Disney Interactive Adventures in Typing with Timon & Pumbaa for Windows, Mac Logo
A
Anonymous Posted on Aug 18, 2013
Disney interactive adventures in typing with timon and pumbaa won't run with xp
1 Related Answer
jomabug76
Josh Whitehead
  • 1148 Answers
  • Posted on May 17, 2009
SOURCE: Cannot uninstall Timon and Pumbaa Jungle Games
try reinstalling it the uninstall.
2answers
Need help to unistall
go to contol panel click on add remove programe from there u can uninstall the game
Tron evolution for pc: game won't start on first page.. even after re-installing.
- install "gfwlivesetup.exe" online, it'll download ~30MB some more
- install Tron Evolution
- run regedit,
for 64-bit, search under HKLM\SOFTWARE\Wow6432Node\Disney Interactive Studios\tr2npc
for 32-bit, search under HKLM\SOFTWARE\Disney Interactive Studios\tr2npc
modify the 2 entries "InstallExePath" and "InstallPath" as exactly where you install Tron Evolution
I cant' uninstall Disney's Timon and pumba Jungle Games
I'm not extremely good with compters but I do know 1 remedy...
Click:
Start Menu
Control Panel
Add/Remove
Choose the program you want to remove from your computer. It should automatically un-install the program. If that doesn't work you have malware or a virus or its a hard to remove game.
Take it to a computer repair shop and they will be able to remove it from your computer. It's not very cheap, but it might be your last option. :-(
2answers
I cannot uninstall the file/program disney's Princess Fashion Boutique; it's taking up 4,175 MB
Go into my computer, program files , disney and delete it there, then its gone . If that doesn't work you can download many uninstaller programs.
1helpful
Get script error message whenever you move the mouse
Is it an older game? Just for fun you could try Windows 98 compatibility mode. Right click whatever icon you use to launch the game, click the Compatibility tab up top. Then click the checkbox "Run this program in compatibility mode for:" try Windows 98. Secondly, you should uninstall the game, reboot, reinstall the game.
1helpful
Screen display problems when running Adventures in Typing
I bought this for my daughters back in 2000. Now I find my mother wants to become a silver surfer and she would like to learn how to type letters. I tried using Adventures in typing on her laptop and saw that there were compatability issues. After a lot fo experimneting I found asloution that works every time and is as simple as can be. this is what I did (and printed out for my Mum:-)
Hi Mum :-)
Video problems with Adventures in typing with Timone and Poomba
There are compatibility issues with Windows Vista and this program
To overcome these problems we need to force windows Vista to use an
older Video format (from the days when the program was first published).
A short cut has been created and placed on your desktop.
The compatibility (properties) on the short cut have been set to –
  • Windows 95
  • 256 colours
  • 640 x 480
To create the short cut –
Place the CD-rom in the Disc bay and hold down the Shift key while the the CD-rom boots up. This prevents Autorun.
Now use Windows Explorer to look at the files and folders on the CD-rom.
Look for the Setup.exe file.
Right click on it to create a short cut that will be placed on your desktop.
Go to the short cut and right click on it to select the properties.
Now change the compatibility to the settings mentioned above.
Remove the CD-rom from the disc bay.
This is how to use the program Adventures in typing with Timone and Poomba on a computer running Windows Vista
  1. Do not put the CD-rom in the computer until you are asked
  2. Indentify the shortcut/icon on your desktop to start the program
    Click on this shortcut/icon
  3. When the computer asks for the CD-rom, place it in the disc bay and wait for the program to start.
  4. Use the program as normal.
  5. To quit the program so that it saves the progress you have made – use the QUIT symbol in the program’s screen
  6. When the program has shut-down, remove the CD-rom from the disc bay
Note that steps 1 through to 7 have to be done every time the program is started and stopped.
You will not have to do anything to put settings back to where they should be – Windows Vista will do that automatically.
This is how to stop any program if you are having problems and can not see how to stop it.
  1. Press the following two keys together Ctrl Alt
  2. While holding those two keys down, press a third key – the Delete key
  3. A menu will pop up.
    Click once on the Task Manager option
  4. A new window will open with a list of the programs that are running on your computer. Click once on the program that is causing the problem.
  5. At the bottom of the new window click on End Task
  6. The program that was causing the problem will be shut down for you.
Note that using this method is a sort of emergency stop so it will not save any new work you have done on the program/file.
Top Disney Interactive Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you a Disney Interactive Video Game Console and Game Expert? Answer questions, earn points and help others
