Home | HP | iPAQ hx2410 Pocket PC | Hx2410 won't connect wit...
HP iPAQ hx2410 Pocket PC
Problem for HP iPAQ hx2410 Pocket PC
Hx2410 won't connect with the computer, i'm put as guest
By tennisqueen_ on Apr 08, 2009
Ok.. so my dad had a wireless connection installed and the activesync was working fine on his computer (Windows XP same as mine) and so when he gave it to me I installed the active sync on my computer it wouldn't connect with the device, it said that there was a problem, so i did a clean reset and cleaned everything out now it doesn't have anything and Activesync will put me as GUEST and it won't connect with the Pocket Pc. Also, when i click on START>Activesync it says that i need to install activesync on my computer and then connect the device but i've done this about three times by the way i use 4.0 activesync
Solution #1
posted on Apr 21, 2009
Not Rated)
permana_20
Rank: Apprentice
Rating: 0%, 0 votes
Its a ActiveSync that you have on your CD (bundled with u'r own IpaQ) that I think it's suite best, because I've once installed ActiveSync v4.3 (upgrading..), device connection is intermittent, and some syncronizing process fails.
Was this helpful?
Yes
No
Popular Solutions for HP iPAQ hx2410 Pocket PC
Questions and Unsolved Problems for HP iPAQ hx2410 Pocket PC
Do you recommend HP iPAQ hx2410 Pocket PC?
Answer
Answer
unit becomes warm with it switched off. batt also discharges.Its a 2400 series
Answer
the wifi is not working. have the message (uknown card in socket2)
Answer
hx 2410 will not start up. its been discharge for a while tried a hard reset but still does not... (More)
Answer
i have iPAQ hx2410 pocket pc and when i close it the instrumen tell me that i should re-enter new... (More)
Answer
I have IpaQ hx-2410 purchased 2nd hand last month, still looking for the wi-fi problem, it's keep... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP iPAQ hx2410 Pocket PC:
Top PDA Experts
Rank: Guru Guru
Solutions: 554
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more PDA Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
