The first 50% of the scan is digital. The second 50% is analog. Unfortunately, you can't turn of the analog scanning or ask for only digital. If you are using an antenna be sure that it is aimed in the location that will provide the most channels. If you are using an antenna, you may be able to scan for channels individually. You will have to turn the antenna 5degrees at a time and then scan for individual channels. If you do a wide range scan, all channels previously found will be erased.
Do you have an outside antenna? If so start scanning for individual channels at 000. Move 5 degrees scan for individual channels again. Move 5 degrees more. You must scan for individual channels. A wide range scan will erase everything else.
Go to Menu. Hit 7343 then mute. This should take you to a menu with a single scan option. It will take a very long time to complete this. Once you have scanned in every direction, be sure to NEVER hit the wide scan.
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/
It doesn't matter what channel number it ends up on after a scan, as long as you do the scan with it fired up it should detect it. You should then be able to edit but why bother?
I don't understand how a channel number can be described as dumber than dirt, if it does not detect it on an autoscan through ALL channels it won't work manually.
All that said you will get much better results using the video and audio outputs rather than the modulated rf feed. Look here for how to get to those outputs, your TV will need a composite and audio input for that to work. SEGA Mega Drive Genesis RCA Mod Tutorial Add Video And Audio Outputs To...
