Question about Intermec EasyCoder 3400 Thermal Label Printer
Intermec 3400 label printer
Printer not printing. Print jobs enter the que but they do not print off or complete. The jobs sit in the print que.
  • gedmiston Sep 06, 2007
    Thanks for the response. I was able to get the printer working. I noticed that the empty/pause light was on. Not sure why it was on as I couldn't find any settings set to pause and it definitely wasn't empty. :0
    I'm thinking that some dirt tripped the sensor or something.
  • Anonymous Mar 12, 2014
    printing but not printinng text
    Problem Solver:
  • 18 Answers
Try here they oft times has a few good referance materials http://epsfiles.intermec.com/eps_files/eps_man/064678.pdf
Posted on Sep 06, 2007
  • Robert Hall Sep 06, 2007
    Use a can of compressed air carefully and try and clean out any debris in it.
    Do not turn the can of compressed air upside down as then you will be spraying propellant which acts like a freezing solution and can damage delicate sensors
Spools and prints but not printing.
Does a label come out of the printer?
Mar 03, 2014 | Intermec EasyCoder 501XP Printer
The Thermal transfer labels are not readable when I print to the Intermec easy coder PM4I. They print too light. I can use the same ribbon and label stock on an Intermec 3400 printer and they print...
You can adjust the darkness level +/- 10. If you adjust it all the way to 10 and it is still too light, there is a print head pressure adjustment screw to the left of the ribbon feed roller.
Aug 19, 2010 | Intermec EasyCoder PM4i Printer
I get 2 labels(1 with data and 1 blank)for every label printed
THE LABEL SENSOR IS NOT SENSING THE BEGINNING OF THE NEXT LABEL
Clean the photo eye that senses the label gap with a q tip and alchol
Open side door release print head and remove label stock you will see small photo eye clean
put printer in manual mode( switch 1 on to and 1 on botom on
turn printer on it should advance one label and hit skip it should advance another
put back in computer mode
should work now if it still skips check yur label desigh=n software and label mode (continuous or sense label)
Best of luck to you
Dec 29, 2008 | Intermec EasyCoder 3400 Thermal Label...
I have an Label Printer Intermec Easycoder 3400 which is kind of old (more than 8 years), and since 2 days now i cannot print anything on it (the "Empty/Pause light is always On, even if it has or not a...
the empt ause light is related to the loading of the label
turn off printer open side door and release print head feed label stock so that it stays up against the back side of the machine(left side as youface front)
Teh print head pops up like a **** shell also make sure the label stock goes under the photo eye which senses the gap between labels
There are a series of dip switches which put the printer in manual mode which is required to install labels and make sure the machine advances properly
the switch settings ar locatd on the inside for the side cover or on the very back I think manual mode is 1onat top bank and 1 on at bottom bank
Once you do this turn machine on and it shuld advance two labels and stop and green light should come on
Now you can switch the machine to compter mode ( not sure of switch setting)
If you need help yoan contact Scan Source technical support they are distributor
Good luck these are good printers and will give good service once you are familiar with them
Nov 18, 2008 | Intermec EasyCoder 3400 Thermal Label...
Intermec 3400 label printer - Connected but no printing...
your com setting must be 9600baud 7 data bits even parity
you may need to drop back to win 98
here is the syntax you need to send to the printer STX ESC E5 CAN DATA CR DATA CR ETB ETX PRINT
Oct 29, 2008 | Intermec EasyCoder 3400 Thermal Label...
TO Print the image using IPL.
I've printed images over 500kb. Can you print a small image? If not, perhaps the driver is the problem.
If you're trying to send a text file of IPL commands to the printer, set up a Generic Text printer driver, to to send the file as ascii characters instead of as a graphic image. You can set this up in addition to your Intermec driver.
Go to Printers and Faxes, Add Printer, Next, Select the Port, Select "Generic" Manufacturer, "Generic / Text Only" Printer, and give it a name like "Text". Cycle the printer power to clear previous attempts, then print the file to this printer name.
Aug 22, 2008 | Intermec EasyCoder 3400 Thermal Label...
Printing Bar Code Labels from Intermec 3400
I am using Smartforms with Intermec printer 3400-e and it works in the correct way.
What is the software that you use to build the layout of the label? In my case Loftware.
What is the code to print the Barcodes.
In my case Code 39
Aug 07, 2008 | Intermec EasyCoder 3400 Thermal Label...
C4 intermec printer
If you're using this printer on a print server then do the following
Turn Printer Off
Disconnect Data Cable
Press & Hold Feed button whilst switching on
Keep Holding Feed Button until test label is complete and light has gone red
Switch Printer off
Reset your Print Server
Plug Data Cable back into printer
Switch Printer on
This should start it printing (unless there are jobs inthe print queue, if there are then they will need to be deleted before printing will commence)
Mar 28, 2008 | Intermec EasyCoder PC4 Label Printer
MAIL MERGER
you have to send the output as such (STX) ESCe5(CAN)(DATA)(CR)(DATA)(CR)(DATA)(ETB)(ETX)PRINT
DO NOT PUT ANY SPACES BETWEEN DATA
LOOK UP SYNTAX AND PRINTING ASAMPLE LABEL IN MANUAL
HOPE THIS HELPS
Dec 04, 2007 | Intermec EasyCoder 3400 Thermal Label...
Intermec EasyCoder 3400 Thermal Label Printer Logo
732 people viewed this question
Top Intermec Office Equipment & Supplies Experts
Paul Bade
Jay Plesset
reference30
Are you an Intermec Office Equipment and Supply Expert? Answer questions, earn points and help others
