79 buick regal clock repair
I have a 79 buick regal clock that does not work. do you repair them? the information on the back of the clock indicates general time corporation, davidson, n.c. I believe the buick part number to be 1259332. there is another number 65349. thanks, mike
    Genius:
  • 1,153 Answers
Is this the only thing that is not working on the radio? If so, then do you want to try to fix yourself or send off?
Posted on Sep 06, 2007
SOURCE:
Where is starter on 1988 buick regal
How to Replace the Starter on a Buick Regal ' eHow
www.ehow.com > Cars The Buick Regal's starting system consists of several key components. Power supplied by the battery initializes the starter relay, solenoid and motor. ... "Haynes Repair Manual, General Motors Buick Regal 1988-2005"; Robert Maddox and ...
How to Replace a Buick Starter
www.ehow.com > Cars Replacing your starter in your Buick can be a time-consuming task as each model ... Repair Manual covering FWD models of the Buick Regal (1988 thru 2004), ...
Feb 16, 2016 | 1988 Buick Regal
97 Buick Regal climate control
Hi Levi, Im AL the owner of Big As Auto Repair.
Levi, If you have the same climate control, then below is a link to a repair video for your climate control. Sorry, this is the part 3 video, look a the side to find the part 2 video and watch it first.
1997 03 Buick Regal climate control display repair part 3
Jan 09, 2015 | 1997 Buick Regal
2002 buick Regal AC/Heater fan switch works intermittentlly
I recently tried the DIY service and repair manuals from a website and it actually helped me repair transmission problem in my jcb 3cx site-master. It would'nt move forward or reverse, engine was good both solenoids for forward and reverse worked, but still couldn't diagnose the problem.
I don't have much technical knowledge but I just followed it step-wise, and now it works perfect! covers diagrams, torque specs, PCV, everything
got it from www.reliable-store.com
Feb 26, 2018 | 2002 Buick Regal
1998 Buick Regal odometer - lights not working?
There is a good video on Youtube that explains the repair . "How-to fix a 97.5-2004 buick regal gauge cluster"
Aug 16, 2011 | 1998 Buick Regal
I have a 2002 buick regal ls and the fuel gage indicator show full for a while and then go to normal level of fuel
Your fuel sending unit is going out, Most of these are located on top of your fuel tank.beside your fuel pump. "You will have to drop tank to repair, good luck to you.
Apr 16, 2011 | 2002 Buick Regal
J have a buick regal grand sport, how to fix clock time .
If you look closely on the place where all the buttons are (radio, clock, etc.), there will be two small buttons, usually with M for minute and H for hour labeling them. Hold the buttons for a couple seconds, and the clock will usually change
Mar 01, 2011 | 1994 Buick Regal Gran Sport
The light for the odometer and the shift indicator went out. How do i repair it ?
common problem,
check ebay for instrument cluster repair, if you wanna send it in to be fixed
or check youtube for buick cluster repair, for a how to video on changing /resoldering the resistors.
Jan 23, 2011 | 2003 Buick Regal
Where is the radiator drain valve on a 1993 buick regal?
back side of the radiator side tank, most liokely driver side, u have to get under the car to see it and open it, looks like a key to wind a clock
Jul 02, 2009 | 1993 Buick Regal
Heater no working on 1991 buick regal 3.1
It probably has an airlock - so needs the air leting out of it.
If you have the bleed screw on the pipe that goes from engine to bulkhead, then, with engine cold, and heater turned to heat, start engine( KEEP CLEAR OF FAN / BELTS ), and undo bleedscrew to let out air. STOP ENGINE. Refill coolant to mark with antifreeze mix.
If this soes not solve problem, it could be more serious - either blocked matrix or if you only find steam regularly - it's a head gasket problem - requiring replacement.
Jan 13, 2009 | 1995 Buick Regal
197 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
