I have a 1996 Mazda MX-3 Precidia and the engine is junk. I just need to know if an engine from a 1993 Mazda MX-3 Precidia will work? If not are there any other years that would be compatible? I'm in a jam here, I appreciate the help.
It will only work if you switch over the wiring harness and ecu too
If you have a 4 cyl motor, that any 4cyl will fit from an MX-3 (and a few other vehicles actually).
If you have a V6, then you can use any other MX-3 1.8L OR MX-6 OR Ford Probe OR Millenia 2.5L V6 motor (160hp)! You can import the KLZE (200hp) from japan for around $1300 and it will also fit (2.5L V6).
any questions, join the forum at http://www.mx-3.com/phpBB3/index.php
