CHECK OUT http://www.obd-codes.com/p0700 & P0740 Torque Converter Clutch Circuit Malfunction
SOURCE: Transmission slipping in and out
1. check fluid level ---- in neutral ,not parkand at operating temp.
2.check throttle pressure cable for binding and adjustment
3.Replace Governor Pressure Sensor and a Governor Pressure Control Solenoid
Testimonial: "great, thank you"
SOURCE: 2002 Dodge Caravan, Tranny would shift, DTC P0700, P0725
replace the input speed sensor to transmission and the wiring pigtail all are available at your chrysler dealer take your vehicle registration in to the parts counter so they have your vin # to get the right part and it is the front of trans by fluid linres to radiator.
SOURCE: 2005 Dodge RAM 1500 Quad
P1521 - VRIS Solenoid 1 I have replaced the VRIS (Variable resonance idle solenoid 1).
P0750 - Shift Solenoid A malfunction
There is more than one solenoid in the valve body and to make sure he is
replacing the right one. I will say that with an electrical malfunction
code---it's usually the wiring or the solenoid----so not a real bad
choice. Come to think of it I think there will be 4 solenoids---A,B,EPC
and TCC. So he needs to find out which one is the bad one before he goes
replacing.
Good luck
Testimonial: "Thanks for the prompt and concise answer. I suspect it might possibly even a short in the system due to abuse. At least I have a starting point now!"
