SOURCE: language setting
Try this: 1. unplug all cables from back of unit (turn power off as well) 2. while the printer is off hold down the * and 5 3. while holding them turn printer on 4. continue to hold buttons until display reads 'Permanent Storage Init' 5. then release buttons 6. at the end of reset it will ask you to select language and location, just press enter then 1 to confirm Hope that works!! Ed PS. You could have picked an easier language!!!
SOURCE: HP Laserjet 3030 printer/scanner/fax Language has
How can i change HP laser jet 3030 printer's language?
press Enter bottom
press left arrow key twice
press enter key
select the language you need then press inter
SOURCE: language change
Press the check button and the right arrow button in this combination:
check, arrow, check, check, check.
This should bring you back to the ready screen after a brief pause.
SOURCE: CHANGING PRINTER CONTROL PANEL LANGUAGE
See solution below:
1. Turn off the printer.
2. Press 'select' and turn on the printer. (select button should be pressed while turning it on)
3. press '-value+' to choose your language
4. press 'select' to save
5. press 'go' to return to ready mode.
Thanks
Incorrect language appears on the display
These are possible solutions. Try one of the following:
Change the language selection during initial setup
After you select a language, Language appears again on the display. To change the selection:
1 Press or repeatedly until the language you want appears on the display.
2 Press to save.
Select a different language after initial setup
1 From the control panel, press or repeatedly to choose Setup.
2 Press .
3 Press or repeatedly to choose Change Printer Default Settings.
4 Press .
5 Press or repeatedly to choose Language.
6 Press .
7 Press or repeatedly until the language you want appears on the display.
8 Press to save and exit.
Note: If you cannot understand the language on the display, see "Resetting the printer to factory default settings" on page 57.
Manual:
http://images.lexmark.com/publications/pdfs/2007/4800/v4924668_en.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
go to settings and using up/down until you see English. Only then you press ok. GL
Jaime, if that does not work, speak to HP
e-barua, oon the Touch Screen Display I see 4 square icon's in non English. The icon on the bottom Right from memory is the Settings icon, under that I see two pages of selections from print test page and etc,. Somewhere there is a language Icon, but with the strange language it is hit and miss. I will keep at it before I contact HP. e-barua, I wish you a good week and thank you for the suggestions.
I found the solution in this HP linkhttp://g2u0048.austin.hp.com/ewfrf/wc/do...
