Question about HP OfficeJet 6110 All-In-One InkJet Printer
Printing is very green
Recently, when I print photographs on this printer using HP (semigloss) paper and proper HP photo ink cartridges, all but the top centimetre or so has a strong greenish tinge. Small images are fine and the second print straight after is all greenish. I tried changing the colour cartridge but it didn't help. I did recently install a revised driver from Windows update.
    Problem Solver:
  • 18 Answers
I would suggest that you clean the carriage assembly with a q-tip and at least 90% solution of isopropyl alcohol. Then I would check the carriage rest area, using a clean paper towel carefully soak up any excess ink there. Then check the paper path from start to end and make sure that there is no paper pieces.
Posted on Sep 06, 2007
SOURCE:
I am printing exterior photos of a buildiing on regular paper for test only. The color is printing out with a green tinge. What is happening?
Not using genuine HP cartridges could be one reason. Low ink cartridges could cause not enough ink to be used to make a certain shade of gray or black and thus causing the green tinge. Also if you are selecting photo quality printing then you need to use photo paper. The printer drivers tell the printer different commands depending on what kind of paper you tell it you are using. Good luck!
Mar 09, 2011 | HP Deskjet 3745 Inkjet Color Printer
Photos print too redish; blues are purplish
Photo Prints Slowly on HP Advanced Photo Paper
... 8250, 8250xi and 8250v Printers - Photo Prints Slowly on HP Advanced ... Prints Slowly on HP Advanced Photo Paper - c00564372 ... 8250, 8250xi, and 8250v printers print a photo on HP Advanced Photo Paper slower than expected. The ... s.gif » Choose the Best Ink Cartridges for Your Printing Task
Choose the optimum combination of ink cartridges to enhance photo quality. s.gif » Printing Photos from a Memory Card
... to view, select, enhance, and print photos. You can also print camera-selected photos, photos you ... in the Main tray or Photo tray. Check the Photo tray light to verify that ... Load photo paper. Check the Photo tray light to verify that ... s.gif » Problems Printing from the Photo Tray
Instructions and troubleshooting on photo tray printing issues.
Aug 27, 2008 | HP Photosmart 8250 InkJet Printer
Brand new canon ink cartridges but my photographs are printing green. I tried the test print out and it came out ok. Could the photo paper I have be the problem?
Usually if your using the wrong photo paper the ink will come out wet on the print instead of drying while coming out of the tray. Printer settings then need to be changed.
I would also suggest cleaning the print heads. But you say this is a brand new machine. I'm also assuming you are using canon cartridges which would eliminate the head cleaning. Was the software installed ok also. (Driver anyway).
Dec 09, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Can print paper but photos have green tint
If you refilled the ink cartridges, this can happen. Kodak uses pigment based inks, the others use dye based inks. Also, make sure your printer is set for normal photo printing, rather than special effects.
Jan 01, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Ink not dry when printing photographs
Download the proper drivers from hp.com - DON"T use standard Windows drivers.
When you have the proper drivers installed, you will find an "Advanced" tab in your "Printing Preferences" where you can set "Ink Volume" and "Dry Time".
Try using less ink and a longer dry time.
Also, make sure you're using photopaper that is designed for "INK JET PRINTERS".
(Laser Jet paper won't work).
Any photo that you print on glossy/semi-gloss paper will be wet as it emerges from the printer (especially ones requiring lots of ink).
You could manualy "catch" each one and set aside to dry, which should only take a minute or two.
Professional printers use a special drying powder and timed spray rig when printing on coated cover stock and glossy materials.
Nov 27, 2008 | Office Equipment & Supplies
Printing problems
hi if you have firmware,you can try it. it is the best solution
Aug 08, 2008 | HP Photosmart 2610 All-In-One InkJet...
Printing options have disappeared (re plain paper; glossy paper; CD etc)
here is ur fix
The paper types available in the driver are dependent on which type of black ink cartridge is loaded in the printer. If the Photo Black ink is loaded, you should have various glossy paper choices. If the Matte Black ink is loaded, you will have a choice of plain or Matte paper types. Once the cartridge is switched, you will get the corresponding paper choices.
Mar 09, 2008 | Epson Stylus Photo 2100 InkJet Printer
Hp Deskjet 845C - Yellow Colour not Printing
I found this post to work for me when yellow was not printing on my HP PSC750 after using 2 cartridges: "Well if you want to damage your printer use alcohol. But if you want to make it work then pull the cartridge from the printer and run hot water on a couple of paper towels leaving alot of hot water in the towels. Put some thing under them to keep them from staining your counter top and then set the cartridge down onto the hotwater towel and let the hot water melt away the dry ink and in minutes you may be printing again if this is what it is. Be sure and use a dry paper towel to wipe off the ecess wet before you reinstall the cartridge."
Jan 31, 2008 | HP DeskJet 845c Printer
Photo printing
It is definite one cartridge is not running. You do one thing - 1. Write documents in MS-Word - select all - change the color to Red. Take print out. Check Printing is perfect or not.
2. Write documents in MS-Word - select all - change the color to Cyan. Take print out. Check Printing is perfect or not.
3. Write documents in MS-Word - select all - change the color to Yellow. Take print out. Check Printing is perfect or not.
I am sure when you changed the color to Cyan - it did not print Cyan or blank page you got.
So you must replace the Cyan cartridge or may be ink is not coming out through the passage. And first you have to check whether you have removed the plastic tape from the head of t he cartridge.
Oct 25, 2006 | Canon I900D InkJet Photo Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
64 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
