Question about Logitech Cordless Internet Handset Phone
Logitech Cordless Internet Hnadset Phone on VISTA! for SKYPE
Recently just brought a Logitect cordless internet handset for Skype... however it turned out harder to use than ever. I am using VISTA 1) FIRSTly i couldnt open the program "Logitech internet handset" a popup saying " please upgrade your operating system" comes out. 2) then i couldn't get my handset to connect (it shows disconnect all the time) 3)i've already choose my input and output on skype as 'Logitech internet handset" i've also changed my laptop's input and output devices on logitech internet hand set" 4)this only leaves me to the final question " DOES IT NOT SUPPORT VISTA AT ALL?" Thank you experts for your helpppp~ im so so lost... thanks
  • 4 more comments
  • Anonymous Nov 07, 2007
    i have vista and it says upgrade your operating system, how do i do this?
  • stout890 Nov 22, 2007
    same problem but i got it to work perfectly on my xp laptop.
  • Anonymous Feb 07, 2008
    Need
  • fotispag Jul 21, 2008
    i recently bough logitech cordless internet handset for skype and followed the instructions. I completed the software installation and connected the usb base station.
    The handset at all times shows "disconnected", and whenever i turn on my laptop i get a sign "upgrade operating system".
    My computer is using vista business.
  • kiki miki Oct 18, 2008
    I am using VISTA
    I am using VISTA
  • Anonymous Feb 12, 2009
    i have the same problem too...and still no luck with it...
Handset shows DISCONNECTED.
On Logitech support page lookup document 6674 (search).
Boot computer with minimum og services and programs running.
Start Logitech handset program - this starts skype.
the handset will disconnect.
As soon I start the new LIVE MESSENGER BETA - the hanset disconnect.
Therefor I installed a msn messenger extension in Skype extras.
This gives me the opertunity to use msn messenger without using the LIVE MESSENGER PROGRAM - if I do - Logitech Handset will not work.
Posted on Oct 29, 2008
  • 3 Answers
I had the same problem, the phone comes with a setup disk designed for XP and before, logitech have a download for vista users at the following address
www.logitech.com/index.cfm/438/233&cl=nz,en
After installing this and and doing some reseting my phone works, however in hindsight I would recommend against purchasing this particular phone, as it's sound quality is not as good as I expected.
Posted on Nov 12, 2007
Install updated driver for vista available on logitech site and uninstall messenger live (computer requires rebooting).
messenger live has compatibility issues.
Posted on Apr 22, 2009
Get the last vista driver....www.logitech.com/index.cfm/438/233&cl=nz,en
than go, start - all programs -click on logitech. on logitech internet handset click with right side of mause, then select properties and click on security. on "group or users names" activate " everyone" than "edit". on next page on "permission for everyone" under "allow" activate " full control". in the end you just need to make the default sounds to the headset in skype.
hope it will help!
Posted on Oct 27, 2008
For "upgrade your operating system" message, you should find the .exe file and right click>properties then in compatibility tab change it to XP. But anyway this phone doesn't get incoming calls in Vista. I am gonna return it.
Posted on Apr 08, 2008
Yes it does work when you install the vista driver you just need to make the default sounds to the headset in skype itself not windows
Posted on Jul 09, 2008
NOT working with VISTA
Fix it please!!!
Posted on Mar 09, 2008
SOURCE:
How do i make my logitech cordless skype phone connect
Hi, Unfortunatly since the skype version 4 the Logitech Skype IP Phone is not longer supported. You will not be able to sync the contact from skype to phone, and might not be able to connect as well. Thanks and have a nice day
J -
Feb 20, 2010 | Logitech Cordless Internet Handset for...
The handset is unable to receive calls via Skype,nor am I able to make calls via Skype Handset says Disconnected
If you use windows vista, and installed windows live messenger, you wil have alway`s this problem, solution is, dont let msn start up with your pc.
The best way, under software remove msn messenger, and install again en dont let it start wen your pc start up. skype and msn dont working together.
i hope your problem is solved
Feb 08, 2010 | Logitech Cordless Internet Handset Phone
Logitech cordless phone
make sue your on the latest software and there is no interference from other 2.4 ghz devices. also place receiver at a distance from the pc it self the emi can disconnect the phone.
Jul 24, 2009 | Logitech Cordless Internet Handset Phone
Logitech internet cordless phone will not work with IE8. and logitech appears to not support the phone anymore. The internet phone program freezes when I try to load it and I have to use task manager in XP...
Hi, Sorry as Skype stopped to support this hardware since version 4, this device has been END OF LIFE and is not in use anymore. Unfortunatly unless using Internet explorer 6 and Skype v3 there is no much you can do... Thanks and have a nice day ! J-
May 02, 2009 | Logitech Cordless Internet Handset Phone
Skype phone not working
i had the same problem on vista operating system, i uninstalled windows messenger live and all is well. for some reason messenger conflicts with it.
Apr 08, 2009 | Logitech Cordless Internet Handset Phone
Caps Lock
check this out
if u got vista, solutions seems to exist
http://www.logitech.com/index.cfm/488/558&cl=us,en
Mar 04, 2009 | Logitech Cordless Internet Handset for...
HI I am running Vista and want to install a Logitech Skype cordless phone I am hearing there can be a problem, please advise if I can do this before I buy the item Thx Robyn
You can run it in compatability mode.
http://support.microsoft.com/kb/301911/en-us
Make sure you do nothing for the graphics option or it will mess up your settings. Also, enable the "always run in compatibility mode" option.
After doing this, it worked perfect on my vista64 and my XP64. Have not tried Windows 7 x64 yet.
Tom Daly
Jan 27, 2009 | Logitech Cordless Internet Handset for...
Logitech cordless internet handset for skype -- base unit problem
You can uninstall the Skype Application and reinstall it in compatiblity mode and chose XP. To do this right click on the install exe and go to the compatibility tab/section and from the drop down chose XP. Then try reinstalling it.
That has solved a lot of issue for me with Vista.
Let me know if you need anymore help or if that does not solve your issue.
Thanks,
CompGoddess
Dec 29, 2008 | Logitech Cordless Internet Handset Phone
You advice was such a blessing
Haven't experienced this one, it should open if you right click on the icon in the tray at the bottom.
However you should still be able to change your Skype options, click on "skype", then "Tools", then "Options", then "Audio Settings", change microphone and speakers to "logitech" or whatever your computer has listed your device as. This should have the effect of changing logitech to "use handset" and gets the same result. Unfortunately the phone will never work as good as it should, for instance I can't make test calls. I hope this helpful.
Jun 13, 2008 | Logitech Cordless Internet Handset Phone
Drivers for skype phone for vista
Hi
Try this website
http://www.logitech.com/index.cfm/438/233&cl=gb,en?osid=13.
Its the Logitech Download Centre.
You will find your Vista Drivers for your skype phone there.
Nov 24, 2007 | Logitech Cordless Internet Handset Phone
Logitech Cordless Internet Handset Phone Logo
4,354 people viewed this question
Top Logitech Computers & Internet Experts
Ekse
Damen Wong
Damen Wong
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
