Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
URGENT HELP NEEDED (editing a film) G4 0S 10.4
Bought new a month ago.Its been working perfectly daisy chained to 2 other lacie hard drives.I noticed it started not powering down when computer was shut down. Now Ive plugged the fire wire cable straight into the back of the computer and its not connected to any other harddrive. Its icon is no longer appearing on the desktop and the orange light is pulsing when it comes on rather than beeing constant ( I have about 250 gigs of quick time files on the drive ..and am editing a programme on final cut pro...help is urgent
    Novelist:
    Champion:
  • 382 Answers
It sounds as if the enclosure has failed. IF THE DRIVE IS GETTING POWER, but not making strange noises, you may just need to extract the drive from the enclosure. Keep your fingers crossed. If the drive has been affected, data recovery may be the solution. Good luck.
Posted on Oct 22, 2007
2 Suggested Answers
SOURCE:
Orbixx
  • 133 Answers
SOURCE: URGENT HELP NEEDED (editing a film) G4 0S 10.4
Some external drives don't power themselves down because their power is taken from a mains power cable, rather from USB or Firewire - so it is totally separate. Some drives are designed to power off when they do not have a USB or Firewire signal, some are not. So if you want it to power down, unplug it. As for it no longer appearing, you may want to try plugging it in to another computer to see if it appears there. If it appears on a different computer, then it's likely to be something wrong with the OS on your system - it could be that you've had it connected in the daisy chain before and now you have it singluarly connected the drivers are not being loaded properly because it would've been using the other disk's drivers as it would've gone through the daisy chain - and now it can't communicate. If it does not work in other computers, the drive is bricked and will need to be returned to the manufacturer. I'm not familiar with Macs either, however if it works with other computers, but you're at a dead end with your computer, a surefire way to fix it is to reinstall your OS.
Posted on Sep 10, 2007
The hard drive is working fine but as I added it as a second Lacie drive (daisy chained) some of my files in my main drive were switched around. Using Pro Tools, the sound banks stored in my 2nd drive are...
My wife just bought one of these a few weeks ago. We noticed right away that it would loose or change settings. If it powered down you had to reboot it or the computer or both before it would recover. There was also some issues with security settings. The driveitself seems to be fine but windows or the ports settings do need to be played with to get it to behave. I changed the time outs and power tomax out and it seemed to settle it down on ours. Not sure this will help in your case but it seems to be where these problems come from.
Sep 02, 2010 | LaCie 1TB D2 HD Quadra FireWire 400 Hard...
These units have problems with the hibernate/sleep functions of windows. It should power down when the PC actually is fully shut down, but not when it goes into sleep mode. Well, for starters you probably want to go into the driver settings and turn off the long strip of light. It serves no real purpose but has been reported to cause heat issues. I'm slightly worried that these heat issues may be what's causing your problem. Once you've done that, disconnect the power and USB from the drive. Let it sit for a good 10 minutes, to make sure it's fully cooled down, then plug the power back in, and then the USB cable. If that doesn't restore it, you'll have to remove it from device manager. Disconnect the USB again. Then right click on your my computer icon (either on your desktop or your start menu) and choose properties. That brings up a System Properties window. Click on the Hardware tab, and then on Device Manager. In Device Manager, look for this drive. You may have to hit a couple + signs to expand some things before you find it. Right click on it, and choose uninstall. Once that's done, reboot for good measure (you PROBABLY don't need to reboot, but it never hurts), and then plug the USB back in. It should detect and reinstall the drive. If you do that, you'll want to go back into the driver settings and disable the light again.
Sep 06, 2007 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
LaCie d2 Quadra is inert: service/repair or buy new one?
Check with LaCie's support site at http://www.lacie.com/us/support/ and it's a good idea that you write down the serial number of your external disk.
Jul 09, 2010 | LaCie (300770) 250 GB Hard Drive
My mac is not recognizing my Lacie 1 TB, it started a week ago. It used to work fine for 2 months or so. I got this Lacie less than 3 months ago. I have fully stored my all my music there, but now I can t...
I had the same issue -- turned out that power supply was going bad so the drive wouldn't spin up all the way; this could explain the strange noises you're hearing. I put in a support ticket with LaCie at their website and they sent me a new power supply at no charge (I was within the warranty period, I think).
Mar 08, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
La cie hard drive mount issues
I had the same problem and surprisingly, after many attempts to get the drive to mount with different connections, etc., the problem turned out to be the power adapter. If you've got the same kind of adapter on another drive, switch it out and see if your drive shows up. Good luck.
Nov 09, 2008 | LaCie Big Disk Extreme with Triple...
Firewire problem I think - I have a Sony Vaio laptop, the firewire port is 4 pin, it is connected to a LaCie CD Burner via 6 pin and the burner is daisy chained to a AcomData external hard drive via 6 pin....
If the hub has an external power supply it migh do the trick. That way you can have a backup port if needed.
Make sure the hard drive isn't connected to the hub. Sometime windows doesn't see it when its connected to a hub.
Jul 14, 2008 | Computers & Internet
Daisy chain my external hard-drives
I don't think these drives are designed to be daisy chained. This worked for SCSI drives, but not for USB drives.
Dec 20, 2007 | LaCie d2 Extreme 250GB External with...
Don't get it
I notice that you had issues initially installing the drive. Is it possible hat your actions as noted in the link corrupted the HFS+ formatting that was shipped on the drive?
Review this link
If as you noted THIS WAS THE FIRST TIME YOU USED THE DRIVE, you have no data on the drive to loose or recover.
Especially if you believe your actions may have corrupted the formatting of the drive, reformatting may be the appropriate response and could yield a working drive eliminating many return headaches. However if this does not seam reasonable contact with LaCie as to why the drive did not work directly out of the box may be appropriate. (I did confirm in the drive specs that the drive should have been formatted correctly for an apple computer -- windows users need to reformat the drive before they can use it )
I hope this helps
Dec 14, 2007 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Icon disappeared from desktop on my mac
By stating the System Profiler environment, I asume you're a Macintosh user. Try going into your DISK UTILITIES folder. Appllications/Utilities/Disk Utility And when/if the drive appears in the the pane on the left, select it and hit the MOUNT button at the top of the window. If the drive fails to mount, you may need data recovery software or services. Usually when a drive enclosure box has a flickering led, it's usually to see the drive activity as far as reading or writing to the drive. The drive may be struggling to mount or there are bad blocks or sectors on the drive. Hope this helps.
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
123 people viewed this question
Top Seagate Computers & Internet Experts
Ekse
Alun Cox
Argospete
Argospete
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
