SOURCE: How to keep the blade guard off the Circular saw blade when in use?
What is (B and Q) stand for ? This is a circular saw or a table saw, or a miter/chop saw?
SOURCE: Power Glide Circular Saw with Laser Guard Spring Broken
The spring hooks onto the blade guard and wraps around the hub of the blade guard. It is orta hard to see but it will hook onto the guard.
SOURCE: Makita circular saw 5007n, it will only run when
Great!! Could you please rate my solution as a "problem solved"?
I would greatly appreciate it.
SOURCE: How to replace Ryobi circular saw CSB140LZ lower guard assembly
Clean the area where the guard attaches to the hub assy. It is a snap ring that is holding the guard on. You will need to either use a pick or a small flathead screw driver in order to remove it. There should be a little tab that you will be able to work out. Look around the entire perimeter of the hub to locate it. You may need some extra light to see it. Stick the pick or small flathead behind the tab from the right. Work the tab out and above the hub. Now you can work your pick or scredriver around the perimeter to remove the ring. Install it in a similar fashion but use the flathead to guide the ring back into the groove, working it around the opposite way.
Testimonial: "Got it. Thanks"
SOURCE: Instructions or diagrams on how to replace a power cord
saw just quit,fairly new ,light comes on ,so theres power
