Question about Samsung RS2630SH Side by Side Refrigerator
NO ICE AND IS MAKING FUNNY NOISE
I HAVE A SAMSUNG RS2630SH AND THE ICE DISPENSER WORKS EVER ONCE IN A WHILE. IT STARTED WITH A WHIRRING NOISE AND THEN STOPPED MAKING ICE. THEN STARTED AGAIN A LITTLE WHILE AGO. I HAVE READ MANY OF THE POSTS BUT CANNOT FIND THE CORRECT PART NUMBER TO REPLACE THE MOTOR MODULE THAT HAS BEEN SUGGESTED BY OTHERS. THE REFERENCES GIVEN ARE FOR A WHIRLPOOL REFERS. IS THIS THE SAME PART? I CAN FIX IT BUT JUST NEED TO KNOW WHICH PART TO ORDER SO THE REFER WILL GIVE ME ICE AND MY SANITY BACK.
  • 3 Answers
I also have the same model as you. My problem with the ice maker has been build-up of ice under the cube pan which holds the crusher and cubes. ( I pulled the pan out and cleaned up the ice, pushed and re-seated the pan against the back of the freezer where it connects into the crusher motor). In a day or 2 it was working fine again. I got this problem because my son was pullying the pan out and emptying all the ice-cubes into his cooler for his bottles of water and soda., He was not pushing the pan back far enough to seat into the motor of the crusher and this left room for the ice to accumulate under the pan and pushing it forward away from the crusher motor which makes a loud noise when the pan is not seated correctly. There is another problem I had because the freezer was opened to often. The door dispenser became warm and the crushed ice accumulated in the dispenser and froze there, so if I opened the door, ice-cubes would fall out of the pan all over the floor. Also check the back of the pan where the crusher connects to the motor, mine was full of frozen moisture turned to ice which kept the crusher from seating properly. If this is not your problem then I would call a repairman as doing it yourself can be expensive because you may buy a part and then find out the old one was ok and it still doesn't work. Ice maker parts are very expensive .If you are positive that you know what is wrong then by all means fix-it. Also check your frozen food if it is frozen solid or soft, you may have a completely different problem than the ice-maker. Hope I helped some.
                                                     Jerry
Posted on Oct 23, 2007
Why won't ice dispense from ice maker?
Pull out the ice storage bin from the refrigerator. Empty the bin if it is full. Add some ice into the bin. Reinstall bin into refrigerator. Make sure the refrigerator door(s) are closed. The ice will not dispense if the door(s) are open. Press the ice dispenser with a glass underneath it to start dispensing ice. Listen for a whirring sound. If there is a sound, then the auger that moves the ice cubes is working. Check the ice shoot in the door to see if it is blocked with ice. If you don't here any whirring sound the motor that runs the auger is probably bad. Then you will have to replace the whole ice maker assembly.
Jul 20, 2014 | GE Refrigerators
Ice dispenser on kenmore elite 31" won't dispense
Any issues with the water "uptake" to make the ice? Is it making ice & they just won't come out? Is the dispenser clogged? If you can provide a little more detail...better able to troubleshoot....is it making whirring noises (which would indicate the electrical is fine, but there's a jam or something).
Jun 12, 2014 | managemylife.com
When we get ice it flies all over the floor and makes a mess, is there a fix or do i need to return it
Hi.
The ice dispenser is defective. First check if there is ice blocking dispenser door or mechanism. That may prevent the ice-maker from stopping or may cause the ice dropping on the floor. In case try removing food and defrosting the unit completely (leave it off for 24 hours), or use an hairdryer on Cold settings to defrost manually ice from dispenser and icemaker.
If that does not work, then the appliance must be repaired. That does not mean that the fridge will be returned. The manufacturer will send you a technician to replace ice dispenser at home. If the unit is less than two years old the repair will be carried free of charge under warranty conditions.
Here all the parts and diagrams for this unit: RS2630SH/XAA.
Regards.
Ginko
Aug 08, 2011 | Samsung RS2630SH Side by Side Refrigerator
The refiderator isnt cooling and the fan is loud. freezer still works and so does the water/ice dispenser.
Here is a tip that I wrote about refrigerators and the fan noisethat they develop sometimes...
RefrigeratorFan Noise
heatman101
May 23, 2011 | Samsung RS2630SH Side by Side Refrigerator
Fridge Freezer issue
If it is a HMMMMM...CLICK sound it is the relays. (approx. every 30sec or so).... OR, condensor fan located next to the compressor.... Otherwise it is more than likely the fan(evap Fan)!
Goodluck,
Brian
Jul 07, 2008 | Samsung RS2630SH Side by Side Refrigerator
SAMSUNG RS21DCNS
The middle part of my refrigrator (RS21DCNS) is full of ice. i have removed ice many times. could you tell me whats the reason and solution of this?
Jan 15, 2008 | Samsung RS2630SH Side by Side Refrigerator
Rs21dcns
there is a double valve at the back bottom lhs. check continuity of both valve coils but doubtfull this is the problem. the fault may be that the filling tube is frozen. try looking in this area
Jun 11, 2007 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
330 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
