a Compaq 7770dmt and can I connect this to my home computer and how do I connect them and is there a way to transfer the programs one to the other?
    President:
  • 2,961 Answers
You can connect two pcs together by way of RJ45 cable to the network cards, its called adhoc, you use a crossover cable and set up networking using the network wizard, but you cannot transfer programmes as when they are installed they are put in different parts of the registry, so it cannot be copied over, although you can copy and paste or share any files. Make sure they are both on the same network, right click on my computer icon, properties, computer name tab and look at workgroup, make sure both pcs are named either mshome or workgroup, to change the name click to rename this computer click change.
Posted on Sep 06, 2007
SOURCE:
Transfer iPhone photos to home computer
When you connect your iPhone to your computer you can access the photos that are on there on your desktop. If you have a Mac they will already be in iPhoto waiting to be imported. If not then you can just click on your iPhone in My Computer and you can access the pictures that way.
Dec 15, 2013 | Apple iPhone Cell Phones
How do you connect to the internet on this type of computer?
This is an old baby... ripe for a museum. You can connect with the internal modem using dial-up. You could also attach an external modem or an external Ethernet adapter.
Aug 06, 2011 | Compaq Armada 7770DMT Notebook
Is it possible to bypass the built in screen monitor(compac 7770 DMT) and connect to another computer monitor. I bought my laptop at the local goodwill store and the monitor just looks like wet splatter....
1) connect your external monitor to the 7770DMT and switch it on
2) boot up the laptop
3) after it has successfully booted, you need to identify which function key toggles the external monitor on/off
4) you should be able to do this by holding down the Fn key and trying each of the F keys in turn, waiting a few seconds after pressing each one
5) begin by holding down "Fn" + "F3", "Fn" + "F4", "Fn" + "F5" etc.
Oct 18, 2010 | Compaq Armada 7770DMT Notebook
My compaq armada 7770 just doesn't come on anymore. i have so much old work disks that i need and in the past i would purchase another 7770 and just take the drive out of one and put it in the next one. ...
why not take out the drive
and put it in a cheap USB driver enclosure
now any PC can read all those files.
why not.?
why make this so hard,its just files.
nothing more complex that say Fat32 files or NTFS.
you dont have IT departments to do this for you?
here , i had to read the
compaq armada 7770 spec. to see it guts.
its got a relic PATA drive, aka then as IDE.
this size is (length /width/depth) 2.5" i think the specs are rare !!!
so buy this.
http://www.ebay.com/itm/Vantec-Nexstar-3-IDE-PATA-2-5-External-Hard-Drive-Enclosure-USB-2-0-/112432727250?hash=item1a2d8344d2:g:pdgAAOSwYvFZNevp
plug in the drive the usb connect it and bam ,all data there
go to my documents folder and sure there.
i cant guess how or where you put documents, only you know that
but anyone can search the whole hdd, for say *.DOC
or pdf. or?
Jun 14, 2017 | Compaq Armada 7770DMT Notebook
The screen on my compaq Armada 7770dmt is broken is there anywhere I can get a replacement part.
Yes you can buy a replacement screen from ebay alot cheaper then from the manufacturer. They are quite easy to replace but becareful and gentle when it comes to replacement and make sure all power is removed before attempting to change the screen as the inverter which is a long thin circuit board under the lcd screen gives out a hell of a kick as its a high voltage part
Aug 22, 2009 | Compaq Computers & Internet
Video is choppy when transferring flipvideo
I have the exact same problem ... I have a Compaq ... Vista Home Basic, plenty of RAM 1.8GHz ... FLIP told me the exact same thing ... it's exTREMEly frustrating.
Jul 23, 2009 | Pure Digital Flip Video Ultra Camcorder
Unlock compaq laptop 6710b that was given to me without software
compaq computers backdoor password is compaq....
If a password for a windows system you need a password reset program.. I have one and there is some on the net... good luck.....
Oct 30, 2008 | Compaq Computers & Internet
Problem with connection of networking and VOIP.
Go to your Run program on the computer that your are having connection problems with. Type cmd.exe in the box. When your DOS page appears, type in ipconfig/ release. Be sure to use a space between the / and the word release. After it releases, type in ipconfig/ renew, using the space as well. Close out of your DOS. Recheck your internet connection. Before you recheck it though, make sure that your computer's wireless password, if you are using any, are the same as your wireless router's password. Hope this helps.
Sep 07, 2008 | Compaq Presario Notebook
Need some help
you can connect two pcs together by way of RJ45 cable to the network cards, its called adhoc, you use a crossover cable and set up networking using the network wizard, but you cannot transfer programmes as when they are installed they are put in different parts of the registry, so it cannot be copied over, although you can copy and paste or share any files. Make sure they are both on the same network, right click on my computer icon, properties, computer name tab and look at workgroup, make sure both pcs are named either mshome or workgroup, to change the name click to rename this computer click change.
Sep 06, 2007 | Compaq Armada 7770DMT Notebook
Compaq Armada 7770DMT Notebook Logo
96 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
