Question about Canon PowerShot SD600 Digital Camera
Canon Powerhot SD600 Won't turn on
I read this is os likely blown fuse. Could you walk me through the process of replacing the fuse? I am relatively good with electronics, but don't have a service manual or parts list. Thanks John
  • 1 more comment
  • Anonymous Nov 17, 2007
    Have the same problem. Tried 2 batteries already. I have contacted Canon and will post what they tell me
  • moonmonkey Mar 18, 2008
    does anyone have pics of printed circuit boards to locate fuse?
  • snickle Mar 24, 2008
    I downloaded pictures to my computer last week. Recharged my battery for my upcoming vacation. As we pulled into Disney World I pressed the on button only to find it won't turn on. Battery is fully charged, tried another battery, cleaning the contacts. Still no resonse.
With the back off ,right under the on/off button you will see a black surface mount fuse labeled 2.3 take a fine wire and jump the two side legs out and it will light up. A safer way is to ohm out the thing for continuity. You always take a chance of taking out something downstream that the fuse was originally protecting. You can get an olympus 2.0 surface mount fuse if you google it. I have in the past just piggybacked parts that lost continuity,providing you have enough extra room. Helps from destroying by dissassembling.
Posted on Mar 27, 2008
Canon sd600 wont read 16gb memory card
No. The SD600 works with MMC and SD cards, which max out at 2GB. It will not work with SDHC cards such as your 16GB card.
Apr 16, 2014 | Canon PowerShot SD600 Digital Camera
Sony 6060F blown fuse
hello!
there is a standard procedure for proper replacement of blown fuse: CRT TVs: unplug degaussing coil, replace blown fuse with 2amp fuse and turn on the set. If it works, reconnect degaussing coil, replace the fuse with correct value(5-8) amp, depends on model(see fuse note next to holder). Enjoy the show! If in a process of replacing the blown fuse with 2amp w/o degaussing coil it blows again, forget about the next step. Set need repair. It could be an easy one, replacing 1 or 2 shorted diodes or bridge rectifier, but could be real piece of work if the power supply got "fried". If your knowledge won't go further, than fuse replacement, I'd recommend local TV repair shop.
good luck,
Alex.
Jan 15, 2012 | Televison & Video
I have a Canon PowerShot SD600 Digital Camera. The battery has a full charge but the camera will not power up. I press on and nothing happens. What do you recomend?Best RegardsNeil
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Oct 02, 2011 | Canon PowerShot SD600 Digital Camera
Canon sd600, not turning on, just silent
Apr 14, 2010 | Canon PowerShot SD600 Digital Camera
My canon powershot sd600 is not downloading to my iphotos
iPhoto deals with still photographs. For videos, try using iMovie or some other video management program.
Sep 22, 2008 | Canon PowerShot SD600 Digital Camera
Camera won't power on
All digital cameras contain power units called DC/DC converters. Power failures can be caused by failed converters and/or blown fuses.
Apr 27, 2008 | Canon PowerShot SD600 Digital Camera
POWERSHOT SD600 WOULDN'T SWITCH ON
Hi , try to remove memory remove battery from partment clean contacts and assemble again .
Mar 22, 2008 | Canon PowerShot SD600 Digital Camera
Cant turn on
This is generally caused by a blown fuse. These powershot models have an excellent power protection system and will blow a fuse before damaging any critical parts in the camera. At some point the camera experienced a power surge (static electricity, short, etc) and the fuse blew. Chances are good that the camera is still just fine, but will require a fuse replacement. The charge for this at my shop is $89 plus the fuse which is a few dollars. It can be replaced by someone technically inclined who has a pair of tweezers, the proper fuse, and a soldering iron.
Jun 06, 2007 | Canon PowerShot SD600 Digital Camera
Canon PowerShot SD600 Digital Camera Logo
411 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Steven Wander
Steven Wander
Are you a Canon Camera Expert? Answer questions, earn points and help others
